AMPERO - Battery Power
Started by admin, April 08, 2019, 01:59:05 PM
Ampero on battery power (19VDC)
PilotPro 32,000 mAH Battery pack
Another solution - use a USB-C PD Battery pack  - and this adapter to deliver 18VDC to the Ampero
USB 3.1 Type C USB-C to DC 20V Power Plug PD Emulator Trigger Charge Cable GL
https://www.ebay.com/itm/113677986333
SKU: CE1094
Features:
USB 3.1 Type C USB-C to DC 20V 5.5 2.5mm & 2.1mm Power Plug PD Dummy Emulator Charge Cable for Laptop
Build-in the PD Emulator Trigger at Type-C female end.
Input: Type-C Female, 65W or 87W Type-C Charger
Output:DC 5.5 2.5mm & 2.1mm male, DC 18v-20v(not support 5v)
Use it with the 65W or 87W Type-C Charger to conveniently charge your Laptop with DC5.5mm 18v-20v port from a wall outlet.
Please note the Type-C charger power must be over than the output end.
carlb
You had mentioned approximate run-time with the PilotPro - what can be expected, roughly?
Morningstar MC8 & MC6
QSC CP8 powered speaker
Quote from: carlb on April 12, 2019, 11:26:34 AM
I ran 4 hours and still had 50% power
Ampero will run longer than Gigboard on PilotPro battery (32,000mAh
