Katana FxFloorBoard Booster settings question
Started by alonbl, May 01, 2020, 01:44:00 PM
alonbl
I have some question about the booster settings. I'm trying to combine 2-3 booster at a time. I didnt see an option to add another pedal to the chain, is there a way?
I saw that there is red-green-yellow inside the booster settings, is this the only way to combine them? if so there isnt a way to tweak each individual booster?
also, in the boost menu it looks like there is 4 total booster option one on the left and two on the right?
Sorry but I'm very confused :)
You can not add extra pedals within the Katana chain, what you see is what you get.
In the Booster effect, where you have the Red,Green, Yellow options,
this gives you the option to select a different booster model for each color, but they all share the same common settings.
Very limiting, but that is the way the Katana was designed.
Same for the Reverb and Delays, sharing a common group for parameter settings,
but different for the MOD and FX where each color group has its own unique settings parameters.
The color groups relate to the panel color button next to the effect, where pressing the button cycles through the red, green, yellow effect type choices saved for each channel.
alonbl
cool thanks!
Now I finished changing an existing TSL file. I tried import it to tone studio but it say import fail. I tried just opening an existing TSL with FxFloorBoard and saving as new file without changing anything but still I get import fail.
What should I do?
Quote from: alonbl on May 02, 2020, 02:16:25 AM
cool thanks!
Now I finished changing an existing tsl file. I tried import it to tone studio but it say import fail. Is it because my red-green-yellow are all boosters and I have a MKI not MKII?
Not following what you mean?
Which type Katana are you using?
Which version of FxFloorBoard, and which version of Boss Tone Studio?
Original or MK2?
alonbl
I'm not home right now to check exactly but I have the latest software and Katana 50 MK1.
alonbl
Quote from: gumtown on May 02, 2020, 03:12:08 AM
Original or MK2?
Katana 50 MK1
FxFloorBoard for MK1 Firmware 4 version 20191225
Boss Tone Studio V4
I seem to have found an issue with the *.tsl exported files from FxFloorBoard MK1 FW4 editor,
under some conditions the file is not B.T.S. compatible.
I will examine this, might take a while to sift through each of the 2000+ exported parameters to see which one fails on file saving.
alonbl
Quote from: gumtown on May 03, 2020, 01:19:11 AM
found the problem, and fixed it.
a new update of the MK1 original Katana FxFloorBoard for Firmware 4 here
https://sourceforge.net/projects/fxfloorboard/files/KatanaFxFloorBoard/Katana%20FxFloorBoard%20for%20MK1%20Desktop/
You are the best! it works now!
BTW do you make patches(tsl)? I have a feeling you make good ones :)
