GT-1000 - Q & A
Started by admin, May 14, 2018, 11:00:41 AM
Translate this page of Boss GT-100 Q& A from Japanese to English
http://faq-jp.roland.com/category/search?utf8=%E2%9C%93&keyword=GT-1000&commit=
Translated this page of Boss GT-1000 Q & A from Japanese to English
http://faq-jp.roland.com/category/search?utf8=✓&keyword=GT-1000&commit=
1【GT-1000】Q. Can I assign various functions to the EXP pedals on the top panel of the main unit or each switch?
ANSWER
Is possible.
For the setting method, please refer to "Operation manual P.12" Foot switch, expression pedal setting ".
* Parameters that can be assigned can be confirmed with the parameter guide P.26 "CONTROL ASSIGN".
http://faq-jp.roland.com/faq/show/87834?category_id=9742
2【GT-1000】Q. Can I play while listening to music from smartphone or PC using Bluetooth function?
ANSWER
can not.
With the Bluetooth function of GT - 1000, you can edit and manage sounds wirelessly from "BOSS Tone Studio", a dedicated editor application compatible with iOS / Android.
http://faq-jp.roland.com/faq/show/87842?category_id=9742
3【GT-1000】Q. Is there a way to play while listening to an external sound source while playing?
ANSWER
It is possible to connect the GT - 1000 to the PC via USB and select "GT - 1000 MAIN" on the output device of the playback software.
http://faq-jp.roland.com/faq/show/87841?category_id=9742
4【GT-1000】 Q. The effect is applied to the signal sent from the PC, but what should I do to avoid it?
ANSWER
To prevent effects of the GT-1000 during playback, select "GT-1000 MAIN" ("3-4 GT-1000" for mac) as the playback device.
When "GT - 1000 DRY" ("1-2 GT - 1000 in the case of mac") is selected as the playback device, the signal is sent to the beginning of the effect chain, so output with the effect of GT - 1000 It will be.
~ Reference
The GT - 1000 's USB driver has three ports, each with a different signal flow.
【GT-1000 DRY / 1-2 GT-1000】
You can apply GT - 1000 's effect to the signal sent from the PC and play it.
【GT-1000 MAIN / 3-4 GT-1000】
You can play back the signal sent from the PC without applying the GT - 1000 's effect.
【GT-1000 SUB / 5-6 GT-1000】
You can play back the signal sent from your computer from the device connected to the SUB OUTPUT jack of GT - 1000.
http://faq-jp.roland.com/faq/show/87840?category_id=9742
5【GT-1000】Q. How can I record an effected sound on the DAW?
ANSWER
Please select "GT - 1000 MAIN" ("3-4 GT - 1000 in case of mac") on DAW input device.
~ Reference
The GT-1000's USB driver has a different signal flow.
While monitoring the GT - 1000 's effect sound, you can actually send only dry sound to the DAW without applying any effects.
This effect can be applied directly to the sound of the guitar connected to the GT - 1000 and recorded to the DAW, and it is used when you apply the effect.
By using these two ports separately, you can also use the opposite way to send the recorded tracks to the GT - 1000 to the DAW and apply the effect of the GT - 1000 back to the DAW.
Specifically, for tracks that you do not want to apply an effect to, select "GT - 1000 DRY" and select the "GT - 1000 MAIN" for the track you want to apply the effect, while monitoring with the GT - 1000 main unit You can leave the DAW track's dry sound and the other you can apply the GT - 1000 's effect.
http://faq-jp.roland.com/faq/show/87838?category_id=9742
6【GT-1000】 Q. Can I use multiple wah-wahs (WAH) simultaneously?
ANSWER
The GT - 1000 has multiple effects that have a wah effect.
We will inform you about the outline of each and whether it can be used simultaneously.
【WAH】
Control the wah effect in real time by operating the main unit or external expression pedal.
Available blocks are "PEDAL FX", which can not be used simultaneously.
【AUTO WAH】
You can obtain a wah effect automatically by periodically changing the filter.
Available blocks are "FX 1 to FX 3", and you can use up to three blocks.
【TOUCH WAH】
You can obtain a wah effect by changing the filter according to the volume of the guitar.
http://faq-jp.roland.com/faq/show/87837?category_id=9742
7【GT-1000】 Q. What is the number of effects that can be used with one patch?
ANSWER
The blocks that can be used with the GT-1000 patch and its number are as follows.
COMPRESSOR    × 1
DISTORTION    × 2
AIRD PREAMP   × 2
NOISE SUPPRESSOR   × 2
EQUALIZER   × 4
DELAY   × 4
MASTER DELAY   × 1
CHORUS   × 1
FX   × 3
REVERB   × 1
PEDAL FX   × 1
FOOT VOLUME   × 1
SEND / RETURN   × 2
LOOPER   × 1
Regarding the number of simultaneous use of effects, the number of the above blocks is the maximum.
For categories with multiple blocks, such as DISTORTION and FX, you can select the effect type for each block.
For example, for DISTORTION 1 and 2, you can select the effect type and assign the same effect type.
For details of the effect types and parameters that can be set for each block, refer to Parameter Guide P.5 - 25.
http://faq-jp.roland.com/faq/show/87836?category_id=9742
8【GT-1000】Q. Even if you press the expression pedal, the indicator of the EXP SW will not light up.
ANSWER
Please put your weight on your toes and depress it steadily.
If necessary, check the pedal calibration procedure.
* For details, please refer to the instruction manual P.13 "Adjusting the expression pedal (pedal calibration)".
http://faq-jp.roland.com/faq/show/87835?category_id=9742
9【GT-1000】 Q. Can I assign various functions to EXP pedal, CTL pedal, etc.?
ANSWER
With the GT - 1000, you can easily set the desired parameters for the EXP pedal and all foot switches with "CONTROL FUNCTION".
Also, if you want to set more detailed parameters, you can easily set your favorite parameters from the effect edit screen using "Quick Assign".
* Each function of each switch and pedal can be set for each patch, and up to 16 types of each patch can be set at the same time.
* For details, please refer to the  GT-1000 Owner's Manual "Foot Switch, Expression Pedal Setting" and GT-1000 Parameter Guide .
For your convenience, we will show how to set ON / OFF switching of "DS 1" to EXP 1 SW with "CONTROL FUNCTION" as an example.
● How to assign ON / OFF of "DS1" to the EXP1 SW of the GT-1000 main unit 【CONTROL FUNCTION】
* In the following, under "CONTROL FUNCTION", set ON / OFF switching of "DS1" to EXP1 SW I will introduce the method.
1.   Select a patch.
※ This time we will use P10-3 "OVERTONES".
2.   In "CONTROL FUNCTION", set ON / OFF of "DS1" to EXP1 SW.
1) Press the [MENU] button and press the [1 (CONTROL ASSIGN)] knob to enter the CONTROL ASSIGN screen.
2) Press the [1 (CONTROL FUNCTION)] knob to enter the CONTROL FUNCTION screen.
3) Press the PAGE [>] button to switch the page and display "EXP 1 SW".
4) Make sure "FUNCTION" of "EXP 1 SW" is selected.
     * If it is not selected, turn the [1 (SELECT)] knob to select it.
5) Turn the 2 (VALUE) knob to select "DS1" .
     * It is also possible to select from the list display by pressing the [2 (VALUE)] knob.
3.   Press EXP 1 SW (press down strongly on the toe portion of the EXP pedal) and check whether "DS 1" can be turned ON / OFF.
If you wish to set further stepped parameters, you can set it using "quick assign".
For your information, I will show you how to set the value of "DRIVE" of DS 1 to EXP 1 pedal by "quick assign" as an example.
● How to set the "DRIVE" value of "DS1" to the EXP pedal of the GT-1000 main unit 【Quick Assign】
1.   Select a patch.
2.   In "Quick Assign", set the value of "DRIVE" of DS1 to the EXP1 pedal.
1) Press the [EFFECT] button to enter the effect edit mode.
2) Turn the [6 (SELECT)] knob to select "DS1" .
3) Turn the [1 (TYPE)] knob to set the effect type to "OD - 1" .
4) Press and hold [2 (DRIVE)] knob to open the ASSIGNE MATRIX screen.
     * In this example, hold down the [2 (DRIVE)] knob to control the value of DRIVE, but long press the knob where the parameter you want to control is set.
     * Switchable TAEGET can be switched with the PAGE [<] / [>] button.
5) Press the [1 (ON / OFF)] knob to set the corresponding parameter to "ON" .
6) Turn the 5 (VALUE) knob to set SOURCE to "EXP1" .
7) Turn the [6 (VALUE)] knob to set MODE to "MOMENT" .
     * For MODE setting, select MOMENT when changing the value intermittently, select "TOGGLE" to switch ON / OFF each time you operate. In this time, to make DRIVE smoothly variable, I will make it MOMENT.
3.   In addition, you set the necessary parameters according to your preference as follows.
TARGET   DIST 1 DRIVE
MIN (minimum value of variable value)   20
MAX (maximum value of variable value)   100
4.
* Adjust the values of MIN and MAX according to your preference.
SOURCE   EXP1
MODE   MOMENT
ACT LO (minimum value of SOURCE movable range)   0
ACT HI (maximum value of SOURCE movable range)   127
5.
* When "TOGGLE" is selected in MODE setting, please set to "ACT LO: 0", "ACT HI: 127".
6.   If necessary, set the FUNCTION setting of the EXP 1 pedal to OFF.
* By default, the FV / PEDAL FX function is assigned to the EXP 1 pedal. If you want the effect of only DS1 DRIVE with the EXP1 pedal, turn OFF the FUNCTION of EXP1 PEDAL with CONTROL FUNCTION.
3) Press the PAGE [>] button to switch the page and display "EXP1 PEDAL".
4) Turn the [1 (SELECT)] knob to select "EXP1 PEDAL" "FUNCTION".
5) Turn the [2 (VALUE)] knob to select "OFF" .
7.   Move the EXP pedal of the GT - 1000 main unit and confirm that the value of "DRIVE" of DS 1 changes.
8.   Save the patch.
1) When the desired operation is achieved, press [WRITE] to display the patch / light screen.
2) Select the destination patch number and press [WRITE] to save the patch.
The setup procedure is over.
http://faq-jp.roland.com/faq/show/87843?category_id=9742
10【GT-1000】Q. Please tell us which foot switch or expression pedal can be used.
ANSWER
You can use the following products.
Foot switch: FS-5U / FS-5L , FS-6 , FS-7
Expression pedal: EV - 30 , FV - 500 H / FV - 500 L , EV - 5
※ We can not guarantee the operation regarding other company made foot switch etc.
http://faq-jp.roland.com/faq/show/87833?category_id=9742
11【GT-1000】Q. Please tell me the difference from GT-100.
ANSWER
Please see the comparison table here .
http://faq-jp.roland.com/usr/file/attachment/GT-1000_hikaku.pdf
http://faq-jp.roland.com/faq/show/87832?category_id=9742
12【GT-1000】Q. When connecting the GT-1000 to the input of the guitar amp, how can I set the tone of the amplifier side?
ANSWER
In order to maximize the effect of AIRD, please set the amplifier to be connected to be as clean as possible and flat frequency characteristics.
* On the GT - 1000 side, please select the AIRD OUTPUT SELECT setting suitable for the amp to be connected.
http://faq-jp.roland.com/faq/show/87829?category_id=9742
13【GT-1000】Q. Can I use the patch created by GT-100 directly with the GT-1000? Is there compatibility?
ANSWER
Since the effect engine itself differs between GT-100 and GT-1000, both patches are not compatible and can not be used as they are.
http://faq-jp.roland.com/faq/show/87828?category_id=9742
14【GT-1000】Q. Although the RETURN input impedance of the GT-1000 is high impedance as 1 MΩ, is it OK if you connect the effect amplifier of the owned low impedance output?
ANSWER
Some products connected to the RETURN of the GT - 1000 have output high impedance, and are designed to 1 MΩ intentionally in order to improve the sound quality.
Regarding the impedance matching between the high impedance RETURN terminal of GT - 1000 and the effector of low impedance output etc, it is in the state of so - called "receiving low receiving high", there is no problem.
http://faq-jp.roland.com/faq/show/87827?category_id=9742
15【GT-1000】Q. Can it be used with an electric acoustic guitar?
ANSWER
Yes, you can.
In the GT - 1000, ACOUSTIC RESONANCE which realizes the natural resonance of a natural and abundant acoustic guitar for the electric airco is carried.
http://faq-jp.roland.com/faq/show/87825?category_id=9742
16【GT-1000】Q.  Do you have a special case?
ANSWER
I have no preparation. Please select the one with the size on the market.
The external dimensions / mass of the GT - 1000 are as follows.
Width (W): 462 mm
Length (D): 248 mm
Height (H): 70 mm
Weight: 3.6 kg
http://faq-jp.roland.com/faq/show/87824?category_id=9742
17【GT-1000】Q. Can you connect the foot switch and the expression pedal simultaneously to the CTL 4, 5 / EXP 2 terminal and the CTL 6, 7 / EXP 3 terminal?
ANSWER
can not.
Either the foot switch or the expression pedal can be connected to the CTL 4, 5 / EXP 2 terminal and the CTL 6, 7 / EXP 3 terminal.
Example)
CTL 4, 5 / EXP 2 terminal: FS - 7 (sold separately)
CTL 6, 7 / EXP 3 terminal: EV - 30 (sold separately)
http://faq-jp.roland.com/faq/show/87823?category_id=9742
18【GT-1000】Q. Does sound breakage occur when changing patches?
ANSWER
The new high speed patch switching system is installed in the GT - 1000, and switching with less silent time is possible. Automatic fastest switching is done for each patch, and it is also possible to switch without sound break.
◆ Tips to prevent sound break
By creating the patches before and after switching as follows, it is possible to prevent sound break.
· Do not change the block position with a chain.
· Place effects using multiple blocks
(do not change TYPE in the same block).
- Switch channels using parallel processing.
Example)
Switch from chorus and clean sound using deep delay, to phaser and crunch sound using shallow delay.
http://faq-jp.roland.com/faq/show/87822?category_id=9742
【GT-1000】Q [Driver] Mac OS High Sierra (macOS 10.13) does not recognize the corresponding driver installed
ANSWER
It is possible that the installed driver is blocked by Mac security.
Please unblock the driver according to the procedure described in " TROUBLESHOOTING ~ EVEN IF THE DRIVER IS INSTALLED " ,  in the README.htm file included with the USB driver *.tgz
ANSWER
Select a patch.
Select a patch.
4) Press and hold [2 (DRIVE)] knob to open the ASSIGN MATRIX screen.
     * Switchable TARGET can be switched with the PAGE [<] / [>] button.
TARGET                                                  DIST 1 DRIVE
* Adjust the values ​​of MIN and MAX according to your preference.
SOURCE        EXP1
MODE        MOMENT
Save the patch.
https://rolandus.zendesk.com/hc/en-us/articles/360016410051-GT-1000-Control-of-External-MIDI-Devices-with-PATCH-MIDI
https://www.boss.info/us/support/knowledge_base/360016410051/
GT-1000: CONTROL OF EXTERNAL MIDI DEVICES WITH PATCH MIDI
Tags: MIDI, PC#, CC#, PATCH, PATCH MIDI, CONTROL CHANGE, PROGRAM CHANGE, GT-1000, EXTERNAL, CONTROL, MIDI DATA, MIDI RX, MIDI TX
GT-1000: Control of External MIDI Devices with PATCH MIDI
Please use the GT-1000 PATCH MIDI in order to target multiple external devices on different MIDI CHANNELS. Please see the GT-1000 PARAMETER GUIDE page 35 to review PATCH MIDI.
https://www.boss.info/us/support/by_product/gt-1000/owners_manuals/6f4ee1ca-e847-494f-aac2-38a822db1c08/
For each PATCH on the GT-1000 you can have a 1-4 PATCH MIDI programmed.
Each PATCH MIDI can send MIDI DATA along a selected MIDI CHANNEL (1-16), a PC#(1-128), CC1# and CC2#(1-128). If necessary MSB and LSB#(1-128) for Bank variation and access.
This is the way in which you'll be able to MIDI control your external devices.
NOTE: MIDI SYSTEM GLOBAL parameters will not need adjustment. Disregard Device ID for now because it's only necessary if communicating to two external devices on the same MIDI CHANNEL.
For this example, EXTERNAL DEVICE #1 and DEVICE #2 are setup to receive MIDI DATA on isolated MIDI CHANNELS:
DEVICE#1= is set to MIDI CHANNEL 1 on the external device.
DEVICE#2= is set to MIDI CHANNEL 2 on the external device.
The GT-1000 can send PATCH MIDI by pressing a PATCH 1-5 foot switch buttons in MEMORY MODE (LED BLUE). We recommend setting up two PATCHES, PATCH MIDI 1 and PATCH MIDI 2 for each U01-1 and U01-2.
For an example for U01-1 set up PATCH MIDI:
Press MENU - select CONTROL ASSIGN (KNOB 1) - select PATCH MIDI (KNOB 3):
Set PATCH MIDI PARAMETERS as follows:
MIDI CH: MIDI CHANNEL 1
PC# PROGRAM CHANGE: (1-128) will correlate to and external MIDI DEVICE PATCH.
Refer to your EXTERNAL DEVICE MANUAL for it's MIDI PROGRAM CHANGE RECEIVE MAP.
NOTE: MIDI RX/RECEIVE may differ depending on brand etc. Some may start at PC#0 others at PC#1. Some simple math calculations may be needed to correlate PC# and external device PATCH NUMBER. Also some MIDI DEVICES have a SET MIDI RX MAP, some have a PROGRAMMABLE MIDI RX MAP, some may have MIDI RX LEARN functionality.
BANK MSB and LSB#: (1-128)
Only necessary if targeting PATCHES above PC#128 use LSB#(1-128).
For this example set to 0 or OFF.
CC1# CONTROL CHANGE 1 #: (1-128) Use the CC# to target specific EXTERNAL DEVICE PATCH PARAMETER or SUB PARAMETER. (ie: TIME, RATE, GAIN, etc.)
CC2# CONTROL CHANGE 2 #: (1-128) Second CC# for targeting another EXTERNAL DEVICE PATCH PARAMETER or SUB PARAMETER.
CC1 VALUE: (0-127) Value for targeted CC1#. 0-127 may apply accordingly 0 = OFF, 127 = ON, OR to 0-100 or 0-200 of a PARAMETER.
CC2 VALUE: (0-127) Vale for targeted CC2#. 0-127 may apply accordingly 0 = OFF, 127 = ON, OR to 0-100 or 0-200 of a PARAMETER.
WRITE/SAVE these changes to PATCH MIDI 1 for the PATCH U01-1.
Go to PATCH U01-2 and make similar adjustments for it's PATCH MIDI 1.
This will control the first EXTERNAL DEVICE #1 on MIDI CHANNEL 1 when switching between PATCH U01-1 and U01-2.
To control EXTERNAL DEVICE #2, create and program PATCH MIDI 2 on MIDI CHANNEL 2 for both PATCHES U01-1 and U01-2. This allows for isolated control of each EXTERNAL DEVICE via MIDI CHANNEL and MIDI PC and CC DATA.
Check and test when switching between U01-1 and U01-2 on the GT-1000 and if corresponding external PC# and CC#s are being sent by the GT-1000 and the EXTERNAL DEVICES are syncing correctly.
https://rolandus.zendesk.com/hc/en-...trol-of-External-MIDI-Devices-with-PATCH-MIDI
GT-1000 Editor has a "PATCH MIDI " assignment page for transmitting MIDI Bank/Patch No. and assigning MIDI CC#
For each PATCH on the GT-1000 you can transmit 4 unique MIDI messages
Here is how to access HX STOMP SNAPSHOT #1 ( MIDI CC#69, value 0)
On the below right, using Boss Tone Studio for GT-1000 Patch "U01-1 PREMIUM DRIVE" , I assigned a "PATCH MIDI" #1 message of MIDI CC#69 - value (0) on MIDI Channel #1 - to be transmitted anytime GT-1000 CH NUM 1 footswitch selects
On the left above is the resulting MIDI-OX Monitoring session screen shot I toggled between Program #1 and Program #2 - indicating that each time I pressed the NUMBER 1 footswitch DOWN, the GT-1000 MIDI output transmits on MIDI CH#1 :
MIDI Bank MSB 0
MIDI Bank LSB 32
MIDI Program Change 0
MIDI Control Change (CC#) 69 - (value) 0
each time I released the NUMBER 1 footswitch, no MIDI data is transmitted
All GT-1000 assigned "PATCH MIDI" messages are sent sequentially upon each downward press of the footpedal.
There is no accommodation for assigning unique specific MIDI message / event with release of a foot switch.
https://www.thegearpage.net/board/index.php?posts/27424957/
QuotePAH said: ↑
@guitarrob Under Menu / MIDI / MIDI Settings, do you have NUM1 CC#, NUM2 CC#, etc. enabled? If you have those set to CC# 69, then I believe you'll get a value of 127 sent to CC# 69 when you press the corresponding footswitch and a value of 0 when you release it. For what you're trying to do, these should be set to "Off" or some other CC #. The Patch MIDI settings that @Elantric described should work for you if the general MIDI settings are correct.
That was it PAH! Thank you!! Under Menu / MIDI / MIDI Settings, I had NUM1 CC#, NUM2 CC#, etc. enabled and set to CC# 69. That is what was causing the conflict! When I set all of these to "Off" as you suggested, presto, everything worked fine. Thanks again PAH! Now I've got some programming work to do!
Also, I'd like to thank Elantric and JiveTurkey and the others who took the time to try to get this up and running for me as well!
https://www.boss.info/us/support/knowledge_base/360005060131/
GT-1000: SET UP TUNER FOR CURRENT NUMBER
Back to Results
Tags: SYSTEM, CTL3, CNUM, GT-1000, TUNER, TUNER ON/OFF, CUR NUM, CURRENT NUMBER, GLOBAL, CONTROL 3
GT-1000: Set Up TUNER for CURRENT NUMBER
Set up the GT-1000 TUNER for CURRENT NUMBER so that the CURRENT PATCH NUMBER being played can be used to TOGGLE the TUNER ON/OFF.
This will allow the user to regain CONTROL 3/CTL3 to be programmed for other functionality like an added effect ON/OFF, etc.
Press [MENU], press (KNOB1) for the CONTROL ASSIGN MENU,
Press (KNOB1) for CONTROL FUNCTION MENU,
Within the CONTROL FUNCTION MENU, press the [PAGE RIGHT > ARROW] button for Page 2.
Locate CUR NUM/CURRENT NUMBER in the bottom right corner of the CONTROL FUNCTION SCREEN (see below).
Turn (KNOB1) to SELECT and highlight the CUR NUM row for PREFERENCE, turn (KNOB6) to set to SYSTEM. (This will make CUR NUM for TUNER setting SYSTEM/GLOBAL for all PATCHES).
Turn (KNOB1) to highlight CUR NUM row for FUNCTION and turn (KNOB6) to set FUNCTION to TUNER,
Turn (KNOB1) to CUR NUM row for MODE and turn (KNOB6) to set MODE to TOGGLE.
The CONTROL ASSIGN FUNCTION has been set to SYSTEM, so there is no need to WRITE/SAVE settings, it will automatically remain set and saved.
Test and check in MEMORY MODE, use the PATCH NUMBER FOOT SWITCH currently selected (LED BLUE), press once for the PATCH, again for TUNER TOGGLE ON and press once more for TUNER TOGGLE OFF to return to MEMORY PATCH play.
Now move on to setup and program CTL3 for customized functionality for each PATCH while still retaining TUNER with CUR NUM/CURRENT NUMBER.
https://www.thegearpage.net/board/index.php?posts/27329561/
QuoteKeefPilchards said: ↑
Does anyone know if the GT1000 can receive MIDI program changes over Bluetooth?
I use OnSong for iPad (for song lyrics) and if I could link song-specific patches to the corresponding OnSong pages, this would be a huge help on stage. I currently use a BT page turner pedal to flick between songs during a set, so I love the idea of this being the only button press I need! Taking it a step further, I'd also like to incorporate vocal effects via the new Boss VE-500, so I'm hoping that the GT1000 can send program changes to that too.
KeefPilchards wrote.
I'll answer my own question - YES IT CAN!
I spent some time testing a GT1000 at the weekend, and after a bit of tinkering I found that the BT connection can be used to receive program changes from OnSong. This means I can spend a bit of time defining exactly which combination of guitar and vocal patches I need for each song, and then I just need to edit the set list order on my iPad, to get one-button sequencing for the entire gig! This is a killer feature which I think Boss need to start shouting about since it differentiates them from every other unit on the market right now.
After that, I did some ABing with a Helix to get a feel for how the tones compare. I didn't dive too deep but in the time I had, I found the Boss sounded easily as good and in many cases better than the Helix. Add to this the Stompbox feature, the poly tuner mode, the smaller footprint, and that was the decision made. The GT1000 came home with me!  :)
QuoteCan you explain each step to connect GT-1000 to iPad hosting Onsong?
did you need any third party hardware?
No hardware required - just a small in app purchase to enable MIDI in OnSong, followed by a poke around the settings. Once you connect the GT in the Boss app, it just connects as a regular MIDI device.
I need to replicate this on the unit I bought, so will try to document the exact steps when I set it up again...
Use Google translate for new GT-1000 Q & A
http://faq-jp.roland.com/category/show/9742
Q:【GT-1000】 Even if you select "3-4 GT-1000" as a playback device, effects will be applied to the signal sent from the PC, what should I do?
A: ANSWER
Use  the system program (Firmware) of GT - 1000 is Ver.1.20 or later. ( FW 1.21 is latest)
* If your system program is Ver.1.20 or later, please also use the latest version of the USB driver.
In the GT-1000 system program version 1.20, the order of MAIN and DRY of the USB port is switched.
* For details of the changes, please refer to " GT-1000 System / Program (Ver.1.21) ".
Therefore, if the system program of GT-1000 is Ver. 1.20 or later, select "1-2 GT-1000" (GT-1000 MAIN) in order to prevent effects of GT-1000 during playback please.
Q: [Driver] Mac OS High Sierra (macOS 10.13) does not recognize the corresponding driver installed
A: ANSWER
Please unblock the driver according to the procedure described in " TROUBLESHOOTING ~ EVEN IF THE DRIVER IS INSTALLED " .
https://www.boss.info/global/support/support_news/18091014/
PAH wrote>
With firmware 1.x, the cab and output blocks were one and the same.
With firmware 2.0 - 3.02, the cab and outputs were separate blocks, but they moved together. The cabs were depicted as a branch out point in you chain, and the output was the end of that branch. You could put effects between the cab and output, and they'd move with the cab/output, too.
In Firmware 3.10, the branch out point and the cab are now separate and the cabs can be moved out of the branches into the common signal path. You can still move the output to move the branch, so you can still do what you are used to doing.
But, with 3.10, you can also do other things:
Use one cab in the common path to affect both main and sub outs - not needing to duplicate settings.
Use a divider/mixer to put two amps in parallel, each with their own cab, mix them together, and then send them to both main and sub outs.
Use a divider to split your signal into two paths. One path emulates an acoustic guitar, the other has an amp and cab, then mix the two together and send to both main and sub outs. The acoustic is full range with no guitar cab, the amp has a cab.
Use a divider to split your signal into two paths. One path uses a send/return to an external synth effect, the other has an amp and cab, then mix the two together and send to both main and sub outs. The synth is full range with no guitar cab, the amp has a cab.
etc.
