Xsonic Xtone
Started by admin, February 24, 2019, 10:11:59 AM
XSONIC XTONE High Resolution · Quality Pedal Type Audio Interface
I]Audio interface for pedal style musical instruments supporting high res. In addition to Windows and Mac, it also supports iOS / Android.
It can be operated directly connected with popular applications such as JamUp, Bias, Guitar Rig, AmpKit, Revalver, AmpliTube, Mobile POD, POD Farm and Overloud TH 2. The body is equipped with three foot switches and EXP.
https://www.amazon.com/Mobile-Guitar-Interface-Control-Latency/dp/B07DBYT4HT
Description
①XTONE is a high-performance mobile audio interface, designed for the next-generation effect APPs, like JamUp, BIAS AMP, BIAS FX. XTONE's excellent audio performance gives you the best experience of using these APPs. XTONE can be directly powered by your phone and have 3 foot switch and 1 expression pedal for playing control; ②XTONE provides 192KHz sampling rate and 118dB dynamic rang, This is unique in all mobile audio interface, that makes XTONE have the best sound. XTONE + APP has been able to replace the flagship hardware effect. ③XTONE provides foot switch and expression pedal, can switch the preset, control the volume, control the wah-wah and so on. ④XTONE uses a professional XSPEED acceleration processing technology, make the latency much lower than the similar products.
Features & details
192KHz Ultra-HD Audio
Foot Switch & Expression Pedal
Low Latency & High Dynamic Range
iPhone Direct Power Supply
Support iOS/Windows/Mac
https://www.amazon.com/Professional-Mobile-Interface-Control-Latency/dp/B07RJM4WVP/ref=mp_s_a_1_3?m=A8LO3NIMUTTXE&qid=1557328896&s=merchant-items&sr=1-3
Description
①XTONE Pro is a professional stage and and multi-purpose intelligent audio interface for guitar, bass and vocals. Put it on the floor, it is a flagship level multi-effects pedal, that meets your daily practice, professional rehearsal and performance needs. ②Like XTONE, XTONE Pro is designed for the use of effects Apps ,and has an ultra-high sampling rate of 192KHz. For a better experience with software effects, Pro is optimized for latency and dynamic range compared to traditional audio interfaces. Pro has a higher dynamic range, clearer tone and ultra-low latency. ③Pro also has an specialized input designed for guitars, and XLR/Stereo outputs designed for live performances. Also, Pro can be used without external power supply, because Pro can be powered directly by iOS device/PC/MAC. With its 6 definable MIDI foot switches, expression pedals and third party effects software, XTONE Pro can satisfy all your imagination of tone. Put it on the table, it is also a studio-grade professional audio interface, meet your various needs for music production. ④XTONE Pro can also be used in professional-grade recordings. It offers built-in studio-grade microphone preamp、48V phantom power、hardware direct monitoring mode、clip indicator、MIDI IN/OUT jacks, and higher dynamic range and better sound quality than XTONE.⑤At present, the new generation of guitar effects software ,such as BIAS and ReValver , has been able to produce the same amazing tone as those of the hi-end hardware guitar processors. With XSPEED ultra-low latency technology + 6 definable foot switches + expression pedal input, in fact, XTONE Pro + High Quality Effects software = Hi end guitar processor.
Features & details
Specifically designed for guitar effects apps/VST plugins
192KHz Ultra-HD Audio/ 114db high dynamic range
XSPEED technology brings ultra-low latency
Expression pedal input & 6 definable midi foot switches
Support iOS, PC, Mac, and can be powered directly by them
Product information
Item Weight   2.2 pounds
Product Dimensions   7.7 x 4.8 x 2.4 inches
Supported Software   JamUp/BIAS AMP/BIAS FX/Guitar Rig/VocaLive/AmpKit/Amplitube etc.
Additional Information
ASIN: B07RJM4WVP
Best Sellers Rank: 37786
Shipping Weight: 2.2 pounds
Date First Available: April 30, 2019
HAMERMAN409
Big thumbs up for the full size USB port!
Quote from: HAMERMAN409 on May 08, 2019, 12:54:10 PM
Same on MeloAudio Tone Shifter Mega ( the micro USB Power jack (on far right) is not required when used with IOS /Android
https://ask.audio/articles/melo-audio-tone-shifter-mega-is-a-midi-pedal-controller-audio-interface-in-one
https://www.vguitarforums.com/smf/index.php?topic=17224.msg123091#msg123091
plexified
This is what I have been waiting for. Thanks for sharing this one !
XSONIC pro looks real promising.
http://www.xsonic.cc/xtonepro
plexified
Awesome stuff, that one flew by the radar. I'm just starting to look in this market and the terminology is new as well. Thanks so much for helping broaden the horizons  ;D
plexified
Quote from: plexified on September 03, 2019, 06:24:54 PM
A bit overstated clickbait youtube Headline ( typical of Phillip McKnight)
Its just a USB Class compliant audio /MIDI Interface  - similar to the MeloAudio Tone Shifter Mega
https://www.vguitarforums.com/smf/index.php?topic=17224.0
Xtone Pro USER MANUAL
https://www.showdoc.com.cn/XTONEProManual?page_id=3524560735271784
XTONE ASIO DRIVER
https://xsonicaudio.com/pages/xtonedriver
XTONE PRO SPECIFICATIONS
Input impedance: 1M ohms (INL); 100K ohms (INR)
Preamp gain range: 4 ~ 50dB
Unbalanced output impedance: 100 ohms
Balanced output impedance: 200 ohms
Frequency response: 10Hz ~ 21kHz
Sampling rate: 44.1k,48k,88.2k,96k,176.4k,192kHz
Sampling depth: 24bit
Dynamic Range: 114dB
THD+N: 0.001%
USB power input: 5V DC
Auxiliary power input: 9V DC
Power consumption: 100mA
Dimensions: 195mm(D) x 123(W) x 60mm(H)
Weight: 1000g
XTONE PRO vs MeloAudio ToneShifter Mega
https://forum.audiob.us/discussion/40115/xtone-pro-tone-shifter-mega
Tome Quayle at 12 minutes in explains the 3 Foot switch modes
Xtone Pro arrived, found a gently used example
Using wirh 2020 iPad Pro 12.9. USB-C (powered by iPad using included USB-C to USB 2.0 Host adapter ) - very clean, and good headroom,  (cleaner than MeloAudio ) and the three modes of the 6 footswitches (18 accessible) opens up great use as a live controller
GAIN is only for CH2 Mic input -still learning
