FC-300 in STANDARD mode
Started by Rusty Kirkland, February 14, 2020, 03:23:50 PM
Rusty Kirkland
Hi folks.. I have an incoming FC-300 in a couple of weeks....
I would REALLY like to just operate in Standard mode.   So having (mostly) read the manual:
I'll have the FC-300 connected via RRC2 to my VG99.
I need to have the FC-300 midi out port send PCC from the footswitches to a Switchblade.
Question:     Without any programming, without Patch mode, when I'm in Standard mode does footswitch (e.g.) 4  send a PCC of #4 out the midi out port?
and IIRC, the default midi channel for the FC-300 is  "1"   ??
Rusty
Quote from: Rusty Kirkland on February 14, 2020, 03:23:50 PM
Rusty
Best to RTM
https://static.roland.com/assets/media/pdf/fc_300_turbo_start.pdf
https://static.roland.com/assets/media/pdf/FC-300_OM.pdf
and Search on FC-300 here
https://static.roland.com/assets/media/pdf/VG-99_OM.pdf
https://static.roland.com/assets/media/pdf/GT-PRO_l_FC-300_AP.pdf
Other references
https://community.cantabilesoftware.com/t/roland-fc300-to-control-cantabile/1703/21
You can send PC messages from the guitar-to-midi section of the VG-99. That way the patch of the switchblade is set in a patch of the VG-99, and you can call the same patch of the switchblade from several patches of the VG-99.
Then you can use the FC300 in sysex mode and read your patch names on the display of the FC300.
Rusty Kirkland
whoa...........
very cool and thank you for your reply!
Rusty
Rusty Kirkland
sixeight:
so that's:   Set to POLY in the guitar to midi section of the patch, then set the PC (PCC) #
So: Independently of the Tx PC out function, this PC out within a patch could trigger presets on the Switchblade... yes?
and it sends that PC just by going to/engaging a particular VG99 patch?
Rusty
