ios live setup
Started by uwekvguitarforums, July 10, 2018, 12:19:33 AM
uwekvguitarforums
Will this setup work on live setting? Am I missing something on the chain? the only one I don't have is the audio interface. Which is better? AVID fast track solo or Irig HD?
Thanks and Regards! :) :) :) :)
Idgolfguy
Don't believe the pedal will work via midi to USB into the IPad.
Depends on whether the Yamaha is class compliant.
Even then it may be hot and miss.
IK Multimedia iRig HD is  USB Class Compliant  - so will work with iPad
Get a decent  USB Class Compliant USB <> MIDI Adapter ( Roland UM-ONE MKII )
Avoid the USB <> MIDI Adapter seen in your diagram
Rhcole
Aww, man, don't take the headphone jack out into an amp. Many apps won't even work with that anymore.
Use something like the Zoom U-24. It works well, it's a hundred bucks. Got MIDI, got phantom, got guitar in, you're done.
BackDAWman
Focusrite iTrack dock makes it easy. Audio in and out(stereo) and real midi. 24bit as well. I used to use it with Bias FX.
uwekvguitarforums
#5
Thanks for your reply guys.. but.. i already got it working and im using m-audio fast track as an audio interface. it sounded very good with a headphone.
question. for live setting can i use the headphone output going to guitar amp? or should i use the left/right RCA out? do i still need a di box?
thanks all for your help.
cheers. :)
uwekvguitarforums
Hi RHCOLE can you show me your setup? Thanks
