GT-1000 - Jims_Boutique (TSL+ Cab IR wav)
Started by admin, July 11, 2018, 11:59:27 AM
https://www.thegearpage.net/board/index.php?posts/26767994/
Jim Roseberry wrote>
Here's a patch I programmed using the Boutique model (wanted to upload this earlier but left for vacation).
www.studiocat.com/temp/Jims_Boutique.zip
****You'll need Boss Tone Studio and the IR loading programs****
I've included the MESA 4x12 Cab IR that I used.
Make sure to load the "SM57 2_ctr" IR into the GT-1000
Set the Master Output block's cab to "SM57 2_ctr".
Try the Amp Block's built-in Solo boost (I've got Switch-3 assigned to Solo boost on/off).
DS1 is set as a clean-boost (a little fuller sounding than the amp block's built-in solo boost).
CTL1 switches between the Boutique Amp (path 1) and an Acoustic Sim (path 2). The Acoustic Sim will need to be tweaked for the specific guitar/pickups.
CTL2 is assigned to the Master Delay.
The FX1 block is set to a Phasor.
roachone
My Gt1000 should be here this week I'll give it a go. Thanks
roachone
