Katana - Rotate Katana Head for Front Facing Knobs ( cable I/O Accessories)
Started by admin, January 12, 2020, 09:02:49 AM
These Right Angle components  / adapter cables facilitate rotating the Katana Head
Large Rubber feet  - place on the Front ( to be used as the Bottom)
4 LARGE #3 ROUND RUBBER FEET 2.255 H X 1.668 D AMPS, RADIO CASES - FREE S&H
https://www.ebay.com/itm/351292110831
IEC-C13 Power cable adapter provide a cleaner presentation for re-routing the Katana AC Power cord
https://www.amazon.com/WYMECT-Power-Adapter-Socket-Degree/dp/B07L1SDBHZ/ref=sr_1_3?keywords=Down+angle+Power+cord&qid=1578685375&sr=8-3
Right Angle MIDI Cable (1.5M)
https://www.amazon.com/gp/product/B00E05BPSW/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Right Angle USB 2.0 Cable (1.5M)
https://www.amazon.com/gp/product/B00S5WTWX6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
My Plans this year is put my Katana Heads into new cabs
http://www.voxshowroom.com/uk/amp/conq.html
CodeSmart
I want to put these on top of each other gracefully:
Added to Elantric's list, you also need an angled speaker cable, something like this:
https://www.thomann.de/se/pro_snake_tpl_15_aa.htm
So I ordered what Elantric suggested, but not all of us live in US. I live in Sweden i.e. "EU".
WYMECT IEC C14 to C13 Power Adapter PDU Plug/Socket Down 90 Degree for LCD Wall Mount TV 2 Pack
This does not ship to my country however regardless where you live if you Google for
"C14 to C13 Power Adapter wall mount TV" + using your local language and the name of YOUR COUNTRY I'm sure you find a similar product.
of just "C14 C13"...
I did find Grandado:
Sweden:
https://se.grandado.com/products/ootdty-vinklad-iec-adapter-upp-snedstalld-iec-320-c14-till-c13-for-lcd-lec-tv-vaggmontering?variant=18831530197049&currency=SEK&gclid=EAIaIQobChMIwfzf2M7-5gIVzBsYCh1WdQ2rEAYYASABEgIp9fD_BwE
Germany:
https://de.grandado.com/products/ootdty-right-angle-iec-adapter-bis-abgewinkelten-iec-320-c14-bis-c13-fur-lcd-lec-tv-wandhalterung?_pos=9&_sid=b02326d6f&_ss=r
France:
https://fr.grandado.com/products/ootdty-droit-angle-iec-adaptateur-up-angle-iec-320-c14-a-c13-pour-lcd-lec-tv-support-mural?_pos=6&_sid=4b37aca36&_ss=r
Spain:
https://es.grandado.com/products/ootdty-angulo-recto-iec-adaptador-en-angulo-iec-320-c14-a-c13-para-lcd-lec-tv-montaje-en-pared?_pos=9&_sid=e60af4b9a&_ss=r
Italy:
https://it.grandado.com/products/ootdty-destro-angolato-iec-adapter-up-angolato-iec-320-c14-a-c13-per-lcd-lec-tv-wall-mount?_pos=8&_sid=ce6e05cb3&_ss=r
QuoteI want to put these on top of each other gracefully:
If you install the extra tall 1.5" high rubber feet in link above to the front of your Katana Head at the existing 4 large screw locations , there should be just enough clearance  to stack each Katana Head on top of each other
I'll install the right angle cable adapters soon and check ,
CodeSmart
