I get an electrical smell when running k100 1x12 at full blast??
Started by joeshmoe69, December 17, 2017, 09:01:23 AM
joeshmoe69
A couple times I have cranked the 100 1x12 at full blast for a few mins and
I get an electrical smell from the amp.
Not burning but clearly electrical, is this ok and will it go away after more
hi volume use???
It works perfectly by the way.
Jimmy
joeshmoe69
I had to go in the bedroom ;D
Jimmy
By the way, I love this AMP!!!!!!!!!!!!!!
Rhcole
Your smell is too much heat trying to dissipate. An overheated amp usually doesn't get better over time. The smell is of components being pushed beyond what their designers thought they would have to endure. If you kept it up, the amp could easily go out. If you back off short of that limit, you may not have a problem.
sikejsudjek
You will probably damage the amp. Oh and your ears ! Max volume on this amp gives a safe listening time of under 28 seconds. After that you have hearing damage. With a loudish drummer I only could get it to half power in 50w mode before it was drowning out the drums !  :)
...try sticking the GUITAR volume on full and then slowly turning the amp up...if you can still stay in the room, either it's your guitar or your ears that are stuffed!
..maybe get one or both checked before the smoke escapes... ;)
As a person with severe tinnitus and hyper accusis I'd strongly advice
not cranking your amp like described.
An electric smell / fire is your least problem
I actually think a lot of modern amps have a funky smell when driven.  It improves over time.
Just Google "amp burn in smell"...  Lots of reports across multiple forums.   New amps...
Also, different rooms absorb sound differently.   Wide open rooms with dead walls + old punk drummers flailing away on the drums = volume required ...
There were lots of reports of the EV ELX-112Ps smelling "like weed" during burn-in.
Mine smelled like blown circuit breakers.  Made me wonder what the heck they were smokin'...
Rhcole
As a guy who has smoked a couple of amps in my day, I sincerely recommend not trying to "burn off" electrical smells by cranking it up.
...If you get a smell like frying fish, time to end the gig REAL SOON.
joeshmoe69
The only reason I cranked it was to give the speaker
some hard use toward break in. A couple of 4-5 min sessions.
It sounded majestic, like a stack, a Marshall stack.
I used to own one so I know what its like.
I dont see ever having to go past the 50 watt setting.
Great amp! ;D
Jimmy
Quote from: joeshmoe69 on December 21, 2017, 04:03:00 PM
Great amp! ;D
Jimmy
I agree with all you said!  ;)
myksara
This is interesting...I have never used the katana 100 outside the bedroom..what is the  settings that will help with the speaker to break in and give its best tonal performance?
Both for katana 100 1x12 and cube street ex?
Quote from: myksara on December 21, 2017, 07:09:51 PM
There is  common new guitar amp concept called "New Guitar Speaker break in" -
It has positive results
https://www.guitarplayer.com/gear/guitar-essentials-how-to-break-in-a-new-speaker
click here and watch videos
https://www.google.com/search?biw=1396&bih=682&tbm=vid&ei=d6w8Wp29Haea0gLG54voDw&q=New+Guitar+Speaker+break+in%22+&oq=New+Guitar+Speaker+break+in%22+&gs_l=psy-ab.3...813386.814872.0.815215.3.3.0.0.0.0.114.222.0j2.2.0....0...1c.1.64.psy-ab..1.0.0....0.EDPjEQgd7f0
