Steinberg AXR 4T recording and playback of 32 bit / 384 kHz file.
Started by admin, March 04, 2019, 09:12:02 AM
Steinberg The next generation flagship audio interface "AXR 4T" which realizes the ultimate A / D, D / A conversion, 32 bit integer 384 kHz file recording and playback appeared!
Has AES/EBU and ADAT I/O
Manual
http://download.steinberg.net/downloads_hardware/AXR4/Manuals/AXR4T_Operation_Manual_en.pdf
◆ Steinberg
AXR 4T (※ Thunerbolt cable optional)
Sales price ¥ 250,000 (excluding tax)
Shopping page is here >>
Ultimate A / D, D / A conversion, 32 bit INTEGER / 384 kHz
Ahead of the world, next generation flagship machine Steinberg AXR 4T realized recording and playback of 32 bit / 384 kHz file.
■ AXR 4T Main Features
1. Up to 32 bits / 384 kHz Recording playable
In order to realize high sound quality with digital audio, A / D, D / A conversion is an important process. As a result of a careful selection of parts and repeated research aiming at ultimate A / D and D / A conversion, I came to the current specification including 32 bit integer converters. As a result, the AXR 4T became the interface which can record and reproduce the high resolution audio signal most accurately and cleanly.
A sampling rate of up to 384 kHz allows you to set the anti-aliasing filter frequency much higher than the audible band, reproducing transients, stereo images, and recording environments in more detail.
2. Hybrid microphone preamplifier that captures performance faithfully and more attractively
The four hybrid microphone preamplifiers equipped at the front are made up of an analog section that records the sound as it is and a digital section that realizes a musical and airy sound.
Under the Yamaha philosophy "pursuit of natural sound", the analog section carefully examines the important elements of the analog circuit such as mechanical structure, circuit layout, selection of power supply, ground and parts, carefully examining and repeating measurement and verification, Ultimately, we thoroughly evaluated it with internal and external engineers and adjusted the sound.
The digital division accurately models Rupert Neve Designs' transformers and SILK processing using Yamaha's proprietary modeling technology VCM technology and adds musical depth and texture to the sound. There are two modes of SILK, the BLUE mode emphasizes the mid-low range, and the RED mode emphasizes the harmonic overtones of the mid-high range.
3. Built-in latency-free system 28 x 24 matrix mixer installed
Yamaha's custom-made DSPX chip allows you to build a latency-free system using a 28 x 24 matrix mixer, such as routing input signals and DAW outputs to a mix bus.
With the dspMixFx AXR application installed on the Mac you can control all the settings in a window such as a mixer, matrix mixer, meter, etc., and always be able to grasp the level and routing situation. These settings can be saved as a scene and can be called freely later.
4. Four premium DSP effects built in
The AXR 4T has four premium DSP effects.
EQ 601 has reproduced the popular equalizer since the 1970s and has its unique distortion characteristics. Compressor 276 reproduces the analog style compressor often used in the recording studio. Reverb's REV-X provides smooth attenuation, spreading, depth, high density and rich reverberation. And Sweet Spot Morphing Channel Strip can easily obtain optimum setting of side chain compatible compressor and 3 band parametric equalizer using morphing function. The VST software version of all these plugins is also included.
5. 32 bit integer compatible Cubase AI included
AXR 4T is compatible with all audio editing, mastering, and music production software supporting the Core Audio standard.
Cubase AI included with AXR 4T can record and play back with 32 bit integer (maximum 192 kHz), so you can maximize the possibilities of AXR 4 T. You can also operate AXR 4T directly from Cubase.
■ AXR 4T main standard
Microphone / line input 1 to 4 (balance)
· Frequency response + 0.1 / - 0.1
dB, 10 Hz to 22 kHz @ 48 kHz
+ 0.1 / - 0.2 dB, 10 Hz to 44 kHz @ 96 kHz
+ 0.1 / - 0.5
dB, 10 Hz to 88 kHz @ 192 kHz + 0.1 / -3 dB, 10 Hz to 100 kHz @ 384 kHz
· Dynamic range 119 dB, A-Weighted
· THD + N 0.0004%, 1 kHz, 22 Hz / 20 kHz BPF
· Maximum input level
+24 dBu
· Input impedance 3.3 kOhm · GAIN range + 15 dB - + 68
dB · Pad - 20 dB
HI - Z input 1, 2 (unbalanced)
· Maximum input level + 10 dBV
· Input impedance 1 MOhm
dB · Pad - 20 dB
Line input 5 to 12 (balance)
+ 0.1 / - 0.5
dB, 10 Hz to 88 kHz @ 192 kHz + 0.1 / -3 dB, 10 Hz to 130 kHz @ 384 kHz
· THD + N 0.0006%, 1 kHz, 22 Hz / 20 kHz BPF
+24 dBu · Input impedance 20 kOhm
· Input level selection
+4 dBu (20 dBHeadroom), +4 dBu (14 dBHeadroom), - 10 dBV Selectable
Line output 1 to 8 (balance)
And frequency characteristics
Tasu 0.1 / -0.1DB, 10 Hz To 21KHz Atto 48KHz
Tasu 0.1 / -0.3DB, 10 Hz To 43KHz Atto 96KHz
Tasu 0.1 / -1DB, 10 Hz To 83KHz Atto 192KHz
Tasu 0.1 / -3DB, 10 Hz To 120KHz Atto 384KHz
- Dynamic range 117 dB, A-Weighted
· THD + N 0.0006%, 1 kHz, 22 Hz / 22 kHz BPF
· Maximum output level +18 dBu
· Output impedance 75 Ohm
Digital AI / O interface
· ADAT ADAT, Optical, 24-bit
· S / PDIF IEC-60958, Optical, 24-bit
Digital BI / O interface
· AES / EBU AES / EBU Professional use, RS 422, 24-bit
Headphones
· Maximum output level 75 mW + 75 mW, 40 Ohm
Thunderbolt
· Specification Thunderbolt 2, 32-bit, 44.1 kHz / 48 kHz / 88.2 kHz / 96 kHz / 176.4 kHz / 192 kHz / 352.8 kHz / 384 kHz
MIDI
· MIDI input / output DIN 5 pin
WORDCLOCK
· WORDCLOCK input / output TTL / 75 ohms
XLR input
· Polarity 1: Ground, 2: Hot (+), 3: Cold (-)[/i]
