The Sketcher - planning your stage layout.
Started by Elantric-fgn, April 15, 2010, 08:53:28 AM
Elantric-fgn
If you would like some help planning your stage layout, or just share something you are doing that works, please try
The Sketcher.
http://toonz.ca/sketcher/sketcher.aspx
In its current incarnation, you drag items from the palette of instruments onto a stage area.
You can add notes (a good idea) for things that don't fit into the picture.
When you save your changes, I will take what you have done and turn it into a regular image that is viewable on the web and post it in the Sketcher Discussion with comments. When you follow this link, jump to the last page. Your Sketch will likely be there.
Hints:
Printing - You can print your Sketch on your computer. When you are viewing it in The Sketcher, right-click with your mouse for a menu. You will see an option to print. It's small but it works.
Notes Section
If you are using Sketcher to develop your own stage layouts - that's great - have fun with it. If you don't need us to do any work on your Sketch, please put a message in the Notes section so we know what you are doing. Thanks.
Edit
- updated intro image for version 4.0
- added hints
- added image with balloon comments
