AMPERO - EDITOR
Started by admin, February 27, 2019, 08:04:35 PM
At 1st launch  a Help screen is shown
Footswitch Settings - TAP targets
Footswitch Settings - HOLD targets
Footswitch Settings 3+4 - TAP (same target choices for other two footswitch combos )
CTRL/EXP
A Current Settings screen shows a summary of all user control assignments per patch
The CTRL setting  you can control several FX Targets
EXPRESSION 1  - the Volume pedal "curve can be user selected (Linear, Exponential, Logarithmic) curves
EXPRESSION PEDALS can target four FX Parameters   - therefore many old school Boss GT Expression Pedal morphing tricks also work with AMPERO !
and the three Knobs under LCD can be configured as "Quick Access Knobs" to control specific parameters unique per patch
carlb
Are control/expression assignments possible via the onboard user interface, or just via the offboard editor?
Morningstar MC8 & MC6
QSC CP8 powered speaker
Quote from: carlb on May 02, 2019, 04:35:32 AM
Either works ,
Watch the tutorial videos that demonstrate either onboard ecpression setup or mac/ win GUI editor
Below is how to program Expression pedal right on the unit
https://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Editor%20Setup%201.2.1%20for%20Windows.zip
https://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Editor%20Setup%201.2.1%20for%20Mac.zip
Bug Fixes
- Some effects in Effect List have no image – FIXED
- Device cannot be recognized when there is no internet connection – FIXED
- Ampero Editor may crash when loading some IR files with high sample rate – FIXED
- Wrong prompts when loading IR files – FIXED"
https://www.hotoneaudio.com/products/multi-effects/ampero#downloads
Ampero Editor Release Note
Version 1.2.5
Released 10/18/2019
Bug Fixes
1.   When importing all patches, the patch file (containing all patches) cannot be recognized if it contains a patch using 3rd party IR - FIXED
Version 1.2.4
Released 9/12/2019
Bug Fixes
1.   Fixed not working parameters in EQ module
Version 1.2.3
Released 9/6/2019
New Features
1.   Firmware V3.2 support added
2.   Limited pink edition support added
3.   Window sizing support added (can be set to 1.2x)
4.   You can now set monitor level in Global > General Settings
Version 1.2.2
Released 7/12/2019
New Features
1.   Firmware V3.1 support added
Version 1.2.1
Released 6/6/2019
Precaution
IMPORTANT - Use with V3.0 firmware ONLY. The new software will no longer recognize Ampero units with previous firmware (V2.1 and earlier).
The patches of the earlier firmware versions are now not compatible with this V3.0 firmware due to the new features and fatal changes, which means, after updating firmware, ALL YOUR PATCHES IN YOUR AMPERO WILL BE REPLACED BY THE NEW FACTORY/USER PATCHES, AND YOUR CUSTOM IR FILES WILL ALSO BE CLEARED.
Please be sure to export the patches you want to keep by using Ampero Editor V1.1.1 (with V2.1 firmware) before updating. After updating, you can import them via new Ampero Editor (The Editor will automatically convert your old patch files to new version so that you can use them with V3.0 firmware).
If you accidentally updated to the new firmware before backing up your patches, to get the old patches back, you can roll back to earlier firmware versions (load earlier firmware files when updating) before you edit/save patches with new firmware.
Bug Fixes
1.   Some effects in Effect List have no image – FIXED
2.   Device cannot be recognized when there is no internet connection – FIXED
3.   Ampero Editor may crash when loading some IR files with high sample rate – FIXED
4.   Wrong prompts when loading IR files – FIXED
Version 1.2.0
Released 5/31/2019
Precaution
IMPORTANT - Use V3.0 firmware with Ampero Editor V1.2.0 ONLY. The new software will no longer recognize Ampero units with previous firmware (V2.1 and earlier).
Please be sure to export the patches you want to keep by using earlier Ampero Editor software before updating. After updating, you can import them via new Ampero Editor (The Editor will automatically convert your old patch files to new version so that you can use them with V3.0 firmware).
New Features
1.   You can now manage your signal chain by clicking "Manage Signal Chain" button
2.   You can now import user IR file with any bit depth/sample rate
3.   You can now set No Cab Mode in Settings > Global
4.   You can now check solution methods by clicking "Device Not Found" button when Ampero Editor cannot recognize your device
5.   EXP 2/FS settings added in Settings > Global
Improvements & Bug Fixes
2.   Some effects in Effect List have wrong images – FIXED
3.   Optimized USB communication stability between computer and Ampero unit
Version 1.1.1
Released 3/14/2019
Precaution
In this software update, we changed USB communication methods between Ampero and your PC/Mac, which means, the new software will no longer recognize Ampero units with previous firmware (B6.4 and earlier). PLEASE UPDATE YOUR AMPERO TO THE LATEST FIRMWARE FIRST before using the new software.
Bug Fixes
1.   Ampero Editor crashes when importing presets containing user IR files – FIXED
Version 1.1.0
Released 3/12/2019
Precaution
In this software update, we changed USB communication methods between Ampero and your PC/Mac, which means, the new software will no longer recognize Ampero units with old firmware. PLEASE UPDATE YOUR AMPERO TO THE LATEST FIRMWARE FIRST before using the new software.
Bug Fixes
1.   In some cases, presets cannot be correctly imported/exported – FIXED
2.   Quick Access Knobs, EXP 1 & EXP 2 settings cannot be correctly read in CTRL menu – FIXED
Version 1.0.2
Released 2/14/2019
1.   Quick start tips added at the first launch
2.   Effect description mistakes – FIXED
3.   Ampero Editor cannot get correct information from Ampero unit after factory resetting - FIXED
4.   Sync selections display error – FIXED
5.   Language selections aren't working properly (Windows) – FIXED
Version 1.0.0
Released 1/25/2019
Initial Release
