Pedalboard Mixer
Started by Nebooaw, January 13, 2019, 10:15:33 AM
nervoteso
i'm about to buy this mixer (used like new, 80 euro):
zed6 fx from allen and heat, what do you think?
Quote from: nervoteso on February 21, 2020, 03:54:43 AM
Those are very good and very capable - (but too large for my pedal board )
But only 2 mono, 2 stereo inputs
All depends on your needs and real estate
Meanwhile this one supports 8 inputs- as four Stereo TRS Inputs.
STEREO CHANNEL
The audio mixer 4 channel has four 1/4 TRS inputs along with an 1/4 TRS output, the channels are stereo not mono.
FLEXIBILITY CONTROL
Four volume knobs of stereo mixer led on the front panel to adjust each input level.
https://www.amazon.com/FIFINE-Low-Noise-Sub-Mixing-adapter-Ideal-Microphones/dp/B07QDN6Z83
nervoteso
#53
git the zed mixer, but i listen to better quality if i plug sy1000 durectly to ik monitors. if i use stereo inputs if zed quality is not the same. akso i really don't kniw how to use trio plus without having effecrs in the drums. i want effected signaks fir recirding in the trio but clean drums.
i would like to use sy1000 outputs not trio outputs
Quote from: nervoteso on February 21, 2020, 09:54:28 AM
Welcome the the concept of Audio insertion loss - very common  when assembling lots of gear
https://www.fantech.com.au/images/PDF/Catalogue/NoiseInfo.pdf
https://www.jm.com/en/blog/2016/october/acoustical-control-understanding-insertion-loss-part-1/
nervoteso
ok solved. guitar to boss ve2 to sy100 guitar in. main outputs sy100 directly to mixer stereo in, then suboutputs sy100 to trio input and mixer trio outputs to mono mixer inputs.
THE GIGRIG ELEVATES PARALLEL EFFECTS MIXING WITH WETTER BOX
Blend two effects in parallel for new, interesting tones.
by Daniel Ong
TheGigRig Wetter Box
TheGigRig has launched Wetter Box, a compact parallel mixing tool that allows you to blend two effects pedals to your signal chain.
It's based on the brand's 2006 Wet Box, which worked similarly but on a much simpler scale. The Wetter Box expands on its predecessor's design, allowing you to blend effects within your pedalboard, amp effects loop or recording signal chain.
In operation, you connect effects to the device via mono or stereo and blend them with a central knob. There are two main modes of operation: Blend and Mix. According to the brand, Blend "crossfades loop A with B", while Mix "adds loop B to Loop A". In addition to the central control, there are also dedicated gain controls for each of the two loops, and a phase switch for the return of Loop B to mitigate phase issues.
On top of creating some new and intriguing sounds, the device also serves as an analogue dry through when using digital effects and amp effects loops. This allows you to blend your effects over your core sound, rather than eliminate it – handy for getting your effects blend levels just the way you want it.
The Wetter Box can also be used with an expression pedal or remote footswitch, if you so choose.
Check out the Wetter Box in action
https://shop.thegigrig.com/wetter-box/
https://www.premierguitar.com/articles/19551-builder-profile-xact-tone-solutions-oct-13
https://musicplayers.com/2011/06/rjm-music-technology-mini-line-mixer/
https://www.rig-talk.com/forum/viewtopic.php?f=3&t=65336
https://www.lordriffenstein.com/?page_id=538
Mini Line Mixer
MINI LINE MIXER is a Line mixer designer especially for guitar systems. Now you can easily mix signal  from your amplifier with line signals coming from effects processors. The result? A fundamentally lower noise ratio and overall, non-digitalized warm, analog sound. Additionally, its small size and flexibility make it useful for small keyboard systems or anywhere, where a small mixer is needed.
Many people think over  about how to force their guitar systems to sound like John Petrucci  or The Edge.. However, not many know how their advanced  control systems look like. We would therefore like to get you a  step closer to the world's top. One of our line mixers, which you may find in our product line will definitely help you achieving better level in your sound quality.
This device converts a serial signal into a parallel signal thanks to which we can mix-in effects (delay, reverb, chorus, flanger, etc.) to a base signal undistorted by digital processing. This idea comes from recording studios worldwide, where a base signal is mixed with effects from consoles, thanks to which it does not lose clarity while gaining 'spaciousness'. If you want your guitar parts to never get lost in the mix, to be spacious and breathable and, most of all, if you do not want to distort your signal with additional noise this is a device you've been looking for.
CONTROLS:
FX MIX – Adjustable control of both effect units connected to the MINI MIX. This control determines how much effect you want to blend with the original dry sound.
MASTER – Adjustable control of the summed output of the MINI MIX. Unity gain amplification is achieved when the control is set around 11 o'clock.
CONNECTIONS:
INPUT – Low impedance input (send from amplifier loops effects or guitar output),
OUTPUT – Low impedance main output (return from amplifier loops effects or input amplifier),
SEND 1 – Buffered mirror image signal of the main input. (processor input),
RETURN 1 – Low impedance input from the output of your 1st effect,
SEND 2 – Buffered image signal of the MIX 1 Out. (processor input),
RETURN 2 – Low impedance input from the output of your 2nd effect.
Power input – 9VAC /150mA 5.5×2.1mm barrel connectors center negative.
Warranty 2 years
TECHNICAL SPECIFICATION:
Power In: Power supply socket for AC 9VAC/100mA, Plug 2,1 mm x 5,5 mm
Operational temperature: -15C / +50 oC
Height: 35 mm
Width: 90 mm
Length: 60 mm
Weight: 0,5 kg / 1 pounds
Share
Blender V3
Blender V3
larger image
Starting at: $245.00
Please Choose:
Silent switch relay - no battery possible
Silent switch true bypass relayYes ( +$20.00 )
1
The Blender V3 is a parallel effects loop blender with 3 individually selectable effects loops. The instrument signal is split into 3 channels, sent to the 3 effects loops and then mixed back together.
Effects Loop A defaults to a clean channel if no effects pedal is plugged into the return jack of loop A. Effects Loop A also has bass and treble tone controls which come after the effects loop.
B>C toggle switch: Change channels B and C from parallel into a series configuration where the return from effects loop B is sent to the send of effects loop C.
Effects loops B and C also have phase switches to match the phase of the different channels to avoid signal loss.
The Blender V3 also has the ability to change the bypass settings for each effects loop. When the individual effects loop is turned off a toggle switch allows you to select what gets sent from that effects loop to the Blender's output: either the return of the pedal in the effects loop (to allow trails of delay type pedals to continue), a clean instrument signal, or nothing (muted). One major advantage of this set up is to allow the total signal level sent to the final output of the Blender V3 to remain constant when the various effects loops are bypassed but also allow massive flexibility in shaping your sound and changing it on the fly.
Instruction Manual pdf
True bypass stomp switch to turn the entire unit on/off.
Heavy duty 7.4" x 4.7" x 1.3" Hammond aluminum enclosure
Can use DC adaptors from 9 to 18 volts, with a tip negative jack. Standard pedal adaptors like Boss PSA, Godlyke Powerall, Onespot. No battery option.
Current draw: 205mA
Input impedance: 500kΩ
Output impedance: 150Ω (at 1KHz)
https://www.woundedpawaudio.ca/fx/docs/BlenderV3i-manual.pdf
https://www.woundedpawaudio.ca/fx/index.php
Decibel Eleven Pedal Palette Analog Loop Bypass Switcher/Router/Mixer
item# 1378221677273
https://decibel11.com/product/pedal-palette/
Do you want to delay your distorted signal and then distort your delayed signal? Totally doable. The Pedal Palette is the first and only analog loop bypass switcher, router, and mixer capable of swapping effect pedals instantly while simultaneously providing a parallel mix bus. The routing and order of the effects is highly flexible and programmable offering unlimited options to create inspirational new sounds from existing pedals.
https://decibel11.com/pdf/support/Pedal_Palette_Manual_02.pdf
nervoteso
quite satisfied of this zed6fx, very clear sound. i can say this sy1000 is incredible, never listened to such kind of magic in the sound, i am really impressed
https://www.amazon.com/gp/product/B08P35NKX8/ref=crt_ewc_title_huc_1?ie=UTF8&psc=1&smid=A1PZPD3QI86H0M
[Multiple Input Ports and Independent Control] ★DEL-8i2 has four stereo channels, is compatible with 8 mono signal inputs, and can collect sounds from many different sources (microphone, guitar, bass and keyboard) into one Monitoring position. Each channel on the linear mixer has an independent input plug and volume control. You can set "Input 5/6" and "7/8" as stereo or mono input.
[Ground/Floating Signals Functions] ★In addition to mixing signals from multiple devices, DEL-8i2 also has stereo/mono, ground/floating signals, which can process input signals to minimize noise, which are not available in similar products on the market. The grounding/floating function supports "1/2" and "3/4" input.
[High-fidelity Four-channel Signal]★DEL-8i2 uses a chip specially designed for audio processing. The 4-channel mixer can produce the highest signal quality and highest signal integrity even at the highest level, without distortion and easy to set up, suitable for fast mixing of 4-line level signals without complexity.
[Double Output Ports] ★The linear mixer is compatible with multiple output modes, and two output ports are set. In addition to the normal left/right channel output stereo, there is also an interface for stereo output. You can also insert a sound card/monitor headphones to meet various creative needs.
[Complete accessories] ★The green indicator light is on, indicating that the product is working normally. The stereo mixer adopts a heavy metal shell structure, with firm knob adjustment, compact and convenient appearance. The product comes with two 3.5mm to 6.35mm adapters and power adapters, which can perfectly solve power problems.
quad4
How's the headphone amp?  Can it drive 300 ohms high sensitivity cans?
Quote from: admin on April 27, 2021, 03:02:31 PM
