Boss Katana exp pedal
Started by mucecia, March 06, 2022, 09:52:58 AM
mucecia
Hi guys,
is it possible to get the midi signal from midi in (EXP Pedal) on Katana and assign it through the DAW to control other things?
For example - there is a way to connect the same exp pedal to midi in (exp pedal in) on midi keyboard and assign that signal to virtual wah pedal on Amplitube.
The problem in my situation is that my midi keyboard has only sustain pedal in so if I assign exp pedal through sustain pedal midi in I get only on/off functionality and it work not as exp pedal should...
I know that I can purchase any midi adapter/controller that has exp pedal in, but I believe that technically Katana should do the same thing..?
Does anyone has any thoughts?
Best regards,
Arūnas
Only 5 pin MIDI In on Katana Artist/Head
Katana MIDI over USB has limited function
Not possible to have Expression pedal assign to MIDI CC#  and transmit MIDI CC# data over USB
