Korg Kross 2 61 / 88
Started by Elantric, September 17, 2017, 09:17:09 PM
https://youtu.be/ZcXvBkssZ1Y
Kross 2 demo starts at 40:00 minutes
Has a MIDI sequencer that can act as a show controller to change programs on your VG-99 / GR-55 / Kemper / Axe-FX
New Korg Kross 2 model  - adds Audio Sampling and USB Audio and integration with Korg Module (IOS) on iPad
Just released Sept 1 2017  - some itms are still not avaqilable yet - ( Kross 2 Editor and DAW Plug in )
http://www.korg.com/us/products/synthesizers/kross2/
More features, more sounds, more possibilities.
A state-of-the-art platform with ever greater functionality.
The mobile synthesizer workstation that does everything.
KROSS 2, the long-awaited successor of the KROSS, is a compact, portable workstation with a huge range of sounds. While maintaining its identity as ultra-lightweight, compact, and capable of running on batteries, this new model dramatically enhances KROSS's sounds and functionality. In addition to a total of more than a thousand preset sounds, expansion PCM memory has been newly added. Also new is a pad sampler that allows full-fledged sampling, and USB Class Compliant audio/MIDI interface functionality. The color scheme is even more stylish, and the user interface allows intuitive operation even by beginners.
Effortlessly select the sound that you want to play, shape it to match your imagination, sample a sound, create phrases and rhythms, record your vocal or guitar, bring KROSS 2 on stage, and perform. Whatever you artistic vision, you can make it happen. KROSS 2 is a versatile synthesizer platform made with creative freedom in mind.
Highlight
• A rich selection of more than 1,000 powered-up presets
• 128MB of expansion PCM memory is built-in, and option libraries are supported
• The rich expressive power of the EDS-i sound engine, and a rich selection of effects with 134 types
• Superb sampling functionality and 16 sampler pads
• A panel layout that lets you access functions without confusion
• Realtime control section for quick parameter editing
• Favorite function lets you register and instantly recall up to 128 frequently-used sounds
• Quick layer/split can be specified by a single button
• Ultra-lightweight compact body; the 61-key model weighs only 3.8 kg, the lightest in its class
• Long operating life, with six AA batteries allowing up to seven hours of use
• A color lineup with a peerless finish that exceeds its class
• Audio player/recorder that can be easily triggered by the pads
• Sequencer, drum track, and arpeggiator to support your song production
• A rich array of input jacks for singer-instrumentalists or vocoder performance without requiring additional equipment
• Also functions as a USB audio interface
Even more powerful preset sounds, with specialized optional expansion sounds
A rich variety of more than 1,000 preset sounds
The sound quality of KORG synthesizers is endorsed by top-ranking musicians around the world. The evolved KROSS 2 expands polyphony from 80 to 120 voices, and dramatically powers-up the number of internal programs from 809 to 1,075 programs. Including multi-layered pianos and electric pianos, thick strings and other new sounds that will work well with any band, as well as the latest drum kits to cover current styles such as EDM. The wide selection of programs covers your needs from live performance to studio production.
Built-in expansion PCM memory, and support for optional libraries
The KROSS 2 now provides 128 MB of built-in expansion PCM memory. By selecting from optional libraries that will be released following KROSS 2, you can expand KROSS 2's internal sounds to meet the needs of your performing style or situation.
The rich expressive power of the EDS-i sound engine, with a full complement of effects
The high-quality EDS-i Enhanced Definition Synthesis-integrated sound engine is inherited from KORG's professional synthesizers. You can use a total of seven effects units simultaneously: five insert and two master. Rich expressive power is available from the selection of 134 high-quality effects, including standard effects such as delay and reverb as well as amp modeling, vintage effect units, and even a vocoder.
Superb sampling function and a pad sampler
As a first in its class, the KROSS 2 is newly equipped with a unique sampling function that provides 16 playable pads. You can record the input from the LINE IN jack and assign a stereo sample of up to 14 seconds to each pad. Up to four pads can be triggered simultaneously. You can edit the sample waveform using functions such as start/end loop point settings and normalize, and even resample within the KROSS 2, allowing you to perform extensive sampling without requiring any additional equipment. Long audio files from an SD card can also be assigned to these pads.
Straightforward access to the sounds and functions you need
It's easy to get around on KROSS 2, thanks to a user-friendly layout. The panel of the KROSS 2 has been further improved since the first KROSS, ensuring that anyone can quickly access desired sounds and functions from the enormous range of choices.
The new realtime control section lets you directly control KROSS 2's main parameters without having to navigate through a menu hierarchy. In addition to realtime control of the sounds and effects, and simple editing of programs, you can use the knobs to easily control the vocoder settings or adjust the tempo of the arpeggiator and sequencer.
https://www.youtube.com/results?search_query=KORG+KROSS2
Favorites function
The favorite function lets you register frequently-used programs and combinations and recall them at a single touch, and has even been expanded to allow 128 favorite locations, twice the number of the first generation of KROSS. This function is ideal for live players that need quick access to a specialized set of sounds on stage.
Quick layer/split
The layer/split function, which lets you layer two sounds or assign separate sounds to the left and right regions of the keyboard, is now easier to set up, thanks to a dedicated quick layer/split button
Category dial
A category dial is provided, allowing you to immediately find the sounds you're looking for amid the vast range of choices. Just choose the general type of sound, such as piano or organ, and then make your selection quickly and efficiently.
Ultra-lightweight and compact body, with support for battery operation
The amazing mobility of the KROSS series is better than ever. The 61-key model features a new and stylish design, and its weight has been further reduced from the 4.3 kg of the previous model to an even more lightweight 3.8 kg. Additional improvements in power efficiency allow up to seven hours of battery-powered operation from six AA batteries. The 88-key model newly provides an accessory compartment that can hold spare batteries or cables, as well as an easily accessible front-located battery panel. On both models, the rear panel KORG logo is fully illuminated, letting you stand out on stage.
The ultimate body finish that exceeds its class
The evolved KROSS 2 also features high quality in its body finish. First, the 88-key model uses a stylish and cool "dark blue" color. The 61-key model uses a "super matte black" color with a high-quality rubberized finish that is durable and feels great to the touch. Lavish use of this sophisticated rubberized finish gives the instrument a highly professional appearance. The 61-key model is additionally available in a limited-edition "red marbled" color. The special marbled red finish is unique and different on each KROSS 2 unit.
Audio player/recorder that you can easily trigger from the pads
The built-in stereo audio recorder lets you record your KROSS 2 performance, or overdub an external input source such as vocals. There's also a pad audio play function that allows recorded sounds or audio files imported from an external source to be assigned to each of the 16 pads for playback. Unlike the sampling function, this allows extended recording and playback that is limited only by the capacity of the SD card; you can strike a pad to play back the backing of an entire song while you perform on the keyboard, or use the pads to trigger sound effects or background music.
Supports your song production, turning inspiration into reality
16-track MIDI sequencer
The 16-track MIDI sequencer records your keyboard performance and controller movements as MIDI data. It can also record your pad sampler performance, providing an easy way for you to create sketches of ideas for songs.
Step sequencer
This lets you use the 16 pads to intuitively and quickly create original rhythm patterns of up to 64 steps.
Drum track
The drum track lets you add rhythm to your performance simply by pressing a button. Choose from 772 preset drum patterns that cover a variety of styles.
Arpeggiator
This function is a great way to generate ideas for songs; simply hold down keys to generate rhythmic chords, bass phrases, or guitar strumming.
Mic connection for the singer-instrumentalist or for vocoder performance, with no other equipment needed
The 1/4" phone MIC IN jack lets you connect a mic directly, so there's no need for a singer-instrumentalist to provide a separate mixer when performing live. A vocoder function is also built-in, and you can easily perform vocoder sounds with rapid access via the realtime control section. Also provided is a LINE INPUT stereo mini-jack that's convenient for connecting your audio player or for sampling.
Also operates as a USB audio interface
In addition to USB MIDI interface functionality, USB audio interface functionality has been newly added. You can connect the KROSS 2 to your Mac or Windows computer and enjoy DAW recording, or easily use the instrument for playing in conjunction with your iPad or iPhone. The KORG Module high-quality sound module app can be used as an external sound module that's played from the KROSS 2, or you can perform with the backing of tracks that you created using the KORG Gadget DAW app, all with the ease of connecting a single cable.
A dedicated KROSS2 Editor and Plug-In Editor are also provided. These let you edit while viewing numerous parameters at a glance on your computer, or allow you to use the KROSS 2 as a software synthesizer from within your DAW.
Specifications
Kross 2 61:   61 keys (velocity sensitive; aftertouch not supported)
Normally C2 â"€ C7(adjustable in the range [C1...C6] â"€ [C3...C8]
Kross 2 88:   88 keys NH (Natural weighted hammer action) keyboard (no aftertouch)
Normally A0 â"€ C8 (adjustable in the range A-1...C7) â"€ [A1...C9])
* The NH keyboard delivers a playing feel similar to that of an acoustic piano, with low notes being heavier and high notes being lighter.
System:   EDS-I Enhanced Definition Synthesis - integrated
Sound Engine:
Maximum Polyphony
120 voices (120 oscillators), single mode
60 voices (60 oscillators), single mode
* The actual maximum polyphony will vary depending on oscillator settings such as stereo multisamples and velocity crossfading.
Preset PCM Memory:   Approximately 128 MB (calculated as 48 kHz / 16-bit linear PCM data equivalent)
496 multisamples (including seven stereo), 1014 drumsamples (including 49 stereo)
Expansion PCM Memory:   Approximately 128MB (*when converted to 48 kHz 16-bit linear PCM
* Used when loading option PCM
Program:   Oscillator: OSC1 (Single), OSC1+2 (Double): Stereo multisamples are supported 4 velocity zones per oscillator, with switching, crossfades and layers.
Filters: Four types of filter routing (single, serial, parallel, 24 dB)
Two multi-mode filters per voice (low pass, high pass, band pass, band reject)
Modulation: For each voice, two envelope generators (Filter & Amp), two LFOs, two key trackinggenerators (Filter & Amp), and two AMS mixers. In addition, pitch EG, common LFO, and two common key tracking generators
Combination:   Timbres: Up to 16 timbres, switchable via key zone or velocity zone, layer and crossfade supported, Tone Adjust function allows program settings to be offset
Master Keyboard functionality: These allow you to control external MIDI devices
Drumkits:   Stereo and mono drumsamples. 4-way velocity switches with crossfades and adjustable crossfade shapes (Linear, Power, Layer).
The Number of Combinations/Programs/Drum Kits:   User Combinations: 896 Combinations (384 Preload)
User Programs: 1280 Programs (768 Preload)
User Drum Kits 58 Drum Kits (42 Preload)
Preset Programs 265 Programs (256 GM2 Programs + 9 GM2 Drum Programs)
   *: It is not possible to change the sound per track.
Favorites:   Number of memories: 128 (16 favorites × 8 banks)
Effects:   Insert effects:5 Insert Effects In-line processing; stereo in - stereo out.
Master effects:2 Master Effects Two effects sends; stereo in - stereo out.
Effects types:Total of 134 types (select from 74 types for insert effects, 101 types of master effect 1, and 120 types for master effect 2)
Modulation:   Dynamic Modulation
Effects Control Bus:   Stereo side-chaining for limiter, gates, vocoders, etc.
Polyphonic arpeggiators:   Program mode:one arpeggiator
Combination mode:two arpeggiators
Sequencer modes:two arpeggiators
Preset arpeggio patterns:UP, DOWN, ALT1, ALT2, RANDOM
User arpeggio patterns:   Number of arpeggio patterns: 1280 (1024 preload)
Number of tones: 12 tone,
Number of steps: up to 64 steps
Step sequencer:   Program mode
Combination mode
Sequencer mode
Number of tones: 12 tones + 1 accent tone
* Can be created for each program, combination, and song.
Drum Track:   Preset Patterns: 772 patterns (Held in common with sequencer patterns.)
Other: Trigger Mode / Sync / Zone settings can be specified
Sequencer:   Tracks:16MIDI Tracks
Number of Songs: Up to 128 songs
Resolution: 2/480
Tempo: 40.00 â"€ 300.00 (1/100 BPM resolusion)
Maximum Memory: Up to 210,000 MIDI events
Counter: Measure/Beat/Tick
Template Song: 16 preset/16 user template songs
Preset Patterns: 772 patterns (shared with Drum Track patterns)
Format: KORG (KROSS) format, SMF format 0 and 1
Pad sampler:   Specifications:16 pads × 8 banks
Automatically saved on the SD card, and automatically loaded Up to four pads can play simultaneously
Recording format:   PCM audio format 48 kHz/16-bit
Recording time:   Up to approximately 14 seconds of stereo sample for each pad
Importing:   WAVE format, file name extension: .wav, 44.1 kHz/16-bit, 48 kHz/16-bit, stereo * 44.1 kHz is automatically converted to 48 kHz
Edit:   Waveform display editing functionality, start address and looping settings etc., normalize and other editing operations
Audio Recorder:   Recording Format: PCM audio format 48kHz/16bit
Import:   WAVE format (file name extension: wav ) 44.1kHz/16bit, 48kHz/16bit stereo * 44.1 kHz is automatically converted to 48 kHz
Export:   WAVE format (file name extension: .wav) 48kHz/16bit, stereo
Recording Time:   Maximum continuous recording time: 3 hours Depends on the SD card used; approximately 90 minutes per 1 GB
Number of Songs:   Up to 200 songs
Number of overdub recordings:   Depends on the remaining capacity of the SD card
Counter:   Hour/Min/Sec
Pad audio play:   16 pads × 8 banks
Directly play back data from SD card
Multiple pads cannot be played simultaneously
Media:   File, Utility, Information, additional PCM data management functionality
Controllers:   General Control: Pitch bend wheel, Modulation wheel, SW1, SW2
Realtime Control: SELECT button, SWITCH button, KNOB1 knob, KNOB2 knob
Step Sequencer/Favorite/Pad Sampler/Pad Audio Play: Pads 1 â"€ 16 STEP SEQ ACTIVE button, Run button FAVORITES ACTIVE button SAMPLER ACTIVE button, HOLD button AUDIO PLAY ACTIVE button BANK LEDA/B/C/D/E/F/G/H (also used by Step sequencer, Favorite, Pad Sampler, and Pad Audio Play)
Drum Track:DRUM TRACK button
Arpeggiator: ARP button
Audio Recorder: AUDIO REC button
User Interface:   Display: 240×64 pixel LCD backlight Adjustable contrast (hold the EXIT button and turn the VALUE dial)
Category: CATEGORY dial, VALUE dial
MODE: COMBI button, PROG button, SEQGLOBAL/MEDIA button
Value Controller: Cursor buttons, EXIT,ENTER, FUNCTION, PAGE-, PAGE+, MENU buttons
Sequencer: REC button, START/STOP button
Quick Layer Split: LAYER/SPLIT button
Other: VOLUME knob
Control Input:   DAMPER (Supports piano-style half-damper pedals as well as standard foot switches)
ASSIGNABLE SWITCH
ASSIGNABLE PEDAL
Audio Outputs (Analog):   AUDIO OUTPUT L/MONO, R:
Connectors: 6.3mm (1/4") phone jacks(TS unbalanced) Output Impedance: 1.1k ohm stereo, 550 ohm mono (L/Mono only) Maximum Level: +10.0dBu Load Impedance: 10k ohm or greater Controllable by the VOLUME knob
HEADPHONE OUTPUT:
Connectors: 3.5mm(1/8") stereo mini phone jack Output Impedance: 33Ω Maximum Level: 40+40mW Controllable by the VOLUME knob
Audio Inputs (Analog):   LINE IN Connectors:
3.5mm(1/8") stereo mini phone jack Input Impedance: 1.1kΩ Maximum Input Level: -42 to 0 dBu
MIC IN Connectors:
6.3mm (1/4") phone jacks(TS unbalanced) Input Impedance: 33Ω Maximum Input Level: -48 to -6dBu Phantom power or plug-in power is not supported.
Others:   MIDI: IN, OUT
USB: USB connector TYPE B x 1, USB-MIDI interface, USB audio interface
SD Card Slot: One card slat
* Capacity recognized: SD memory cards up to 2 Gigabytes (GB). SDHC memory cards up to 32 Gigabytes (GB). SDXC memory cards are not supported.
Main Specifications:   Power: AC adaptor power supply DC 9V AA alkaline batteries x 6, or nickel-metal hydride batteries x 6
Battery Life: AA alkaline batteries x 6: Approximately 6 hours AA nickel-metal hydride batteries (1900mAh) x 6: Approximately 7 hours
Power Consumption: 5W
Dimensions (W x D x H):   KROSS2-61: 935 mm × 269 mm x 88 mm / 36.81" × 10.59" × 3.46" KROSS2-88 1,448 mm × 383 mm × 136 mm / 57.01" × 15.08" × 5.35"
Weight:   KROSS2-6: 3.8 kg / 8.38 lbs (excluding batteries)
KROSS2-88: 12.3 kg / 27.12 lbs (excluding batteries)
Included Items:   AC adapter, Quick Start Guide
Accessories (sold separately):   Keyboard stand KROSS2-61: Standard-S-BK61 and KROSS2-88: Standard-L-SV88
Soft case KROSS2-61: SC-KROSS 2 61 and KROSS2-88: SC-KROSS 2 88
Expression/Volume Pedal: XVP-20 and XVP-10
Foot Controller: EXP-2
Damper Pedal: DS-1H
Pedal Switch: PS-1 and PS-3
* Specifications and appearance are subject to change without notice for improvement.
* All product names and company names are the trademarks or registered trademarks of their respective owners.
Quick Start
http://cdn.korg.com/us/support/download/files/f976a1b85ad4179beb679ece0806d85f.pdf
Operating Guide
http://cdn.korg.com/us/support/download/files/8ad0d64fd4d2d405c7399768dd509610.pdf
Parameter Guide / Complete MIDI Implementation
http://cdn.korg.com/us/support/download/files/96dbde75752a88b2daf897262d199b80.pdf
Voice List
Basic Information
About the KROSS's modes
The KROSS has four modes
The KROSS has numerous functions that let you play and edit
programs or combinations, record and play back sequence data,
and manage media. These functions are grouped into "modes."
The KROSS has four modes.
Program mode
Programs are the basic sounds of KROSS.
In Program mode, you can:
• Select and play Programs.
• Use one arpeggiator in your performance.
• Play back Drum Track patterns while you perform using
a Program.
• You can use the step sequencer to easily create drum
loop patterns. You can play a program while a drum
pattern plays back. You can also perform simultaneously
with the arpeggiator and drum track.
• Edit Programs
You can use the Tone Adjust function to easily edit the
program.
You can use the quick layer/split function to easily layer
two programs or create split sounds.
You can adjust the parameters and settings of the
oscillators, filters, amps, EGs, LFOs, effects, arpeggiator,
drum track, etc.
You can use up to five insert effects, and two master
effects.
Plus, you can create drum programs using drum kits (as
created in Global/Media mode).
Combination mode
Combinations are sets of up to 16 programs that can be played
simultaneously, letting you create sounds that are more complex
than a single Program. In Combination mode, you can:
• Select and play Combinations.
• Use multiple timbres to play arpeggio patterns generated
by two arpeggiators.
• Use one timbre for the drum track pattern, and play back
a drum pattern while you perform.
• Use the step sequencer to easily create drum loop
patterns. You can play a combination while a drum
Use the KROSS as a 16-track multi-timbral MIDI tone
generator.
• Edit Combinations
You can use the tone adjust function to easily edit the
program of each timbre.
You can assign Programs to each of the 16 Timbres, each
with separate volume, pan, and keyboard and velocity
zones; adjust settings for effects, arpeggiator, drum track,
step sequencer.
Plus, you can use up to five insert effects, and two master
effects.
Sequencer mode
Sequencer mode lets you record, playback, and edit MIDI tracks.
You can:
• Use the sixteen-track MIDI sequencer to record and play
back songs.
• Record a single MIDI track, one at a time, or record as
many as all sixteen tracks simultaneously. You can also
record system exclusive messages.
• Record and play back the pad sampler performance.
• Use multiple tracks to record and play back
performances generated by two arpeggiators.
• Use one track for the drum track pattern, and play back
or record a drum pattern.
• Use the step sequencer to easily create drum patterns.
• Edit songs
• Use the KROSS as a 16-part multi-timbral sound
module.
• GM/GM2 playback is also supported.
• Use the Tone Adjust function to easily edit the program
of each track.
• Use up to five insert effects, and two master effects.
Global/Media mode
Here is where you can save/load data on an SD card. You can also
adjust overall settings for the entire KROSS, and edit drum kits
and arpeggio patterns.
You can:
• Adjust settings that affect the entire KROSS, such as
master tune and global MIDI channel.
• Create user scales
• Create drum kits using drumsamples.
• Create user arpeggio patterns.
• Set the function of the assignable pedals and assignable
buttons.
• Transmit MIDI System Exclusive data dumps.
• Save and load Programs, Combinations, MIDI Songs,
and Global setup data.
• Format the SD card.
• Export and import sequences to and from SMF (Standard
MIDI Files)
Other functions
In addition to its four modes, the KROSS provides various
functions that are convenient for performance and practice: audio
recorder, pad audio play, pad sampler, and favorites.
AUDIO RECORDER
There's an independent audio recorder that can record an audio
signal from an external mic or line input, or USB audio input, or
the audio of the program, combination, or sequencer
playback.The sequencer and audio recorder are not able to
synchronize. (see page 99)
PAD AUDIO PLAY
Using this function, audio songs that you recorded or audio files
that were imported from an external source can be assigned to the
pads and recalled easily for playback.
Introduction to the KROSS
PAD SAMPLER
Using this function, external input audio or phrases that you
perform can be recorded and saved as sample data, and assigned
to pads 1-16 for playback. Up to four samples can play back
simultaneously, while you use pad operations to play samples as
one-shot or as a loop. Control the data filer function (save and
load MIDI exclusive data).
Favorites function
You can register programs or combinations to pads 1-16 and
recall them instantly regardless of the mode you're in.
https://youtu.be/EPqjIeoKtVU
https://youtu.be/Vf1TOebpWfY
https://youtu.be/Mt9tnaCB0O8
https://youtu.be/P1TNGXxjpA0
https://youtu.be/f8IAZ3-iO_w
https://youtu.be/rLHNO59wcz8
https://youtu.be/KvOXHMFWHVk
https://youtu.be/HBIjWGDRK_A
https://youtu.be/oDy0Fw5yVOA
https://youtu.be/u2vyxn6nZ7Y
https://youtu.be/jm50UGf98FU
https://www.musicmatter.co.uk/news/korg-kross-2-synthesizer-workstation-updated
Korg Kross 2 Synthesizer Workstation Recieves An Update
15 Sep 2017
The Long-Awaited Successor Of The KROSS, Is A Compact, Portable Workstation With Huge Range Of Sounds
Also new is a pad sampler that allows full-fledged sampling, and USB audio/MIDI interface functionality. The color scheme is even more stylish, and the user interface allows intuitive operation even by beginners.
Korg Kross 2 Synth Range
Korg Kross 2 Presets
Korg EDSI Integration
Korg Kross 2 Pad Sampler
Favorites function
Quick layer/split
The layer/split function, which lets you layer two sounds or assign separate sounds to the left and right regions of the keyboard, is now easier to set up, thanks to a dedicated quick layer/split button.
Category dial
https://youtu.be/3TaA-UZ5_3M
Off the record, the people we spoke to at Korg were baffled at the amount of features crammed into the Kross 2 - as you would expect, the usual feature set from an affordable workstation-like keyboard, with PCM based sound sets, FX and performance controllers. But the addition of audio recording, sampling and sample playback, it seems they went the extra mile.
Luke from Korg gave us a quick look at what Kross 2 offers.
Korg Kross 2 software finally available !
KROSS 2 System Version 1.1.0
KROSS system version 1.1.0 includes a number of new features, as listed below.
•Support for the KROSS2 Editor and Plug-In Editor
•Load .KSC, .KMP and .KSF sample files
•Pad Sampler – Export to KSC and WAV
•REALTIME CONTROLS – VOCODER improvements
In addition to the new features, KROSS 2 System Version 1.1.0 includes various improvements and resolutions to specific operational issues.
We recommend that all KROSS 2 users update to version 1.1.0. This update may be installed on any KROSS2, regardless of the currently installed system version; it is not necessary to install intermediate upgrades first.
KROSS System Version 1.1.0
KROSS 2 Editor/Plug-In Editor 1.0.0
The KROSS 2 Editor and KROSS 2 Plug-in Editor are applications for Macintosh and Windows that allow you to edit the KROSS's Program, Combination, Drumkit, Arpeggiator Pattern and Global settings, as well as Sequencer mode sounds and effects for multi-timbral use (editing of MIDI data is not supported).
•The KROSS 2 Editor is a stand-alone editor.
•The KROSS 2 Plug-in Editor is compatible with DAWs (Digital Audio Workstations) and other applications which have support for the VST and AU plug-in formats.
The KROSS 2 Editor and Plug-In Editor 1.0.0 requires KROSS2 System Version 1.1.0 or later.
http://www.korg.com/us/support/download/product/0/754/#software
Software
Mac / Win
KROSS/System Updater1.1.02018.03.23 / ZIP : 61.9MB
Win
KROSS/Editor/Plug-In Editor1.0.02018.03.23 / ZIP : 22.1MB
Mac
KROSS/Editor/Plug-In Editor1.0.02018.03.23 / DMG : 15.8MB
Drivers
Release notes
- Support for the KROSS2 Editor and Plug-In Editor
- Load .KSC, .KMP and .KSF sample files
- Pad Sampler – Export to KSC and WAV
- REALTIME CONTROLS – VOCODER improvements
In addition to the new features, KROSS2 System Version 1.1.0 includes various improvements and resolutions to specific operational issues. For more information, please see the Release Notes.
We recommend that all KROSS2 users update to version 1.1.0. This update may be installed on any KROSS2, regardless of the currently installed system version; it is not necessary to install intermediate upgrades first.
Notes
Notes:
This new operating system is NOT compatible with the original KROSS.
Requirements:
・An MS-DOS formatted SD card or SDHC card. 5Mbyte or more free space .
・A computer and a card reader
http://www.korg.com/us/support/download/software/0/754/3833/
