USB Class Compliant - USBAudio2.0 mode" support "driverless" 24 bit audio
Started by Elantric, July 10, 2014, 12:06:02 PM
All the following products support "driverless" 24 bit audio I/O using USB Class Compliant Mode or "USB Audio 2.0 mode".
This is important if you want to use these interfaces with iPad/ iPhone/ Android / Linux
Apogee JAM
IK Multimedia iRig HD
IK Multimedia iRig Pro
Peavey AmpKit Link HD
Roland UA-22 Duo Capture EX
Roland FA-6, FA-8
Steinberg UR Series
Focusrite Scarlett 2i2
Focusrite Scarlett 2i4
Focusrite Scarlett 18i6
Focusrite Scarlett 18i20
Presonus AudioBox 1818VSL
Digitech GNX3000
Digitech GSP-1101
Lexicon Omega Studio
Vox VXII Amp
Korg PX5D
more here too
http://auriaapp.com/Support/auria-audio-interfaces
Further reading about 24 bit USB Class Compliant Audio - which is the current standard for interfacing with iPads and Android Tablets
http://en.ntrack.com/pro-audio-on-ipad.php
http://www.wavemachinelabs.com/Support/auria-audio-interfaces
http://www.usb.org/developers/docs/devclass_docs/
QuoteUSB Device Classification for Audio Devices
unzip - find the doc named "Audio20_final.pdf
http://www.usb.org/developers/docs/devclass_docs/Audio2.0_final.zip
http://www.usb.org/developers/devclass_docs
http://www.usb.org/developers/devclass_docs/AV_BDP_v1.0.pdf
http://www.rme-audio.de/en_support_techinfo.php?page=content/support/en_support_techinfo_cc_mode
These Roland Audio Interfaces are USB Class Compliant -
Roland FA-06, FA-08
http://www.rolandus.com/support/knowledge_base/205721095
FA-06, FA-08: USB DRIVER MODE
Tags: FA-06, FA-08, USB, Driver
The FA-06 and FA-08 allow you to change the USB Driver setting - the available options are:
VENDER: This setting requires that you install a Roland USB driver on your computer for the FA-06 or FA-08, and allows you to transfer both MIDI and Audio through the USB connection. This is the 'normal' setting used when connecting to a computer.
GENERIC: This setting does not require a Roland USB driver to be installed (it instead uses the built-in driver in your computer's operating system), and is also referred to as "Class Compliant." This is a good option when a USB driver is not available for your computer, or when you are connecting to an iOS device.
Here are the steps to change the USB Driver setting on the FA-06/08:
Press MENU.
Cursor to "System" and press ENTER.
Use the </> buttons to select the "General" tab at the top of the screen.
Cursor to "USB Driver" and use the Value Dial to set this to "VENDER (MIDI+AUDIO)" or "GENERIC (MIDI ONLY)." You will need to press the #6 button under the screen (which has "WRITE" displayed above it on the screen) to proceed.
Power off then back on the FA-06/08.
The VG-99, VB-99, GT-10, GT-10B also provide a 16 bit USB Class compliant mode
fokof
Allen&Heath ZED10
Class compliant
2 IN  / 2 OUTS
https://www.allen-heath.com/ahproducts/zed-10/
