Ideas on how to affix GT-1 to pedalboard?
Started by buduranus2, July 20, 2022, 07:53:18 AM
buduranus2
There are only five points where I can put velcro but the GT-1 is too heavy. Any idea how to get the rubber feet off without damage? Then I could use longer velcro strips. Maybe there's another way?
I use a Razor blade, and store the rubber feet I remove from bottom plate
slooky
I made my own pedalboard out of wood. I attached the Gt-1 using 2 screws and a wire. The wire goes right beside the volume pedal.
dnr101
I found that normal Velcro was thick enough that I could put strips of it on the back of the gt-1 in between the rubber feet, and being careful to leave space with no Velcro on the pedalboard for the feet, with a little pressure (like, stepping on it pressure, but not excessive) it grips fine.
