Mark L Custom Amps - Subzero 60 Stereo Tube ( Poland)
Started by admin, January 15, 2018, 01:27:14 PM
http://mmail.marklcustom.com/en/amplifiers-cabinets/subzero-60-stereo
http://mmail.marklcustom.com/en/photo-video/video-gallery
MLC Subzero 60 Stereo
MLC SUBZERO SERIES - three channels of jaw dropping classic to modern rock tones. Impeccable build quality and durability for life on the road, or in your home studio.  Incredible amp function and FX loop controls with optional MIDI integration.  Stunning touch dynamics while still bringing the thunder....
MLC AMPLIFIERS - handmade in Poland, highest quality military grade components, custom handmade transformers, OMRON and BELTON preamp tube sockets, TUNG SOL tubes and ceramic power tube sockets with gold plated contacts.
All holes are plated through the PC board to give the strength and reliability of point to point wiring. Laser cut chassis, solid 2mm welded aircraft grade aluminum.
Hand build with only the best sounding and most reliable parts, and as with all of our amplifiers. 1% metal film resistors and fully regulated DC preamp tube heaters are used for the lowest noise and longest tube life.
MARK L CUSTOM - a tradition of creating  amplifiers with rich, balanced sound and unmatched musicality including superb touch sensitivity, note articulation, string to string separation and dynamic response.
                                               ...the next evolution of guitar amps!!!
MLC SUBZERO 60 STEREO features:
output power 2 x 60 watt
3 channels (Clean, Crunch, Lead)
CLEAN – Volume, Gain, Treble, Middle, Bass, 3 pos. Bright switch  ( CLEAN channel offers a full range of American voiced clean sounds )
CRUNCH – Volume, Gain control ( hot-rodded 2 stage"PLEXI 1968" British sound )
LEAD – Volume, Gain control ( hot-rodded 3 stage "PLEXI 1968" British sound )
common tone regulation ( Bass, Middle, Treble) for both channels CRUNCH  & LEAD
master or non master volume
PRESENCE control of HI frequency response in the power amp stage
DEPTH control of LO frequency response in teh power amp stage
4-way channel switch
2 x 3-way speaker impedance switch
speaker outputs ( 2 x 4 ohm, 2 x 8 ohm, 2 x 16 ohm )
2 x EL34 TUNG SOL power tubes for RIGHT channel
2 x EL34 TUNG SOL power tubes for LEFT channel
6 x 12AX7 TUNG SOL preamp tubes
MIDI control (Clean, Crunch, Lead, FX Loop, Solo, Mute )
5 functions foot switch ( Clean, Crunch, Lead, Solo, Mute )
MIDI IN, MIDI THRU Out
midi channel switch
ultra transparent and buffered STEREO FX loop  (adjustable +4db/-10db)
FX loop SEND optimized for WET/DRY/WET systems
Worldwide voltage ( 115VAC / 230VAC )
dimensions (width x depth x height) 660 x 270 x 320
weight - 26 kg
Handcrafted in Gdansk, Poland
List price: 2699,00€ include 23% Polish VAT
Delivery: 1 week
Product Included:
SUBZERO 60 STEREO
5 functions footswitch
Power Cord
Manual
Check out their foot pedals too.
http://mmail.marklcustom.com/en/guitar-systems/fx-25-expander-2nd
MLC FX-25 Expander 2nd
Our FX line of MIDI controllers were built with one goal in mind: To be the most dependable, easy to use, and functional guitar system controller on the planet. Bulletproof tour grade construction, MAC & PC compatibility, and infinite MIDI options to give you full control over your rig....no comprises!
The new ergonomic aluminum casing, equipped with an alphanumeric LED display and high-quality buttons ensure longevity and operational ease. The device sends 128 PROGRAM CHANGE commands, 128 CONTROL CHANGE commands over 16 midi channels and works with 2 expression pedals and 2 additional expanders. The FX–25 comes equipped with a 15-position alphanumeric display informing which BANK/SONG has been chosen (1–64) as well as song title, preset and is also used for function service in program mode
With the EXPANDER SECOND you now have ability to double the expansion capabilities of the original FX-25, providing you with a total of 27 direct access switches.
The EXPANDER SECOND  provides you with 9 additional direct access switches for Control Change functions.
Connecting the EXPANDER SECOND to your FX–25 couldn't be easier, as every FX–25 is automatically designed to know when an EXPANDER is connected, eliminating the need for expensive modifications or software updates.
Warranty 2 years.
List price: 299,00€
include VAT 23%. In stock.
http://mmail.marklcustom.com/en/guitar-systems/interfaces
