AMPERO - How to update Firmware
Started by admin, March 21, 2019, 06:00:43 AM
Hotone Ampero FW V3 Update Guide Book
https://www.hotoneaudio.com/uploads/190531/MP-100(Ampero)_V3.0 Firmware Update Guide_EN_V02_190531.pdf
Ampero FW V3 Update worked like a breeze!
(My computer is a Win 7 64 (Dell) and USB 2.0 ports )
1 ) Download all new Ampero files from Hotone
https://www.hotoneaudio.com/support/29.html
http://www.hotoneaudio.com/downloads/software/Ampero/MP-100%20%28Ampero%29_Firmware_English_V2.1_190312.zip
http://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Editor%20Setup%201.2.0%20for%20Windows.exe
http://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Editor%20Setup%201.2.0%20for%20Mac.pkg
2 ) Uninstall the old Ampero Editor V1.1.1 (use "Ampero Editor V1.1.1 "Uninstall" application which was preinstalled in same folder as the app)
3) Install Ampero Editor V1.2
4 ) With Ampero powered off - connect via USB to the computer
5 ) Run the Ampero Editor V1.2 app ( it will say "Device not Connected)
6 ) On Ampero , Hold down the "3" + "CTRL" footswitches + the Menu/Value Knob - and while holding all three down, power Ampero "ON"
7 ) Launch Ampero Editor V1.2 app ( it will say "Device Connected)
8 ) On Ampero Editor V1.2 app , Click "UPDATE"
9 On my Computer, it prompted me to find the drive location of my "MP-100 (Ampero)_Firmware_English_V3.0_190530.bin" file - I located it and selected it - the Firmware update procedure now started - with moving bar % status displayed on the Ampero Editor V1.2 app
10) After 90 seconds, the Ampero FW V3.0 update procedure completed - with the Ampero LCD screen going dark, and Ampero Editor V1.2 app indication "UPDATE COMPLETE"
11) On Ampero, turn the power "Off"
12) On Ampero, turn the power "ON" - and after the normal 12 second boot-up - I now have the Ampero running with FW 3.0, and connected to Ampero Editor V1.2 app  -all all working !
Very happy with Hotone's attention to responding to the Ampero community with this FW 3.0 update!
Ampero Firmware v3.1 and Editor v1.2.2 is now available.
Ampero FW Version 3.1
Released 7/12/2019
New Features
1. Wait Mode is now available when you use MIDI controllers to switch between banks
Improvements & Bug Fixes
1. Reduced the default volume of drum machine
2. Further optimized Tuner sensitivity
3. Shortened the fade in time when engaging compressor effects, this may cause a noticeable fade in progress when switching between patches
4. Tuning mode will now be automatically saved
5. Tuner cannot be engaged by sending CC 57 – FIXED
6. CTRL function may not work correctly when sending CC 72 – FIXED
7. Irregular output level may occur after importing some user presets – FIXED
8. Irregular on/off status display when using external footswitch to control drum play/stop – FIXED
9. The expression pedal range min/max values can still be set when unassigned - FIXED
Ampero Editor Release Note
Version 1.2.2
Released 7/12/2019
New Features
+ Firmware V3.1 support added
Version 1.2.1
Released 6/6/2019
Precaution
IMPORTANT - Use with V3.0 firmware ONLY. The new software will no longer recognize Ampero units with previous firmware (V2.1 and earlier).
The patches of the earlier firmware versions are now not compatible with this V3.0 firmware due to the new features and fatal changes, which means, after updating firmware, ALL YOUR PATCHES IN YOUR AMPERO WILL BE REPLACED BY THE NEW FACTORY/USER PATCHES, AND YOUR CUSTOM IR FILES WILL ALSO BE CLEARED.
Please be sure to export the patches you want to keep by using Ampero Editor V1.1.1 (with V2.1 firmware) before updating. After updating, you can import them via new Ampero Editor (The Editor will automatically convert your old patch files to new version so that you can use them with V3.0 firmware).
If you accidentally updated to the new firmware before backing up your patches, to get the old patches back, you can roll back to earlier firmware versions (load earlier firmware files when updating) before you edit/save patches with new firmware.
Bug Fixes
- Some effects in Effect List have no image – FIXED
- Device cannot be recognized when there is no internet connection – FIXED
- Ampero Editor may crash when loading some IR files with high sample rate – FIXED
- Wrong prompts when loading IR files – FIXED
Seems to be isolated to Windows 8.1 64 Pro users.
However,  Ampero Editor V1.2.2 works fine on Windows 7 64 Pro and MacOS
This FW update may  promote sales bigtime to the A=432Hz conspiracy crowd
"Tuner reference pitch range changed to 432Hz – 447Hz"
Version 3.2
Released 9/6/2019
New Features
- In Looper menu, you can now sync drum rhythm to your phrases when recording
- You can now control USB monitor level (Global > USB Audio)
- You can now toggle between two different display modes in Main Display screen (Global > Display)
Improvements, Changes & Bug Fixes
- Improved the sound quality of these compressor effects in FX1 and FX2: Comprosso, Comparoma 4 and Blue Sustainer
- Tuner reference pitch range changed to 432Hz – 447Hz
- In some cases, the unit may be muted when exiting tuner by sending CC 57 – FIXED
- Minor bug fixes
Ampero FW Update Giide
https://www.hotoneaudio.com/downloads/manual/Ampero/Ampero%20V3.x%20Firmware%20Update%20Guide%20EN.pdf
New FW 3.2 Manual
https://www.hotoneaudio.com/downloads/manual/Ampero/Ampero%20Online%C2%A0Manual%20EN%20V06.pdf
