GR-55 - Overdrive on Electric Piano
Started by airton000, December 29, 2017, 02:41:34 PM
airton000
Hi all
I'm trying to simulate a Fender Electric Piano.
When editing, I turn on FX/Overdrive. Then sound is modified and do not turn back. Even turn off FX.
Must to go to next patch and return to ??? give recorded patch.
Is it a bug ?
Thanks in advance
It would need to be MOD (modulation effects) DISTORTION, I have never had any issues with switching the effect on/off.
It could be an assign, that is changing the sound. Do you use the CTL switch to turn the distortion on and off? Then make sure CTL doesn't change another parameter.
