NUX - MG-300 MFX FAQ
Started by admin, July 17, 2020, 10:31:57 AM
https://drive.google.com/file/d/1lPhCHiPtPbaM4642hgONuQHD4AwYfief/view?usp=sharing
NUX MG-300 FW 2.01.01
1.Extra Function: MASTER VOLUME SAVE & LOCK in GLOBAL setting.
2.Extra Function: In EDIT mode, press both " GROUP MODULE" buttons, you can ENGAGE/DISENGAGE current block.
3.Extra Function: In GLOBAL setting, press "SAVE" to save current OUTPUT MODE & GLOBAL EQ.
4.Extra Function: In PRESET mode, press SAVE, you can save current patch location as default reboot patch location.
5.Fixed Function: All the system settings, if there is no HINT, press "EDIT/EXIT" to quit, press "SAVE" to save.
6.Fixed Function: While you save current patch to other patch location, the current patch name will rewrite target patch location name.
See bottom of page
https://www.nuxefx.com/mg-300.html
FW Update Guide
http://v2sources.siiite.com//enclosure/sources/BgthLXDsrLFPCVau/NUX%20MG-300%20Firmware%20Update%20Guide.pdf
$149 at Amazon
https://www.amazon.com/gp/product/B08BYF75CX/ref=ask_ql_qh_dp_hza
https://tinyurl.com/y3u5ulcb
NUX MG-300 FX and AMP Parameters and JAM Drum Style list
#1 Update the NUX Firmware to latest
(get latest FW version here at bottom of page )
Then after installing latest Firmware - recalibrate your Expression pedal
The procedure is in the owners manual
http://v2sources.siiite.com//enclosure/sources/ACXVUwkdowTHoAPe/NUX%20MG-300%20User%20Manual.pdf
1 ) Power MG-300 "ON" by connecting the 9VDC Power cable
2 ) Enter the SYSTEM MENU  ( Press and Hold both EDIT/EXIT and SAVE buttons for 5 seconds )
3 ) Highlight the PEDAL Calibrate  - Press the GROUP Module > key once.
4 ) Press EDIT/EXIT Button once  - get the LCD Prompt for Heel down Calibrate:
       SET PEDAL to MIN, then PRESS V
( Move the Expression pedal Heel Down, then press the left footswitch Once
4 ) Now get the LCD Prompt for Toe down Calibrate:
       SET PEDAL to MAX, then PRESS V
( Move the Expression pedal Toe Down, - BUT NOT TOO HARD -  then press the left footswitch Once
- and returns the LCD to the SYSTEM Page
5 ) Press SAVE to Save and return to normal operating mode
6 ) Test Expression Toe Switch - from preset 1A, "CT 88JM Driv"  - press extra hard on the Toe down of Expression pedal - should see the PEDAL switch glow RED when the Expression pedal Toe Switch for secondary expression pedal operation is enabled ( reverb Level)
Press Expression Pedal Toe area hard again, see the PEDAL switch light go out,  and normal expression pedal operation is enabled ( Patch Volume)
MG-300 - Hardware Reset
* hold edit and save until the system menu appears
* then navigate with the arrow (group) buttons to the factory reset menu and press save
Post-Effects with Core Image Technology
Modulation:
NUX built the popular Mini Core Series and the Verdugo Series (post effects) using Core Image Technology. Now MG-300 provides you with the same sound library - including all the classic Chorus, Flanger, Phase, Vibe, Rotary, Vibrato, and more.
Delay:
If you have tried out the Cerberus or Atlantic, you know NUX's impressive Delay and Reverb sound. MG-300 offers even more new models and algorithms with Core Image technology. It also provides sub-division and tap tempo to make your tone more musical.
Reverb:
Just like the iconic sound of NUX's Atlantic reverb algorithm, MG-300 adds Room for small environment reflection.
Jam ( Drum & Looper ):
60s phrase loop recording time. MG-300 supports NUX Phrase Loop Synchronization with Rhythm - a breakthrough technology derived from the popular NUX Loop Core Stompbox and later the JTC Pro Drum & Loop. Every guitarist has his/her own funky way so a truly versatile drum & looper is indispensable. MG-300 has 8 rhythm styles, each style has 7 different beats. You can play the rhythm then record your phrase loop. MG-300 will automatically amend the phrase to fit the current rhythm BPM.
Expression Pedal
The Expression Pedal can be used to control the volume or the effects.
WAH: Controls the WAH filter.
EFX: Controls GAIN (DRIVE) parameter of OD/DIST. Or controls PITCH parameter of PITCH BENDER.
AMP: Controls LEVEL parameter of AMP.
MOD: Controls MIX level of Modulation effects.
DLY: Controls MIX level of Delay effects.
RVB: Controls MIX level of Reverb effects.
Highlights
.   TSAC-HD Pre-Effects and Amp Modeling deliver realistic feel and playability.
.   Core-Image Post-Effects offer you studio sound quality.
.   Edit Software for quickly choosing and tweaking patches.
.   Load 3rd-party IRs to expand sound ability.
.   USB audio stream for recording interface with routing setup.
.   56 drum beats and 60 seconds Phrase Loop Synchronization with Rhythm.
.   Global 3 bands EQ for quick adjustments in live application.
Product information
Item Weight   2.1 pounds
Package Dimensions   9.9 x 7.1 x 2.8 inches
Amp Modeling algorithm providing optimum sound response and playability
Dollar-for-dollar, the best multi-efx on the market. Our dream was to develop a compact and versatile multi-efx pedal at the right price. We understand that both beginners and working musicians are looking for compact size and great sound at an affordable price. This was a big challenge, and we're proud to say we did it!
CORE-IMAGE Post-Effects
sound library offering you
User-friendly interface and interactive Quick Tone™
Edit Software
IR (Impulse Response),
USB audio stream (recording interface with re-amp function), and more !
We've all experienced digital pre-effect pedals that belong on the Wall of Shame - especially Overdrive.
Modelers of this kind used the linear algorithm which doesn't provide negative-feedback for dynamic playability.
Enter the NUX MG-300, the modeler that will totally blow your mind!
The pre-effect block beautifully recreates the awesome signature sound of real analog overdrive / distortion pedals.
Pre-Effects
Empowered by NUX TSAC-HD Technology
[TSAC-HD]
WHITE-BOX Amp Modeling Algorithm
What is the most important component in an Amp Modeler?
In 2010 NUX introduced TSAC (True Simulation fo Analog Circuit) with the sole intention of bringing Amp Modeling to a whole new level. The DSP industry has been evolving at breakneck speed, and keeping up can be a challenge. We were impressed that a product like the Fractal® AX-FX had the foresight to use a high-definition TSAC (white-box) algorithm to do its Amp Modeling. So we took note and started development on an affordable modeler with TSAC-HD.
The concept of "Chaos makes the muse" perfectly applies to the analogue circuit. When you tweak the knob, it affects itself as well as other parameters. For a linear digital system, the parameter is independent. The white-box algorithm offers real negative-feedback, increment-by-increment. NUX TSAC-HD replicates the same playability most guitarists prefer in a real tube amplifier.
Building a sky-high priced product is easy. The art of building an affordable product is a real challenge. We priced the MG-300, with a straightforward high-performance algorithm to not only fit this specific DSP platform, but dominate the multi-efx platform in general.
For Cabinet Simulation
Impulse Response
NUX is well-known for Impulse Response technology. Using IR is the most popular way to do cab simulation today. Why ? Because the sound is noticeably more realistic compared to traditional cab simulation.
MG-300 offers 512 sample resolution of impulse response. You can load 3rd party IR files using NUX QuickTone edit software. ( MG-300 supports 48kHz wav format. ) The built-in 25 cabinet IRs combine 4 classic microphones with 3 positions to allow beginners a quick and easy way to jump into the multi effects experience.
Post-Effects
With Core Image Technology
Modulation
You can adjust the MOD position as below:
Delay
You can adjust the DLY position as below:
Reverb
Just like the iconic sound of NUX's Atlantic reverb algorithm, MG-300 adds Room for small environment reflection. Simple operation with great sound is our mission. Try it... you'll love it!
*MG-300 offers 60s phrase loop recording time.
Editor Software
Connect to NUX Quick Tone™, and you can easily tweak parameters, download patches, load 3rd party IRs, and even set up USB audio-stream routing. Quick Tone is an interactive edit software - when you tweak the Real knobs, you'll see your changes in Real time.
(Note: There are no collaboration patches in CHINA MAINLAND EXCLUSIVE version.)
Musicians love MG-300 and created Preset Patches for it
MG-300 creates various tonal possibilities.
Top Class custom presets and IR Packs.
Join the MG-300 community on Facebook!
Facebook MG-300 Group is mainly for MG-300 users to discuss their experience and opinions. Don't be shy to share your videos and experience with NUX MG-300 here!
Note: USB Recording
For USB Recording, we suggest you set the I/O Buffer Size at 128 Samples.
Note: Expression Pedal
Detailed instructions on how to assign functions and how to calibrate the pedal are provided in the User Manual.
Highlights
Quick Tone™ Edit Software for quickly choosing and tweaking patches.
Inside view
Ti TMS320C6720 as main DSP
https://www.ti.com/product/TMS320C6720
AKM AK4558 32 bit CODEC
https://www.akm.com/global/en/products/audio/audio-codec/ak4558en/
TI OPA01688A Rail to Rail Op amp
https://www.ti.com/store/ti/en/p/product/?p=OPA1688IDR
USB Transceiver is a pSOC (NXP MIMXRT1061CVJ5A) for 24 bit audio - and there are SPDIF I/O on unused BGA pins
https://www.mouser.com/datasheet/2/302/IMXRT1060IEC-1396579.pdf
and the ubiquitous STM32F103 ARM CORTEX M3 CPU
https://www.st.com/en/microcontrollers-microprocessors/stm32f103.html
United Chemicon Electrolytic caps ( good quality)
http://www.chemi-con.com/
( Compare to Valeton GP-100 Inside view here)
https://www.vguitarforums.com/smf/index.php?topic=28681.msg211256#msg211256
Plastic Chassis - and if over age 45 WILL NEED GLASSES TO EDIT on the small LCD
5 ) Now get the LCD Prompt for Toe down Calibrate:
6 ) Press SAVE to Save and return to normal operating mode
7 ) Test Expression Toe Switch - from preset 1A, "CT 88JM Driv"  - press extra hard on the Toe down of Expression pedal - should see the PEDAL switch glow RED when the Expression pedal Toe Switch for secondary expression pedal operation is enabled ( reverb Level)
1st group of 36 patches (1A thru 9D) are USER PRESETS depicted in WHITE Lettering on the Color LCD= ONLY these USER presets can be changed
While the 2nd Group of 36 patches (1A thru 9D) "FACTORY PRESETS" are depicted in GREY Lettering on the Color LCD - and are fixed in memory from the factory - and edits will not save
And I have a White Knob USA version -
[URL unfurl="true"]https://www.nuxefx.com/mg-300.html[/URL]
"Artist Presets have these names:
"CT" = ChopTones (1A-1D)
"SF" = Silas Fernandes (2A-2D)
"TM" = Tony Martinez (3A-3D)
"VT" = Vinai T (4A-4D)
"RG" = Ryan Gunns" (5A-5D)
GY = George Yeh (6A-6D)
"RL" = Roger Lin (7A-7D)
"JL" = Jimmy Lin (8A-8D)
72 total patches
New MG-300 Firmware  V1.0.8.13
New MG-300 QuickTone Editor Version 1.0.8.11
See bottom of page
FW Update Guide
Quote from: miggelblast, post: 31043692, member: 225757
I'm on the verge of ordering the MG-300 for playing with headphones and maybe some other stuff as well. Is it possible to bypass the amp sims and IR's and use it purely as a multi-fx in front or in the effects loop of an actual amp?
yes
Although in AMP Effect loop   the AMP  MUST  have separate FX SEND and FX Return Level controls,as the NUX MG-300 input is fixed at  -20dB
The Valeton GP-100 is a bit more flexible in this regard, as it has input level adjustable between -20dB to +20dB , and provides a StompBox Mode
- but many NUX MG-300 FX ( Spring Reverb) are superior to the GP-100 FX , - but the GP-100 has a wider FX palette (touch wah, Bias Trem, etc)
and the GP-100 in Tuner Mode can be configured between MUTE or  Dry signal only - which acts as a clean Bypass i.e FX Off mode.
NUX MG-300 FIRMWARE V1.0.8.17
Product: MG-300
Version: V1.08.17
v1.0.8.17
1.Function Added: You can exchagne patches by swaping memory slot positions;
2.While you go back to factroy defaul, it won't change EXP initial setting;
3.Fixed the 3rd party IR patch export no-sound issue while using QuickTone editor to save;
4.Fixed the firmware update failed issue with some MAC OS;
Erjimipey
Hi there,
I'm about to get this unit. I would like to know something I haven't been able to find anywhere:
I want to use the audio interface capabilities to record and monitor 2 simultaneous tracks in my DAW, one with the Nux's full chain panned 100% right and a completely dry DI to use with a plugin in my DAW and pan it 100 % left.
Is this possible with the Nux MG300? I really want a stereo rig through headphones, basically, with 2 independent signal paths mixed.
Quote from: Erjimipey on October 28, 2020, 06:24:00 AM
Hi there,
Not possible on the MG-300
is possible on Valeton GP-100, or Ampero
Erjimipey
Quote from: admin on October 28, 2020, 09:42:22 AM
Oh... What a pity, I love the sound of the demos I've heard...
So, the dual track thing is Not even possible with Asio4all drivers?
Plus, would you say the Ampero can sound as realistic as the Nux?
Quote from: Erjimipey on October 28, 2020, 10:22:07 AM
Nux sounds a bit better than AMPERO or Valeton
Erjimipey
Thanks for your answers. I really appreciate it. I dig the Nux sounds....
So, the dual signal path... Would I be able to do it using the Asio4all drivers? I did it that way with my Boss Katana MkI.... Has anyone tried that?
NUX has posted the MG-300 Parameters XLS Spreadsheet I created to their global MG-300 downloads area
Look at the bottom
MG300 FW 2.01.01
ladron
Has anyone found a way to turn off direct monitoring on this device? While I like the built-in sounds, I also want to use it with VST guitar software.
I haven't found a way to keep it from overlaying its signal on top of the USB audio output.
The "Dry Out" mode almost does what I want, but it still overlays the effect chain path on the output - I want 100% what the USB path is outputting.
ladron
I was able to work around the monitoring issue by using "Dry Out" mode and setting the amp gain to zero. A bit of a hack, but it works.
Some other notes - the unit was completely silent after doing the firmware update. Fortunately, I'd read on another forum to try calibrating the pedal - that fixed it. Not everyone is going to know to try that, though.
In case anyone cares, I tried using it with Linux and Android. Neither worked.
Quote from: ladron on January 16, 2021, 04:51:36 PM
Works fine as USB Audio Interface on my Samsung Galaxy S10+ w/ Android 10
I use a USB-C to Micro USB cable
ladron
Quote from: admin on January 16, 2021, 07:55:46 PM
That's interesting. What app(s) are you using? I tried using Audio Evolution Mobile Studio - it recognizes it as a USB audio interface, but fails to record. Using the same app/cable has worked for me with other audio interfaces.
I'm on an older version (8.1) of Android, so maybe something was fixed between 8 and 10? I tested on Linux with the latest kernel, though, without success...
Quote from: ladron on January 17, 2021, 08:04:04 AM
Field Recorder
https://play.google.com/store/apps/details?id=de.pfitzinger.rec&hl=en_US&gl=US
FILMIC PRO
https://play.google.com/store/apps/details?id=com.filmic.filmicpro&hl=en_US&gl=US
Launch  app - then connect the NUX MG300 via USB after app is running
ladron
ladron
Some more information on this device under Linux. Initially it did not work at all. After working with the lead maintainer of the Linux kernel sound system, I was able to get capture working. Audio playback still does not work, though.
More information here:
http://blog.nostatic.org/2021/01/nux-mg-300-guitar-processor-under-linux.html
