GT-1000- Trigger
Started by noe66, September 27, 2022, 04:27:13 AM
noe66
Hello,
Is there anyone who have an exemple on thé use of trigger in some effects?
Because i can't see the différence with on/off
Quote from: noe66 on September 27, 2022, 04:27:13 AMHello,
Several FX feature a Trigger parameter (Twist, Warp, Feedbacker, etc)
Which specific FX Trigger are you interested in?
noe66
it's not an effect particularly but I don't understand trigger  advantage  over a simple on/off
Boisdelac
Some effects are not switched on and off within the chain, but are permanently on. the actual effect is then started by the trigger.
Trigger means here to start a certain effect at a certain time ( e.g. as soon as you press a button).
E.G. assign CTL1 to the trigger of the feedbacker. Your guitar will start to sound like a feedbacking guitar as soon as you press CTL1.
