One FC300 to a VG99 and VB99
Started by ericar123, January 30, 2019, 03:47:18 PM
ericar123
Hi
I notice some manual rotary switches online and need to know if I need RJ12 or RJ45 connectors to connect with?
If you want to control two both VG-99 and VB99 from the FC-300, I would connect one of the devices through RRC2 and one through Midi. You can change modes on the FC-300 with an external footswitch.
You will only see patchnames and effect states for the device connected through RRC2.
ericar123
I would prefer a switch. I only use one device at a time. I just wanted to confirm that the plugs used are rj45.
These are the switches I am thinking of. I would switch the fc300 before turning on the VG unit so I don't screw something up.
https://www.bestbuy.ca/en-ca/product/4-port-rj45-switch/13213469.aspx?
https://www.newegg.ca/Product/Product.aspx?Item=9SIAHBM7P61640&Description=rj45%20switch&cm_re=rj45_switch-_-9SIAHBM7P61640-_-Product
RJ45 switch box should work
either link above
ericar123
ericar123
I did end up buying this one and it works great. Now I have full control of either unit with the push of a button.
https://www.amazon.ca/dp/B01I2PY0AA/ref=pe_3034960_236394800_TE_dp_1
