Input Level settings.. not programmable to each patch?..
Started by Cam Grant, May 01, 2023, 11:29:16 AM
Cam Grant
Just got a Core, and was setting up different levels for different guitars in INPUT section of "In-Out Settings".. and after trying to write a patch with each setting, it applys that setting to all patches... what am I missing?.. I want each patch to have it's own Input setting, help me, Obi-wan, you're our only hope!
GT1000-CORE, VG-99, VG-88 , Custom GK loaded Strats, & Teles. Taylor Acoustic, Rickenbacker 330, Rickenbacker 620,VOX AC15, AC10.
Cam Grant
Nevermind!, found it!.. once again Youtube to the rescue!
Cam Grant
Boisdelac
If you are asking for Input Level setting for a certain patch and a certain guitar your headline is not really correct. Ask a Mod to change it to
"Input Level settings.. not programmable to each patch?.."
In the case you want a certain output level per patch, go to the master section and set the parameter "patch level".
Changed title from output to Input so as to reflect the correct topic content.  8)
