GX-100 limitations
Started by Magic Russ, July 27, 2022, 04:43:12 PM
Magic Russ
One interesting thing about the GX-100 is that you can use up to 9 instances of an effect depending on how much processing power the effect takes.  For those who are wondering specifically what that means:
Assuming you have one amp sim loaded you can also load
2 instances of Tera Echo
3 instances of Overtone or Reverb+
5 instances of Shimmer Reverb, Prime Chorus, Prime Phaser
6 instances of Vibrato Prime
7 instances of Analog Delay or Flanger Prime
8 instances of Octave Poly, Metal, S-Bend, X-OD
9 instances of any other effect.
I haven't tested, but I am assuming the bass versions are roughly as processor intensive as guitar effects.
