GR-20 Editor
Started by Elantric, February 04, 2016, 01:45:03 PM
6dB
did you make it work? I get an error saying that the GR20 is not connected
Its only an Alpha version - and not finalized.
(owing to the fact there a limited numbers of GR-20 users )
Suggest join the Yahoo GR-20 group
https://groups.yahoo.com/neo/groups/gr-20/info?yguid=81112783
Further development on the GR-20 editor was ceased, due to the GR-20 firmware being not very co-operative with midi system exclusive data requests.
Older Roland devices, including the GR-20, do not support realtime bi-directional sysx data transfer, instead only support "bulk dump" mode as the only means to extract data from the device.
So the GR-20 does support real-time patch data/parameter change from the editor, but the editor can not first retrieve data easily from the GR-20 to 'know' where the initial settings are at.
Secondly, the GR-20 user interface is so basic and easy to use, an editor is quite pointless, except the editor lists all the synth tone sounds by name, making tone selection easier.
manuels
Is there a way I can access the synth sounds another way?
1951 Fender Custom Shop Nocaster.
1966 Fender Telecaster blonde.
1971 Fender Telecaster black with Bigsby.
1973 Fender Telecaster blonde. SOLD
1972 Fender Stratocaster sunburst with rosewood fretboard.
1975 Fender Precision Bass. Deep red with rosewood fretboard.
1967 Fender Twin Reverb.
Out of room
Quote from: manuels on June 28, 2018, 06:01:28 PM
Only the genuine GR-20 hardware can deliver GR-20 sounds
anarchytect
Quote from: gumtown on February 06, 2016, 04:07:28 PMFurther development on the GR-20 editor was ceased, due to the GR-20 firmware being not very co-operative with midi system exclusive data requests. Older Roland devices, including the GR-20, do not support realtime bi-directional sysx data transfer, instead only support "bulk dump" mode as the only means to extract data from the device. So the GR-20 does support real-time patch data/parameter change from the editor, but the editor can not first retrieve data easily from the GR-20 to 'know' where the initial settings are at.
hi, I installed today the editor (mainly for organising my user patches, hoping for a rename option & secret settings) but I have no idea how to connect the gr20 with the pc, since it has no usb slot :) i tried midi through the roland tr8 used as a soundcard but couldn't get any connection between the editor and the roland unit.
anarchytect
the editor seems very nice but i am curious if you can rearrange the order of the presets & user patches / rename user patches? and also assign different sounds for a specific patch (let's say piano + drums) i couldn't test this offline
seems like i need something like this magic box
anarchytect
Hi
does anybody here have a proper implementation chart for boss gr-20? the manual is very succint :) i need to make a definition txt file for the squarp pyramid
anarchytect
Hi
does anybody here have a proper implementation chart for roland gr-20? the manual is very succint :) i need to make a definition .txt file for the squarp pyramid
Quote from: anarchytect on September 04, 2023, 09:48:56 AMthe editor seems very nice but i am curious if you can rearrange the order of the presets & user patches / rename user patches? and also assign different sounds for a specific patch (let's say piano + drums) i couldn't test this offline
I no longer have any documentation or info, or the editor source code, work ceased on this 14 years ago.
The GR-20 is very limited in functions, and is very much just a Rompler player with little adjustment.
The patches within the GR-20 can not be named, and only patch files saved to disk can be named.
JoBoss
Is it possible to change patches on the GR-20 via external midi controller ???
gumtownadmin
Quote from: JoBoss on December 27, 2023, 12:00:50 PMIs it possible to change patches on the GR-20 via external midi controller ???
Yes, it only requires a midi cable into the GR-20 midi in port.
JoBoss
Thanks Gumtown!!.....I have a Valeton GP-200, which I would like to use as a MIDI controller, to control the GR-20, to just change patches only on the GR-20....how should I go about it.....???....sorry for my ignorance with anything MIDI...... ::)
I don't know much about the Valeton GP-200, but try plugging a midi cable from its midi out into the GP-20 midi in.
JoBoss
Thanks Gumtown......what should I do next...I'm extremely sorry for my total ignorance .....please take  your time and help me find a solution.....I know this sounds absurd....but I've my challenges....no hurry.....I'm bound to my chair...... 8)
When you change patch on the Valeton, does the GR-20 follow the patch change (1~99) ?
The midi channel setting of both the GP-100 and GR-20 need to match (channel 1 is good), although the GP-200 can do OMNI mode too which is 'all channels'.
Open the GP-200 user manual to page "7" which explains how to assign a midi control to one of the foot switch's,
 control change (cc#) are the first 127 options, then the last option is Program Change (pc#) which is what you need to select one of the 99 GR-20 patches,
select channel number, then patch number.
https://www.valeton.net/manual.html
Quote from: JoBoss on December 29, 2023, 10:18:15 AMThanks Gumtown!!.....I have a Valeton GP-200, which I would like to use as a MIDI controller, to control the GR-20, to just change patches only on the GR-20....how should I go about it.....???....sorry for my ignorance with anything MIDI...... ::)
Use the standard MIDI CONTROLLER setup procedure here
Valeton GP-200 Manual
https://res.valeton.net//enclosure/sources/unSmrVUGkCTqQTur/GP-200_Online%C2%A0Manual_EN_Firmware%20V1.5.0.pdf
Learn MIDI
JoBoss
Thank you so much Gumtown and Elantric.. :) ...don't have words to describe my gratitude to you guys..... :-X ......
