GX-100 - INIT patch
Started by jozart, May 21, 2022, 08:12:48 PM
jozart
200 empty presets
Boisdelac
What's the point behind 200 empty presets?
jozart
There is no direct way to completely initialize an empty preset, and no easy way to completely initialize a block of presets. So users in the know will create a completely empty bank and copy from that.
GX-100 users should also check out the new Boss Tone Exchange.
Magic Russ
I prefer what you get when you initialize the preset in BTS (the dropdown underneath WRITE).  It gives you a chain containing WAH, FV, a Div with two AMPS, boost, delay, chorus, reverb, with the Expression pedal and switch configured to wah and volume already.
I have been going through some of my presets from older units.  I found that there are generally a few patterns that I like to use
Single chain
Single Amp, switchable chain in front
Divider with amps in parallel
Divider with switchable channels
I usually want a wah pedal and volume pedal in front, noise suppressors after the amps, and ending with delay-chorus-reverb.
Sometimes I will want a pedal bend in there instead of a wah pedal.
For my purposes, a liveset containing 6 or 8 templates fits my need better than an entirely empty patch.
