GK3 internal g string failing, but works for a short while if I jiggle it
Started by Bendy, February 04, 2023, 09:58:17 AM
Bendy
So yeah my old faithful has started to play up on just the G string. If I jiggle it it will work for a while and then fail again.
Has anyone had this problem and fixed it?
I am wondering if its failing and I should just get a new one fitted?
Thoughts appreciated
Ta
A technician can inspect GK preamp  and inspect /test the 8 pin PU header crimp connections
But 80% of time it's due to a faulty GK13 cable or oxidized pins on the connectors
Solutions here
Bendy
Thanks for the response.
I am pretty sure it's the actual pickup. I have tried several cables and it does short term fix if I physically wiggle the actual pickup.
Ta
Bendy
So I replace the hex pickup part only and it works lovely again.
Ta
