MS-3 - FAQ
Started by admin, May 15, 2018, 01:01:42 PM
Q & A IN "MS-3"
#86826
【MS-3】 Q. MS-3 Editor / Librarian for ** can not be installed.
ANSWER
If you get an error such as "Downloading is being confirmed" during installation of MS-3 Editor / Librarian for ** and the installation is not completed, you may not have installed Adobe AIR.
When installing MS-3 Editor / Librarian, Adobe AIR of Adobe Inc. is automatically installed, so that MS-3 Editor / Librarian is installed properly according to it.
If the installation of Adobe AIR is not completed for some reason, installation of MS-3 Editor / Librarian will not be performed normally.
In this case, please troubleshoot, please try installing MS-3 Editor / Librarian manually after manually installing Adobe AIR from Adobe's website.
#86533
【MS-3】 Q. Can I synchronize MS-3 to tempo information of external equipment?
ANSWER
can not.
MS-3 can not receive MIDI messages from outside.
#86532
【MS-3】 Q. Can I switch patches or turn LOOP ON / OFF from an external device?
ANSWER
can not.
#86509
【MS-3】 Q. If you unplug the expression pedal or foot switch from the CTL IN terminal while the power is on, you can not switch the effect type on the EDIT screen.
ANSWER
This problem was corrected in the MS-3 system program version 1.03.
Please update MS - 3 to the latest version.
If you have symptoms that TYPE can not be switched, you can temporarily recover by one of the following methods.
· Connect the device again to the CTL IN terminal.
Turn the power of the MS - 3 unit on again.
· Hold down the [EXIT] button and press the [ON / OFF] button.
#86503
[MS-3] Q. Is it possible to send a program change number in addition to the patch switching timing?
ANSWER
can not.
With MS - 3, program change numbers can be sent only at the timing of patch switching.
#86490
【MS-3】 Q. Please tell me how to make WAH ON when I start stepping on the external EXP pedal.
ANSWER
When the following settings are made, WAH turns OFF when it is returned to the heel side, and WAH turns ON when depressing toe side.
1. Assign FX 1: WAH control to EXP 1 of the patch in advance.
  Please refer to the following MS-3 Q & A for operation method.
 " Please tell me how to connect the EV - 30 or EV - 5 to the MS - 3 and use it as a WAH pedal. "
http://faq-jp.roland.com/faq/show/86476
2. Next, add the following settings with EDIT - CTL - ASSIGN 1 - 8.
  ※ ASSIGN 1 to 8 are ASSIGN numbers that are not ON (not used) Please choose.
ASSIGN  ON
SOURCE  EXP1
MODE  MOMENT
CATEGORY FX 1
TARGET  ON / OFF
MIN  OFF
MAX  ON
ACT.LOW    0
ACT.HIGH  1
  ※ For how to set ASSIGN, please refer to the following.
   1) Press the [EDIT] button.
   2) Turn the [1] knob to select "CTL".
   3) Press the [ENTER] button.
   4) Turn the [1] knob to select "ASSIGN 1 - 8".
   5) Press the [ENTER] button.
   6) Perform the above setting.
3. Finally save the patch.
  * Please refer to the following for the patch storage method.
   1) Press the [EXIT] + [ENTER] button.
   2) Select "WRITE" and press the [ENTER] button.
   3) Press the [1] knob to select the destination memory.
   4) Press the [ENTER] button and change the patch name as necessary.
     [1] Knob: Change character
     [2] Knob: Move cursor
     [3] Knob: toggle between uppercase letters / lowercase letters / symbols
     [EDIT] button: Delete character
     [MENU] button: Insert character
     [ENTER] button: Confirm
   5) Press the [ENTER] button to save the patch to memory.
The operation is over.
#86487
【MS-3】 Q. Can you fast forward the BANK No. by holding down the BANK UP / DOWN switch?
ANSWER
Is possible.
MS-3 supports momentary type external foot switch (FS - 5U etc).
When BANK UP / DOWN with an external foot switch, please use our momentary type external foot switch (FS - 5U etc.).
#86486
[MS-3] Q. Can you turn off BANK UP / DOWN when you press the number switch [1] + [2] or [3] + [4] at the same time?
ANSWER
I can do it.
Please set according to the following procedure.
1. Press the [MENU] button.
2. Use the [1] - [3] knob to select "PLAY" and press the [ENTER] button.
3. Press [PAGE>] (ENTER) button to display Page 3.
4. Use the [1] knob to change BANKDOWN from "1 + 2" to "OFF".
5. Use the [3] knob to change BANKUP from "3 + 4" to "OFF".
#86485
[MS-3] Q. If you operate the BANK UP (number switch [1] + [2]) or BANK DOWN (number switch [3] + [4]) while playing the sound, you will hear a momentary patch sound Is there a breakdown?
ANSWER
It is not a malfunction but a specification.
There is a parameter called SW MODE in MS - 3, and you can set the operation when stepping on the switch.
 PUSH: The patch is switched at the moment you step on the switch
 RELEASE: The patch switches at the moment you step on the switch and is released The factory setting is set to PUSH.
BANK UP / DOWN switches by pressing the two number switches at the same time, but due to the difference in depression timing, the switch other than the currently selected patch may react for a moment.
In such a case, setting SW MODE to RELEASE will improve symptoms.
Set SW MODE in the following procedure.
2. Use the [1] - [3] knob to select PLAY and press the [ENTER] button.
3. While Page 1 is displayed, set SW MODE to "RELEASE" with the [3] knob.
#86484
[MS-3] Q. Can I take over the tempo set using the tap tempo to the next patch?
ANSWER
I can do it.
There are two kinds of methods as follows.
◎ Method 1 (Set whether to inherit the tempo every patch or not)
1. Press the [EDIT] button.
2. Use the [1] knob to select MST and press the [ENTER] button.
3. Set TEMPOHOLD to "ON" with the [3] knob and save the patch.
* If you select a patch set to ON, the tempo information of the previous patch will be inherited.
  If you select a patch set to OFF, it switches to the tempo information saved in the selected patch.
◎ Method 2 (Set tempo information to system setting)
2. Use the [1] - [3] knob to select PREF and press the [ENTER] button.
3. Press [PAGE>] button to display Page 5.
4. Use the [2] knob to change BPM to "SYSTEM".
* Because Master BPM is set to BPM common to all patches, the tempo set using tap tempo is reflected in all patches.
#86483
【MS-3】 Q. Can MS-3 use internal effects or external LOOP in parallel connection (parallel connection) like ES-5, ES-8? Can you sort again?
ANSWER
The effect chain of MS - 3 is series connection (series connection).
In addition, each built-in effect (FX1, FX2, MOD1, MOD2, DLY, REV, NS, FV) can be rearranged and arranged freely before and after L1 to 3.
However, external LOOP (L1, L2, L3) can not be rearranged.
※ For the sorting method, please refer to Chapter 2 of the MS - 3 Quick Start movie .
https://www.youtube.com/watch?v=aX2WB6fUkwg&list=PLGZ4LhsRFL_3-VkW5X6aXAUeFgaZzV-Ht&index=2
#86482
【MS-3】 Q. Can the MS-3 flash the indicator according to Master BPM (tempo)?
ANSWER
In MS - 3, you can blink the MEMORY / MANUAL switch indicator according to Master BPM.
3. Press [PAGE>] (ENTER) button to display Page 4.
4. Set the BEAT LED to "ON" with the [1] knob.
※ For MEMORY MODE, it will be blue, MANUAL MODE will be red, flashing according to Master BPM.
#86479
【MS-3】 Q. Can I connect an external preamplifier to MS-3's LOOP? (4 cable · method)
ANSWER
Is possible.
Please connect MS - 3 and external preamplifier as follows.
<Connection method>
· Connected from the guitar to IN of the
MS - 3 · Connected from the MS - 3 LOOP * SEND to the IN of the
amplifier · Connected from SEND of the amplifier to RETURN of MS - 3 's LOOP *
· From the OUT of MS - 3, Connect to RETURN
<Cautions>
· Depending on the usage environment, ground loops may occur.
· The MS-3 internal effects (FX1, FX2, MOD1, MOD2, DLY, REV, NS, FV) can be moved to any position including L1 and L3. (L1 ~ 3) itself can not be moved.
In addition to the above connections, there are also the following Q & A connection methods, so please choose the connection method according to your usage.
[MS-3] Q & A " Can I connect MS-3 to SEND / RETURN of external preamplifier? "
http://faq-jp.roland.com/faq/show/86478
#86478
【MS-3】 Q. Can I connect the MS-3 to the SEND / RETURN of the external preamplifier?
ANSWER
You can connect.
To connect with SEND / RETURN of the preamplifier, connect from the SEND terminal to the INPUT terminal of the MS - 3, from the OUTPUT L / MONO terminal of the MS - 3 with the audio cable (shield) respectively to the RETURN terminal of the pre - amp .
* Since the INPUT / OUTPUT of the MS - 3 is a mono standard type, it can not be connected in stereo.
MS-3 Q & A " Can I connect an external preamplifier to the LOOP of MS-3? (4 Cable · Method) "
http://faq-jp.roland.com/faq/show/86479
#86476
【MS-3】 Q. Please tell me how to connect the EV-30 or EV-5 to the MS-3 and use it as a WAH pedal.
ANSWER
When using the EV - 30 as a WAH pedal, please connect and set it according to the following procedure.
* If you do not mind, please refer also to the Chapter 8 of the MS - 3 Quick Start movie .
https://www.youtube.com/watch?v=KxNlmQS-6hs&list=PLGZ4LhsRFL_3-VkW5X6aXAUeFgaZzV-Ht&index=8
1. Turn off the power of the MS-3.
2. Set the MIN volume of the EV - 30 to MIN.
3. Connect the EXP 1 CTL 1/2 of CTL IN of MS - 3 to the EXP OUT terminal of EV - 30 with the audio cable of TRS standard plug (stereo standard plug) on ​​both sides.
4. Turn on the MS-3.
- Next, set WAH -
5. Press the [EDIT] button.
6. Turn the [1] knob to select "FX1".
7. Turn the [3] knob to select "WAH" as the effect type.
- Next, set the function of the EV - 30 -
8. Turn the [1] knob to select "CTL".
9. Press the [ENTER] button.
10. Turn the [1] knob to select "EXP1".
11. Press the [ENTER] button.
12. Turn the [1] knob to select "FX1: WH / PB".
13. If you want to make WAH ON when you start stepping on the EXP pedal, continue with the following settings.
   MS-3 Q & A " Please tell me how to make WAH ON when I start stepping on the external EXP pedal. "
http://faq-jp.roland.com/faq/show/86490
- Save the patch at the end -
14. Press the [EXIT] + [ENTER] button.
15. Select "WRITE" and press the [ENTER] button.
16. Press the [1] knob to select the save destination memory.
17. Press the [ENTER] button and change the patch name as necessary.
18. Press the [ENTER] button to save the patch to memory.
19. Operate the EV - 30 and confirm that the WAH effect is applied.
  Also, when selecting a patch again, confirm that the WAH effect is applied in the same way.
#86475
【MS-3】 Q. Does the sound break down when switching patches?
ANSWER
When switching to another tone by patch switching, it will be silent once so as not to cause noise due to sudden change in characteristics.
This behavior is by design, it is not a malfunction.
If you switch the effect from ON to OFF in manual mode, the sound will not be interrupted.
#86474
【MS-3】 Q. Can I assign a function to MS-3 switch or CTL IN terminal?
ANSWER
Is possible.
<In manual mode>
Functions can be assigned to number switches [1] - [4], [MEMORY / MANUAL] switch, CTL IN [1] - [4].
<In memory mode>
Functions can be assigned to the [MEMORY / MANUAL] switch, current number switch, CTL IN [1] - [4].
Please refer to the MS-3 Parameter Guide published on MS-3-SUPPORT to see what parameters can be assigned .
https://www.boss.info/jp/products/ms-3/support/
Please refer to Chapter 6 , Chapter 7 of MS-3 Quick Start Video for setting method .
https://www.youtube.com/watch?v=oRVIjWWf6xA&list=PLGZ4LhsRFL_3-VkW5X6aXAUeFgaZzV-Ht&index=6
https://www.youtube.com/watch?v=eVTt8IOLSKU&list=PLGZ4LhsRFL_3-VkW5X6aXAUeFgaZzV-Ht&index=7
#86473
【MS-3】 Q. What kind of signal is output from the MIDI OUT terminal of MS-3?
ANSWER
From the MS - 3 's MIDI OUT terminal, program change information, control change information, and MIDI clock information are output.
If you want to control an external MIDI device from MS-3 via MIDI, check what kind of behavior the device connected to the MIDI OUT terminal of MS-3 will behave when receiving MIDI information Please give me.
※ Please refer to the MIDI implementation chart published on MS-3 - SUPPORT for detailed specification of MS-3 .
* Refer to Chapter 9 of the MS - 3 Quick Start movie for setting .
https://www.youtube.com/watch?v=6VtbvObSV08&list=PLGZ4LhsRFL_3-VkW5X6aXAUeFgaZzV-Ht&index=9
#86472
【MS-3】 Q. Can I adjust the output level of MS-3?
ANSWER
I can do it.
By adjusting PATCH LEVEL, you can set the output level for each patch.
#86471
【MS-3】 Q. Can MS-3 leave effect reverberation sound when switching patches?
ANSWER
can not.
If you change the effect from ON to OFF in manual mode, the reverberation sound will remain.
#86470
【MS-3】 Q. What kind of tempo information is output from MS-3? Also, what kind of equipment can you receive MS-3 tempo information?
ANSWER
Since the MIDI clock information can be output from the MIDI OUT terminal of the MS - 3, if it corresponds to a slave of MIDI clock synchronized, it can follow the tempo set by MS - 3.
To send the tempo to the device connected to the MIDI OUT terminal of MS-3, set Clock Out (CLK OUT) to "ON" (initial value) in MENU → MIDI → MIDI Setting.
Also, from the CTL OUT 1/2 terminal, you can output the tempo set by Master BPM of the patch.
Depending on the setting, it is also possible to output the tap tempo information at the timing of the patch change, in addition to outputting the tap tempo in real time.
#86469
【MS-3】 Q. Does it work with the power supply of other company's products?
ANSWER
We do not guarantee the operation with other company's power supply at all.
Please be sure to use the AC adapter (PSA - 100S2, PSA - 100S) specified by us as it may cause the MS - 3 to fail if you use a third - party power supply.
#86468
【MS-3】 Q. What kind of expression pedal or foot switch can be connected to the CTL IN jack?
ANSWER
<Expression pedal>
You can use FV - 500H, FV - 500L, EV - 30, Roland EV - 5 (all sold separately).
* Connecting expression pedals made by other companies may cause the main unit to malfunction. Be sure to use the one specified by us.
<Foot switch>
You can use FS - 5U, FS - 5L, FS - 6, FS - 7 (all sold separately).
When using FS - 6 and FS - 7, normally set POLARITY to I (left) and MODE to FS - 5 U (MOMENTARY).
* If you connect a foot switch made by another company, the operation may not be as intended. Be sure to use the one specified by us.
In addition, please also refer to the following Q & A.
MS-3 Q & A "When you turn off the power, if you unplug the expression pedal or foot switch from the CTL IN jack, you can not switch the effect type on the EDIT screen. "
http://faq-jp.roland.com/faq/show/86509
#86467
【MS-3】 Q. Can I use it with a bass guitar?
ANSWER
Can be used.
The effect tuned for the base is loaded, and TUNER corresponds to the bass range of the base.
#86465
【MS-3】 Q. Are there any differences in the switcher function between ES-5 and MS-3?
ANSWER
The switcher function of MS - 3 differs from ES - 5 in the following differences.
· In MS-3, it is not possible to change the order of LOOP 1 ~ 3.
· MS-3 does not have mixer function. Therefore, it is not possible to connect the effects in parallel or carry over (leaving delay sound).
· MS-3 can not operate by receiving MIDI message from the outside.
· Manual mode of ES - 5 consists of ON / OFF dedicated switch of each LOOP, but MS - 3 can freely set various functions for each switch.
· MS-3 does not have ON / OFF function of Input Buffer.
• There is no Patch MIDI in the Target of Assign on MS-3. Therefore, program change number can be sent only when patch is selected in memory mode.
#86464
【MS-3】 Q. Is it the same effect as the effect installed in the GT-1?
ANSWER
The same effect as the GT - 1 is installed in the MS - 3, but effects that are further brushed up than the GT - 1 are also installed.
Also, because the number of MS - 3 's parameters is larger than GT - 1, it is possible to create more detailed sounds.
#86463
【MS-3】 Q. Is it the same effect as the effect installed on the GT-100?
ANSWER
The same effects as the GT - 100 are installed in the MS - 3, but effects that are further brushed up than the GT - 100 are also installed.
#86462
【MS-3】 Q. What can you do with the USB terminal?
ANSWER
You can use "MS - 3 Editor / Librarian" which allows you to edit and manage patches by connecting the MS - 3 's USB port, Windows compatible computer, or Apple Mac series.
* MS-3 has no USB audio function.
* MIDI messages can not be exchanged with software other than MS-3 Editor / Librarian.
MS-3 Editor / Librarian can be downloaded free of charge from MS-3 download page .
#86461
【MS-3】 Q. Do you have editor software for PC?
ANSWER
There is MS - 3 Editor / Librarian.
#86460
【MS-3】 Q. Can I connect with iOS or Android tablet etc.?
ANSWER
can not.
You can connect the MS-3 with a USB cable and use it only for Windows compatible PC with USB port, or Apple Mac series.
For detailed operating conditions, refer to the download page of each driver .
