New 13 Pin breakout
Started by KeldAmpworks, March 02, 2018, 06:21:10 AM
KeldAmpworks
Hi,
There's so much great information on here that I nearly always end up posting in the wrong place! Apologires if I've done it again, admins.
For a musical project I'm working on I've decided I need full 6 string breakout from the 13 pin pickup so I've designed a new board that gives me access to all the pins. I'm certainly not the first to do it, but I'm doing it in a very simple but effective way.
There's no active electronics in the signal path, just a straight forward pin mapping of the 6 strings to 6 mono jacks and mapping of the other 13 pin functions to stomp switches and jacks.
I'm a gigging player, rather than a studio guy, so it's important to me to make something that suits that environment. For me, I'm always frustrated by not having access to the S1/S2 at my feet, so I've turned them into stompbox switches, and the GK volume into an expression socket.
There's an option to add a bipolar 7-0-7 DC power supply with on board filtering, or you can just power from a GR55 etc. It fits in a standard 1590BB box.
Uses:
  • Break out 6 strings from a GK pickup to run into separate FX chains (That's what I want to do)
  • Break a normal guitar into any of the 6 strings to allow monophonic use of the synth tones (Unlike my P7 breakout board, and some other products, this requires an external buffer, eg any Boss pedal)
  • Replace the GK pickup synth vol control with an expression pedal.
  • Replace the S1/S2 (Up/down) switches with stompbox style switches
  • Break in/out of the 'normal' gtr signal, just like the P7, but without a buffer.
Shout if there's a simple feature you think should be included. Like the other board, I'm pretty much just doing this to fund my own musical needs so it's dirt cheap(!):
  • May vary from image below
  • Made to order
  • PCB only option (£32ish)
  • Assembled PCB option with undrilled box (£75ish)
  • Other options POA.
  • No box drilling for this one at this time. Sorry. :(
If you're interested please let me know. I'll be able to finalise prices when I've got an idea of purchase quantities. If there are a few people interested I should be able to do it cheaper. If there aren't, it might be slightly more.
Thanks for reading.
billbax
Hi KeldAmpworks,
I remember designing something similar to your project pcb in 2015.  The idea was to replace the 'new' GKP-2 Roland cable in a diecast case.  It worked well, but never bothered to take it any further.
GKP-2 in a box plus separate strings out.
ISO
Rear
Today v-synth users might find themselves better off with a standard GKP-1 breakout box, or if they only want to access separate strings out, a simple breakout cable will do. The versatile cable is only £75.00GBP, and functions as a breakout box and a cable set in one.
GKP-1 Breakout Box priced at £130.00GBP.  The optional 12 mono switch-jacks make this unit a separate strings patchbay.
Mini Breakout Cable at £75.00GBP
I hope my reply doesn't come over as some smart a**e, as there are a couple of v-guitar forum members offering a similar project to yours.
Bill
www.separate-strings.co.uk
cags12
You might want to include a modular design like the Cycfy Nexus box.
http://www.cycfi.com/2016/11/announcing-the-nexus/
I once had designed a small  DIN 13 to DB25 breakout board  - but never fabricated it
required the user to use one of these
BTW - another odd adapter
Atari ST to SCART cable ( for parts only - not natively compatible with Roland / Boss GK 13 gear
http://atariage.com/forums/topic/272817-1088xel-atari-itx-motherboard-diy-builders-thread/page-12#entry3938616
KeldAmpworks
Thanks for the ideas guys.
I don't think you're being an ass Bill. Plug away. I'm offering a DIY kit for live use You're offering a complete product for studio use. No Biggie.
I've now got sufficient interest to cut the prices, see above.
Quote from: cags12 on March 02, 2018, 11:50:10 AM
...and FWIW, I produced a 13-pin Synth-Linx Jack model to interface with this (now-defunct) unit...   ;)
Peter
Quote from: gumbo on March 02, 2018, 01:49:52 PM
Peter
What replaced the "Cycfy Nexus box.' ?
scratch17
Unfortunately, nothing. Cycfi just discontinued it.
VG-99, FC-300, RMC Fanout
RJM Mastermind GT10
Kemper Profiling Amp
Radial JDV Mk3, X-Amp
Mesa Recto Pre + 20/20
68 Fender Bandmaster (AB763)
Marshal AS80R
KeldAmpworks
I've only just heard of the cycfi. Looks like Interesting stuff. LIMO connectors on a guitar though... I'd be more worried about damaging the connectors  than the guitar!
billbax
#9
Hi KeldAmpworks,
Thanks for your gracious understanding with my post - I'll be more abusive in the next one ;D
Slight correction needed in your reply...I design breakout box products for live as well as studio use.
QuoteI'm offering a DIY kit for live use You're offering a complete product for studio use.
Looking at your pcb overlay, are you going to use separate string output buffering?  A 10uF/25V or 10uF/50V elect is usually a good idea on outputs and inputs, as you never know what someone will plug into those jacks.  If you do use a capacitor as a buffer, make sure you keep to 10uF, as a lower value will give a bass cut in the frequency response.
Good luck,
Bill
Quote from: scratch17 on March 02, 2018, 02:08:10 PM
Not the first time a product goes end of life coincident with higher customer awareness
( for example  ANTARES ATG
Was waiting for the Cycfi box to finally be available at the Cycfi store ( oh well )
https://www.cycfi-research.com
cags12
Quote from: admsustainiac on March 02, 2018, 02:57:37 PM
The Nexus box was available just by simply sending an email. I had the option to buy one of the last ones last week. It was overkill for my needs so I did not buy it. Instead I got the NU, XR's and the GK breakout kit.
FWIW - The Nexus is not fully discontinued like the XRs. Read Joel's updates on the Facebook group.
vanceg
The Nexus is going to continue.  It is not a dead product.
mooncaine
Quote from: cags12 on March 02, 2018, 04:47:31 PM
I contacted them twice asking about a GK-compatible pickup, or kit, or whatever. Never saw a reply nor any info at all about it except what you fellows have shared here.
Quote from: vanceg on March 03, 2018, 04:13:30 PM
...well, that's good news...   ;)
cags12
Quote from: gumbo on March 04, 2018, 01:49:25 AM
If you are not part of the Facebook group read below.
https://www.vguitarforums.com/smf/index.php?topic=22962.msg166995#msg166995
Nexus will be part of a new reference design.
I am not a member of the Facebook group (although I was invited), so thank you for the clarification.
...nothing against Cycfi, I just made a decision a long time ago that Facebook was not part of my life.
Peter
Fheder
Has anyone tried to create an audio interface to send a Audio signal directly from a 13-pin cable to a Toslink-ADAT cable using an Arduino or some other type of A/D converter?
My final goal is to send separate Audio signals from each guitar strings to my DAW without having to use Breakout-box or having to use 8 channels of an audio interface to do it
I have a Universal Audio Apollo Twin MKII (2 inputs) with ADAT input (expandable to 8 inputs) , so I thought that It could be great to use this to send audio signal  ;D
https://www.youtube.com/watch?v=e5ov3q02zxo&feature=youtu.be
look at this project I found
QuoteMy final goal is to send separate Audio signals from each guitar strings to my DAW without having to use Breakout-box
The Boss GP-10 already accomplishes that  - $300 used
RTM
https://static.roland.com/assets/media/pdf/GP-10_e02_W.pdf
https://static.roland.com/assets/media/pdf/GP-10_Parameter_Guide_e02_W.pdf
Boss GP-10 USB AUDIO/midi
https://www.vguitarforums.com/smf/index.php?topic=10805.0
[WINDOWS]
Audio input/output device
Of the total audio input/output channels provided by the GP-10, there are 8 INs and 8 OUTs
[Computer WAVE IN Devices]
IN (GP-10) (Stereo Audio Output from GP-10
GK 1-2 (GP-10) (to record raw signal from  high E+B String)
GK 3-4 (GP-10) (to record raw signal from  high G+D String)
GK 5-6 (GP-10)( to record raw signal from A+Low E String)
[Computer WAVE OUT Devices]
OUT (GP-10) ( for Re-Amping)
GK 1-2 (GP-10) (to drive COSM Modeling for high E+B String - for Re-Guitaring)
GK 3-4 (GP-10) (to drive COSM Modeling for  high G+D String- for Re-Guitaring)
GK 5-6 (GP-10) (to drive COSM Modeling for  A + Low E String- for Re-Guitaring)
vanceg
That's not the case at all. The Nexus is still available.
vanceg
Quote from: KeldAmpworks on March 02, 2018, 02:18:23 PM
The Limo connector works VERY well and is extremely resistant to damage, mainly due to it's absurdly overbult design. It really seems like a vastly better connector than the little DIN jacks...but absurdly expensive...that's it's main downfall as far as I can tell.
Fheder
Quote from: admin on May 01, 2019, 10:00:39 AM
RTM
tell me if I am wrong, the GP10 sends audio of the 6 strings on a single channel, not on 6 separate channels from each string
Quote from: Fheder on May 01, 2019, 10:10:48 AM
Each string on GP-10 has a separate I/O channel ( as 4 stereo pairs)
[WINDOWS]
Of the total audio input/output channels provided by the GP-10, there are 8 INs and 8 OUTs ( as 4 stereo pairs)
Quote from: vanceg on May 01, 2019, 10:07:46 AM
Lemo connectors are good enough for Los Alamos  / Sandia nuclear test facilities - and good enough for VGuitar too!
https://www.lemo.com/en/application/nuclear-connector
Fheder
 :o :o :o mind blowing! thanks for this info!
Quote from: admin on May 01, 2019, 10:12:19 AM
[WINDOWS]
