Editor for the GR-55 - GR-55FloorBoard - has been updated
Started by gumtown, January 27, 2021, 05:59:17 PM
If you have landed here looking for an editor for the GR-55, you are in luck.
The GR-55FloorBoard editor is a 3rd party (not affiliated with Roland) editor software for the use with the GR-55.
Detailed discussion can be found in this topic:
https://www.vguitarforums.com/smf/index.php?topic=2951.0
GR-55FloorBoard has just had an update to version 20210127 (27 Jan 2021)
get the latest download from
https://sourceforge.net/projects/grfloorboard/files/GR-55/
fixes some of the mentioned above issues with patch write and timing. also added the whole patch collection into it and changed the main screen 'init patch' thing to a general "Patch Library" for easy access and loading of patches in the saved library.
Adonf
Egsolidbody French Kit SM-DC Deluxe
Roland Gr 55
Line 6 Ux1
Soundcraft EPM8
katana MK2 100
Marshall Valvelstate 80v
Prs se Santana 2002
Focales Alpha 50
bryanz
NickS
Benjazz31
heavenlyguitar
Thanks for the GR-55 Floorboard!! It saves me a lot of time in editing and great to have all the parameters in one screen!
Is there anyway to select a patch on the floorboard from the tree and have the corresponding patch appear on the GR-55? Does the floorboard transmit patch changes to the GR-55? Is there a parameter on the GR-55 or floorboard that transmits patch changes?
Right now when I select a patch on the floorboard the patch loads on the floorboard but not on the GR-55. I have to manually change the patch on the GR-55. I get communication both ways when I change a parameter on the GR-55 and Floorboard.
- GR-55 Floorboard 20220516
- Mac 10.15.7 Catalina
- Running USB from the GR-55 to the Mac
- Preferences on the Floorboard recognizes the GR-55 as MIDI in and out
- Tried to check/uncheck 'Auto Select GR-55"
- Tried engaging Auto Sync with no results
- Tried reinstalling software from a fresh download
Thanks for your help!!
