Dual Channel Strip?
Started by mchad, September 06, 2020, 10:06:07 PM
mchad
I may have to do some voice over work from home.
I'd like to get a good quality signal into my audio interface and a channel strip looks to be the solution.
With pre amp, comp, eq, de-esser.
Looking for dual channel at this stage because it will do double duty when I write/record music. I tend to record from both outputs of my SY1000.
Cannot seem to find a dual channel strip with all those aforementioned elements.  :-\
What's your recording daw or medium
mchad
Doesn't that have channel strips ? There are several inexpensive 2 input/channel  interfaces.  Kind of depends on what you want to spend
mchad
Yep, but a hardware channel strip is going to give you the tools to create a very decent tone prior to hitting the record button. A channel strip is not an audio interface. It doesn't do AD/DA conversion. Although some might have digital output options.
You can do a lot of post production in software but you should avoid fixing bad tone at that stage.
 https://discoverpods.com/best-usb-mixers-podcasts/
https://www.bhphotovideo.com/explora/pro-audio/buying-guide/a-guide-to-voice-over-equipment
A lot of searches for 2 channel mixer came up with D.J. style mix consoles, but any generic USB mixing desk should do live mix and voice over stuff.
mchad
Thanks gents I'll check it out.
mooncaine
I bought a used Behringer for $50. It does about what you'd expect for $50. Not clean enough for work.
carlb
#9
Might be worth a look at a compact full I/O 'old-school style' mixer and recording deck:
https://www.sweetwater.com/store/detail/Model12--tascam-model-12-mixer-interface-recorder-controller
https://tascam.com/us/product/model_12/feature
Might not have de-essing. Does have dual headphone monitoring.
I look enviously at the per-channel EQ, compression with no menu diving. Has reverbs, delays. Punch In/Out. Maybe overkill in some ways, but not that much space taken up. Direct USB to your DAW, or record remote export per-channel wavs later, or master on-board.
This type of board feels natural to me. Might have to sell the DP-24 for one of these ...
Morningstar MC8 & MC6
QSC CP8 powered speaker
Quote from: carlb on September 09, 2020, 06:09:14 AM
Look at QSC Touchmix 30 , Zoom L12
or
SSL SIX
https://www.sweetwater.com/c21--Solid_State_Logic--Studio_Mixers
mchad
#11
The more I look into it the more options to consider.
I may have to get a dedicated voice-over set up. The mic, as you'd expect, is the star of the show. And I have a deep bass voice. Apparently there are baritone friendly mics around. Who knew. Sennheiser MK4, Shure SM7B and EV RE20.
Still need a channel strip. But if dedicated to VO it could be mono. A dual channel strip is still the preferred though. So it does double duty as a music recording front end too.
Was going to get a new audio interface anyway. MOTU M4 looks nice.
I already own lots of post prod software. Mainly Izotope stuff.
scratch17
I think you should consider your new interface should come with its own channel strips. I am referring to the UA Apollo Twin X Duo.
https://www.uaudio.com/audio-interfaces/apollo-twin-x.html
  • 2 DSP Cores to run UAD plugins
  • 2 Unison Mic Preamps
  • Unison Hi Z input
  • 4 analog outputs
  • Desktop control of Talkback, DIM, Mono, Alt, Main monitors
  • Optical ADAT or S/PDIF input for expansion
  • 4 analog outputs
  • TB3
  • Built in talkback mic
  • Top quality analog components
  • Same world class converters as UA Apollo X6, X8 and X8P
  • Free Luna DAW
  • Runs with near zero latency when tracking through UAD plugins in Luna or UAD Console Application
  • Runs UAD Powered Plug-Ins via AU, VST, RTAS, AAX 64 in all major DAWs
Go to JRRShop.com. They sell the Twin X Duo for $799 which is $100 less than retail. Add the Twin to your cart and use the coupon code "forum" for an 11% discount. That gets you the Twin X Duo for $711.11 shipped free, no sales tax.
The Twin X comes with the free Realtime Analog Classics Bundle.
The bundle includes a Marshall Plexi amp sim, Ampeg SVT bass amp sim, RAW distortion (ProCo Rat emulation), the Precision Mix Rack collection which has a channel strip, a mod/delay block and a reflection engine block, Pultec Pro MEQ-5 Midrange Equalizer and the EQP-1A Program Equalizer, RealVerb Pro, UA 1176 LN and SE Limiting amps, Teletronix LA-2A leveling amp and the Unison Enabled UA 610-B mic preamp and EQ.
This free bundle gives you everything you need to create a mix and match channel strip with some of the best emulations of EQ, compressor/limiters and preamps. All in the box.
Here is the kicker: If you buy by September 30th, you'll get an additional 5 plugins that retail for $1145. These are:
Century Tube Channel Strip*
Helios Type 69 Preamp and EQ Collection*
UA 610-A Preamp and EQ (The original version of the 610)*
Pure Plate Reverb
Galaxy Tape Echo (Roland RE-201space echo emulation)
*The first three plugins are Unison enabled.
So for $711.11 you get a world class audio interface and 14 plugins to create your own channel strip.
You also get Luna, UA's new DAW.
https://www.uaudio.com/luna.html
Luna comes with the Oxide Tape extension for adding analog like warmth to your tracks.
There is also a free Luna instrument. Included free with LUNA, Shape is a painstakingly curated LUNA Instrument featuring a collection of the best vintage keys, drums/percussion, guitar/bass, orchestral content, and realtime synthesis, from Universal Audio, Spitfire Audio, and more.
VG-99, FC-300, RMC Fanout
RJM Mastermind GT10
Kemper Profiling Amp
Radial JDV Mk3, X-Amp
Mesa Recto Pre + 20/20
68 Fender Bandmaster (AB763)
Marshal AS80R
mchad
Thanks all.
The UA Apollo Twin X Duo is an option as i have a Thunderbolt 3 enabled PC.
scratch17
@mchad, I'm glad to here that you're considering a Twin X.
Now that I know you are on a PC, I suggest you go here before purchasing:
https://uadforum.com/apollo-arrow-interfaces/24709-apollo-working-thunderbolt-setups-windows-uad-v9-later.html
I'd also suggest you contact support with specs on the PC hardware, Thunderbolt version and OS version. Sadly, some PC/Windows setups just don't work with UA interfaces.
Steven
RJM Mastermind GT10
Marshal AS80R
Quote from: scratch17 on September 24, 2020, 04:32:30 PM
Steven
+1
Review UAE Forums for the short list of known working Windows PCs /Laptops
mchad
Thanks for the tip! TB3 on audio PC may still be not fully fleshed out yet.
https://help.uaudio.com/hc/en-us/articles/215733823-Apollo-Twin-Thunderbolt-Windows-Compatibility
I'll keep this in mind if I go the new interface route. Which is one option.
