NUX Mighty Space Videos
Started by Elantric, April 12, 2023, 08:49:34 AM
m
Been testing a NUX Mighty Space amp .
It's the current pinnacle of NUX DSP processing. And very good sounding.  On paper it seems to be the Nux Mighty Plug Pro in a larger package, but in reality the hardware specification and quality of fit & finish is superior on Mighty Space - and this unit lacks the annoying non cancelable high frequency hiss artifacts of Mighty Plug Pro. This allows the user to experience what the Nux DSP developers intended. It's also very loud as a Bluetooth speaker. It includes a 2.4GHz 24 bit wireless guitar system, but my Dick Dale playing technique reveals flaws in all wireless systems as all perform companding/ compression  for noise reduction with resulting pumping/ gating if you pick too hard ( like playing Miserloo on Low E string) - so Ill use a quality guitar cable.
Soon I'll try to use Xsonic Airstep wireless MIDI Footcontroller with Tuntoris Mightier Amp app to make the connections.
Ludek
Mighty Space is a real gem! I used to have Katana Air THR 30W II and though both of them are really good sounding small amps, the experience Mighty Space brings me, is beyond compare. Such a joy to noodle with its seamlessly operating looper (even having UNDO and REDO - which is  quite a rare function), to learn my favorite songs (or its more difficult parts) with a trainer providing possibility (as Boss Pocket GT does) to change automatically assigned presets during the song playback. And the sound possibilities - within the Mightier Amp app I've already created more than fifty presets organized into logical groups (clean clean reverb, clean reverb modulate, etc.). I must say the sound (speaking about listening to headphones as I haven't had much chance to test it loud) is on par with other major multieffects. Battery life is more than pleasing as is     the transmitter's charging life. As Elantric says - the only thing that should be added is to connect the Mightier Amp app bluetooth section to any BT pedal - I'll try as well.
Ludek
Dear Elantric have you had any experience with XSonic controlling Mighty Space? Thank you
Quote from: Ludek on August 14, 2023, 11:41:42 PMDear Elantric have you had any experience with XSonic controlling Mighty Space? Thank you
still testing USB connection
Full Xsonic Airstep should work with the right USB-C to USB-C audio/video qualified USB-C Cable
https://xsonicaudio.com/pages/airstep
 Joko at NUX uses a Pedalbot MIDI USB Controlller with  its unique USB Host port.
the wireless footswitch option employs a phone running MIGHTIER  AMP  app
https://github.com/tuntorius/mightier_amp
https://fb.watch/mrQqF6h_uP/
Appears Joko employs a PedalBot PB-M4-U MIDI Controller with built in USB Host port when using NUX Mighty Plug Pro /Mighty Space - no computer/android/iphone required.
https://www.facebook.com/pedalbot
