SY-1000 - FAQ
Started by admin, December 12, 2019, 11:37:46 AM
Verify you have FW1.05 installed First
https://www.boss.info/global/products/sy-1000/downloads/
SY-1000 Manuals
https://www.boss.info/global/products/sy-1000/support/
SY-1000 Owners Manual
https://static.roland.com/assets/media/pdf/SY-1000_eng01_W.pdf
SY-1000 Parameter Reference
https://static.roland.com/assets/media/pdf/SY-1000_reference_eng01_W.pdf
SY-1000 Sound List
https://static.roland.com/assets/media/pdf/SY-1000_soundlist_eng01_W.pdf
SY-1000 MIDI Implementation
https://static.roland.com/assets/media/pdf/SY-1000_MIDI_Implementation.pdf
Are you on latest FW 1.05?
and latest version of BTS for SY-1000 (1.0.2)
ALL PRIOR VERSIONS HAVE BUGS
QuoteUPDATE HISTORY
[ Ver.1.05 ] SEP 2020
Bug Fix
The following bug was fixed.
When the CUR NUM function is enabled, the CUR NUM LED may not light correctly.
[ Ver.1.04 ] APR 2020
Bug Fixes
When the INST and Effects (CHAIN) are changed, Reverb sound sometimes fails to be output.
When Patches are switched, the DYNAMIC SYNTH parameter's SEQ playback position sometimes becomes variable.
When OUTPUT SELECT is set to INPUT type, sound drop-out sometimes occurs.
Other minor bugs.
[ Ver.1.03 ] JAN 2020
Functionality Improvement
Be compatible with BOSS TONE STUDIO for SY-1000.
Bug Fixes
Part of the name for preset patch and variation has been changed.
CTL FUNCTION on NUM1-4 incorrectly activated at MANUAL MODE.
NORMAL PU GAIN parameter in GK SETTING doesn't work. (BASS MODE only)
Other minor bugs.
No Driver required to update Firmware- because after the "Hold down [ WRITE ] button and turn on the SY-1000 power" sequence, the SY-1000 presents itself as a USB Class Compliant FAT Storage Drive - ( essentially a USB Thumb Drive) that any modern  OS  can R/W
I know 1st hand there is a specific order to follow - USB Driver and Boss Tone Studio will NOT function until After you first update to FW-1.03 -
Boss SY-1000 - USB Driver Details
Solve SY-1000 Win 10 USB Driver installation problem
Contact RolandUS Guitar Product Support @ Zendesk
https://rolandus.zendesk.com/hc/en-us/sections/200467249-Knowledge-Base
The Roland Zendesk support sent me a zipped driver for Windows 10 and the SY-1000
It at least loads now!
https://rolandus.zendesk.com/hc/en-us/requests/new
Remember Roland /Boss is a Japanese company and their best info is there first
Boss Japan Support Q&A site
(I  use Chrome Browser with an Auto Translate function, and search foe latest info here)
http://faq-jp.roland.com/?site_domain=default
https://www.vguitarforums.com/smf/index.php?topic=27182.0
Why wont SY-1000 USB 64 bit Core Audio  / MIDI Driver work on my macOS 10.14 / 10.15?
Boss Support wrote>
SY-1000 USB MIDI trouble caused by interference by 3rd party USB MIDI driver.
To meet security requirement for mac OS 10.14, our USB MIDI Driver works only for 64bit MIDI Server.
If you use 32bit USB MIDI Driver, MIDI Server works as 32bit and USB MIDI for SY-1000 doesn't work.
For your information, your MIDI Server was boot as 32bit.
Roland/BOSS USB drivers you installed to your Mac work as 64bit.
But some 3rd party USB Driver works as 32bit and make interference to our USB MIDI Driver.
If you could uninstall all of 32bit MIDI driver, your MIDI Server works as 64bit, SY-1000 USB MIDI works.
Q: Does SY-1000 have everything the GT-1000 or VG-99 Does?
A: No  - COMPARE
SY-1000 Reference Manual
GT-1000 Parameter Guide l
https://static.roland.com/assets/media/pdf/GT-1000_parameter_eng05_W.pdf
VG-99 Manual
http://lib.roland.co.jp/manual/en/dl_07-19743/VG-99_e4.pdf
QuoteWHY USE THE BOSS SY-1000
For many its all about the play feel of the specific Guitar Synth - the VG-8, VG-88, VG-99 SY-1000 use the strings as the source and react immediately to your playing technique - no false triggered random notes and no latency delays as occurs on GUITAR to MIDI
https://www.vguitarforums.com/smf/index.php?topic=14088.0
The GK IN =  7 channel analog inputs
FX Loop is Mono  - the Sub and Main outs and Headphones are Stereo
The USB is 8 Channel Out, 8 Chanel IN
Realize the Guitar to MIDI on SY-1000 is a very separate function- and unrelated to any internal sound generation.
SY-1000 Audio Examples
: Boss SY-1000 -Audio Examples
« on: Yesterday at 03:30:18 AM »
SY-1000 Videos
https://www.vguitarforums.com/smf/index.php?topic=26877.0
https://www.vguitarforums.com/smf/index.php?topic=26924.0
https://www.boss.info/global/support/by_product/sy-1000/
SY-1000 Versions
SY-1000 Firmware 1.03
Boss Tone Studio for SY-1000  - Version 1.01
USB Audio Driver 1.0.0
GK Pickup Sources
https://www.vguitarforums.com/smf/index.php?topic=27260.msg200011#msg200011
New SY-1000 Owner Setup Procedure
#1 First Update the SY-1000 Firmware to latest version ( FW1.03)
( Follow all steps here)
https://www.boss.info/global/support/by_product/sy-1000/updates_drivers/d6bf0b5f-b70b-47b5-b12f-a1aa08a58948/
https://www.vguitarforums.com/smf/index.php?topic=27280.msg200201#msg200201
Verify you have FW1.03 installed
I know 1st hand there is a specific order to follow - USB Driver will NOT function until After you first update to FW-1.03 -
No Driver required to update Firmware- because after the "Hold down [ WRITE ] button and turn on the SY-1000 power" sequence, the SY-1000 presents itself as a USB Class Compliant FAT Storage Drive - that any modern  OS  can R/W
#2 Install the USB Driver for you operating System
( the Win 8.1 USB driver also works for Win7 64
The Windows 10 USB Driver should automatically install upon USB connection
- but its still IMportant to download the *.zip file, and extract the README.HTM file to obtain Troubleshooting and USB Audio / MIDI information
#3 Install Boss Tone Studio for SY-1000 for your operating System
Follow the Boss Tone Studio for SY-1000 Setup Instructions here:
https://static.roland.com/assets/media/pdf/BTS_SY-1000_eng01_W.pdf
SY-1000 General Discussion
https://www.vguitarforums.com/smf/index.php?board=320.0
SY-1000 Top Things to Know
https://www.vguitarforums.com/smf/index.php?board=321.0
https://www.vguitarforums.com/smf/index.php?topic=27135.0
SY-1000 User Reviews
https://www.vguitarforums.com/smf/index.php?topic=27077.0
SY-1000 Pelican type case   - Ridgid 22" Case ($30)
https://www.vguitarforums.com/smf/index.php?topic=27108.0
SY-1000  - User to User Patch Exchange
https://www.vguitarforums.com/smf/index.php?board=322.0
Facebook SY-1000 Users Group
https://www.facebook.com/groups/BossSY1000Users/
SY-1000 OWNERS MANUAL (01)
SY-1000 REFERENCE MANUAL (01)
SY-1000 Factory Preset Sound List
Observe the CTRL ASSIGNMENTS -
Use Boss Tone Studio Editor to fully  understand the power of this feature
MIDI controller Setup / Debug
MIDI Tutorials
I just press Both Bank [<] [>} foot switch to access the Tuner
Updated list of SY-1000 Specifications
https://www.boss.info/global/products/sy-1000/specifications/
BOSS's most powerful guitar/bass synth and modeling processor ever
Next-generation synth engine with custom DSP and 48 kHz/32-bit processing throughout
Unprecedented sound and expression with three simultaneous instrument types and advanced real-time signal processing
Each instrument provides pitch, level, and panning of each string for instant alternate tunings and wide, layered voicings
New Dynamic Synth perfectly follows the guitar's natural envelope for uncompromised tone shaping
New sound engine and GK 13-pin interface deliver clear, dynamic sound and precision tracking with zero latency
Dynamic Synth includes two 16-part step sequencers for evolving control of pitch, filter, and amplitude
Newly refreshed versions of historic BOSS/Roland guitar synth and modeling technologies: OSC Synth, GR-300, E.Guitar, E.Bass, Acoustic, VIO Guitar, and Poly FX
Normal ¼-inch guitar/bass input for blending and Dynamic Synth processing
Premium effects and amps derived from the flagship GT-1000
Large LCD and intuitive editing interface for free-flowing sound creation
Eight freely assignable footswitches, external control support, effects loop, and configurable Main/Sub outputs
USB Audio/MIDI and MIDI I/O, plus Guitar-to-MIDI/Bass-to-MIDI function
Dedicated Guitar and Bass modes
Customize sounds with the BOSS Tone Studio editor and download pro patches at BOSS Tone Central
Roland GK-compatible pickup and 13-pin cable required for full access to all synth and modeling features
A New Era of Guitar Synth Innovation
The SY-1000 is the most advanced guitar/bass synth we've ever made, hands down. Custom DSP delivers six times the processing muscle of the SY-300, and the newly developed sound engine leverages the power of GK independent string processing for ultra-articulate performance, lightning-fast response, instantly variable tuning, sound panning/layering, and much more.
Deep Sound Design Tools
A standard SY-1000 patch includes three simultaneous instruments—each with a number of distinctive types to choose from—and you can combine and layer them for an endless range of sounds. Fed by the 13-pin GK input, every instrument offers an extensive set of parameters for tone shaping, mixing, and tuning. A normal ¼-inch input is available as well, letting you blend regular guitar/bass pickup sounds alongside the three instruments.
Ultra-Expressive Dynamic Synth
The all-new Dynamic Synth takes guitar synthesis further than it's ever gone. GK processing and speedy DSP track your instrument's characteristics with precision detail, allowing you to craft sounds never before possible. Choose from ten oscillator waveforms—sine, triangle, PWM, three saw types (including Roland's famous supersaw), and more. Then shape the sound with six different filters, amplifier control, two LFOs, and two powerful step sequencers. Optimum performance is realized with the GK input, but it's also possible to play the Dynamic Synth via the normal guitar/bass input.
Two Step Sequencers Bring Sounds to Life
After shaping a basic sound with the Dynamic Synth, the fun's just starting—with two step sequencers, you can infuse it with movement to create complex textures that pulse, breathe, and groove. Each sequencer features 16 customizable steps that control pitch, filter, and amplitude independently. Better still, every step includes 13 different envelope curves for unprecedented sonic control. And by stacking three Dynamic Synths together, you can build massive moving sounds with three oscillators and six separate step sequencers!
OSC Synth and GR-300
Complementing the powerful Dynamic Synth are two additional synth instruments. OSC Synth is an analog-style engine with lots of filter options, full ADSR control, and high-definition sound with the discrete GK input. Also included is a perfect sonic recreation of the Roland GR-300, the legendary 1980s analog guitar synth used by some of the world's most influential guitarists.
Advanced Guitar/Bass Modeling and Poly FX
The SY-1000 doesn't stop at synthesis—it also features refreshed instrument modeling derived from historic BOSS and Roland GK gear. A large selection of electric, acoustic, and bass guitar types are available, each with independent tuning, EQ, virtual amp settings, and more. There's also a highly expressive VIO Guitar instrument, which alters the input signal's envelope and harmonic characteristics to create tones reminiscent of bowed instruments. Finally, the cool Poly FX instrument delivers richly textured voices with high-res definition only possible with GK processing.
Flagship-Class Effects and Interface
The SY-1000's signal processing and user interface are derived from BOSS's flagship GT-1000 multi-effects, lauded for its exceptional audio quality and simple operation. Shape sounds any way you like with a huge palette of effects, plus ultra-responsive guitar and bass amps. Quickly edit instruments and effects, change routings, create parallel chains, and more via the large LCD and hands-on knobs. And to speed up your patch workflow even more, you can save favorite instrument and effect setups in ready-to-go Variation libraries.
Configurable Control
By default, the SY-1000's eight footswitches select patches, banks, and two control assignments. But you can easily reassign them to nearly any function you want. There's also a Manual mode for fast on/off access to the three instruments and normal input. Up to four external footswitches or two expression pedals are supported, and MIDI I/O is provided as well. The Main and Sub outputs are normally used for mixed stereo signals, but can also be configured as four discrete outputs, complete with dedicated EQ on each. And with the moveable effects loop, you can smoothly integrate all your external gear.
Record Tracks and Play MIDI Instruments via USB
The SY-1000's USB audio/MIDI interface opens a world of creative options with your favorite DAW. With the GK input, you're able to record each of your instrument's strings to separate audio tracks, either processed live or captured dry for later "re-synth" processing through the SY-1000. And with the Guitar-to-MIDI/Bass-to-MIDI function, you can use your axe to play soft synths, record MIDI sequences, input notation data, and more.
SPECIFICATIONS
Instruments parts    3 parts
Instruments types  [Guitar mode]
                             Guitar synthesizer: 3 types (DYNAMIC SYNTH, OSC SYNTH, GR-300)
                             Electric guitar + Amp modeling: (Guitar = 13 types, Amp = 31 types)
                             Acoustic + Amp modeling: (Acoustic = 10 types, Amp = 31 types)
                             Bass + Amp modeling: (Bass = 3 types, Amp = 31 types)
                             Vio guitar modeling: 13 types
                             Poly FX: 5 types
                            [Bass mode]
                             Bass synthesizer: 3 types (DYNAMIC SYNTH, OSC SYNTH, ANALOG GR)
                             Bass + Amp modeling: (Bass = 11 types, Amp = 31 types)
                             AC bass + Amp modeling: (AC bass = 1 type, Amp = 31 types)
                             Electric guitar + Amp modeling: (Guitar = 3 types, Amp = 31 types)
                             Poly FX: 5 types
Alternate Tuning    [Guitar mode]
                             OPEN (D, E, G, A), DROP (D to A), D-MODAL, NASHVILLE, SHIFT (-12 to +12),
                             USER, 12-string guitar function
                            [Bass mode]
                             SHIFT (-12 to +12), USER, 12-string bass function
Effects                   Over 150 types
Patch Memory       Guitar mode: 200 (Preset) + 200 (User)
                            Bass mode: 200 (Preset) + 200 (User)
AD Conversion       Divided Pickup: 32 bits + AF method
                            Normal Pickup: 32 bits + AF method
                           * AF method (Adaptive Focus method) is a proprietary method from Roland & BOSS that vastly improves the
                              signal-to-noise (SN) ratio of the AD and DA converters.
DA Conversion       32 bits
Sample Rate          48 kHz
Normal Input Level   GUITAR INPUT: -10 dBu
                              RETURN: -10 dBu
Maximum Input Level  GUITAR INPUT: +16 dBu
                                 RETURN: +8 dBu
Input Impedance         GUITAR INPUT: 1 MΩ
                                  RETURN: 1 MΩ
Normal Output Level       MAIN OUTPUT (L/PHONES, R/MONO): -10 dBu
                                     SUB OUTPUT (L, R/MONO): -10 dBu
                                     SEND: -10 dBu
Output Impedance          MAIN OUTPUT (L/PHONES, R/MONO): 44 Ω
                                     SUB OUTPUT (L, R/MONO): 1 kΩ
                                     SEND: 1 kΩ
Recommended Load Impedance MAIN OUTPUT (L/MONO, R): 10 kΩ or greater
                                                *Phones: 44 Ω or greater
                                                SUB OUTPUT (L, R/MONO): 10 kΩ or greater
                                                SEND: 10 kΩ or greater
Controls                  BANK DOWN switch, BANK UP switch, CTL1--2 switches, 1--4 switches,
                              POWER switch, INST button, EFFECTS button, CTL button, EXIT button,
                              WRITE button, SYSTEM button, PAGE button
                              1--6 knobs, OUTPUT LEVEL knob
Display                 Graphic LCD (512 x 160 dots, backlit LCD)
Connectors                  GK IN connector: 13-pin DIN type
                                  GUITAR INPUT jack, SEND jack, RETURN jack,
                                  MAIN OUTPUT (L/PHONES, R/MONO) jacks,
                                  SUB OUTPUT (L, R/MONO) jacks: 1/4-inch phone type
                                  CTL3, 4/EXP1 jack, CTL5, 6/EXP2 jack: 1/4-inch TRS phone type
                                  USB COMPUTER port: USB B type (supports High-Speed USB, USB Audio, and USB MIDI)
                                  MIDI (IN, OUT/THRU) connectors
                                  DC IN jack
Power Supply               AC adaptor
Current Draw               800 mA
Accessories                  AC adaptor(PSB-1U + AC Cord Set)
                                  Owner's manual
                                  Leaflet "USING THE UNIT SAFELY"
Options (sold separately)   Divided pickup: GK-3 (for guitar), GK-3B (for bass guitar)
                                       GK cable: GKC-5 (5 m, 15 feet), GKC-10 (10 m, 30 feet)
                                       Footswitch: FS-5U, FS-5L, FS-6, FS-7
                                       Expression Pedal: EV-30, FV-500L, FV-500H, Roland EV-5
                                       Unit A/B/Y selector: Roland US-20
                                       AC adaptor (PSB-1U)
                                     * When purchasing an AC adapter, be sure to specify the adapter (from the list that follows) that is designed for the region in which it will be used, and the voltage supplied there.
               (PSB-120/PSB-120TW/PSB-230EU/PSB-230UK/PSB-240A)
SIZE AND WEIGHT
    Width 345 mm
              13-5/8 inches
Depth     245 mm
              9-11/16 inches
Height     67 mm
              2-11/16 inches
Weight (excluding AC adapter)2.5 kg
                                            5 lbs 9 oz
* 0 dBu = 0.775 Vrms*The specifications are subject to change without notice.
Quote from: DeRigueur on March 21, 2020, 11:09:48 AM
How do you change the display options for the size of the patch number as described above?  Can't find it in the manual.
Thanks!
Push the right arrow button under the page heading on the SY-1000 device.
Search on "NORMAL" in the Reference Manual
See Page 13
NORMAL PATCH - Patches for a conventional guitar (bass) that is connected to the GUITAR INPUT. These can be used even if you don't have a divided pickup. You can also use these patches with the conventional guitar (bass) signal (normal pickup) that is routed through the divided pickup. If you're using Normal patch, the GK icon goes dark. * DYNAMIC SYNTH is the only INST TYPE that can be selected for normal patches.
Quote from: Peter the GR-eat... on January 29, 2020, 02:24:05 AM
Anyone who has the unit.
And has done this.
Looking at the settings for USB routing
There is no DRY-GUITAR as on the GP-10
What setting did you use to record the unprocessed stings to a daw?
Review the USB Audio section in the Reference Manual
and the README.HTM file in the USB DRIVER download -
Even the SY-1000 Win10 USB Driver has an important "README.HTM" file you must read  inside the download zip  file)
Audio input/output device
Of the total audio input/output channels provided by the SY-1000, there are 8 INs and 8 OUTs
[WAVE OUT Devices]
OUT (SY-1000)
GK 1-2 (SY-1000)  = High E & B String
GK 3-4 (SY-1000)  = G & D String
GK 5-6 (SY-1000)  = A & Low E String
*   If you've specified a different name in the "Sound" settings of the Control Panel, the name you specified will be displayed.
[WAVE IN Devices]
IN (SY-1000)
[ASIO device]
When using the SY-1000 with an ASIO-compatible application, select "SY-1000" as the ASIO setting for your application.
*   To prevent an audio feedback loop or double monitoring, make settings on your application to turn monitoring off.
*   The SY-1000 main unit does not support ASIO Direct Monitor, but if you use Cubase, by enabling Direct Monitoring in the Cubase setting, you can prevent loop oscillation of audio equipment and duplicate monitoring.
*   When using the SY-1000 with ASIO, we recommend that you set your application so that it does not use the Microsoft GS Wavetable Synth. (In order to decrease the load, and for convenience when changing Audio Buffer Size of the driver.)
MIDI input/output device
*   In the Windows Media Player, the MIDI input/output device of SY-1000 cannot be used.
Please select the following device in your MIDI compatible application.
[MIDI OUT devices]
SY-1000
SY-1000 DAW CTRL
[MIDI IN devices]
SY-1000
SY-1000 DAW CTRL
The USB routing is extensive
Could add a MacMini and run Scuffham SGear Amp modeling and Omisphere / Samplitude for Synths
Or other Hardware Synths via 5 pin MIDI
https://www.vguitarforums.com/smf/index.php?topic=915.msg4379#msg4379
SY-1000 VIO GUITAR PARAMETERS
Quote from: aliensporebomb on December 12, 2019, 08:35:52 PM
I didn't see the feedbacker as part of the feature set but it's something I use all of the time on the VG-99.  YMMV.
Search on "FEEDBACK"
Page 25 there is an OSC Waveform type  = "FEEDBACK OSC
"A sound containing high overtones similar to guitar feedback playing.
Suitable for creating crisply aggressive tones that stand out"
Page 26
FEEDBACK  0–100
Adjusts the amount of feedback.
Larger values increase the amount of feedback, changing the volume of the harmonics.
Page 47
HR1:FEEDBACK 0–100
Adjusts the feedback amount of the harmonist sound.
Quote from: Vaultnaemsae on December 12, 2019, 07:00:21 PM
Variable Pitch Bend range. It's ambiguous in the manual if it's fixed like the VG-99 or adjustable like the GP-10.
Search on "BEND"
See Page 25 = Bend Depth  =  -24 / +24 semitones
Quote from: Kevin M on December 12, 2019, 08:46:31 PM
Reading the list of effects types for fx1-fx3 (page 42), I don't see a distortion/overdrive type listed, although distortion types are referenced in a later section (page 57). Where exactly do the distortion types fit?
Search on "DIST" - to see all
Page 22
GR-300
This models the Roland GR-300, the famed analog polyphonic guitar synthesizer of yesteryear.
It provides hexa-distortion, with a hexa-VCO and VCF (variable frequency filter) that generates
independent pitch-shiftable sawtooth waves for the six strings, letting you enjoy analog synthesizer
sounds that reflect the nuances of your guitar performance
Page 32
GR-300 Mode MODE
Specifies whether to sound the hexa-VCO (sawtooth wave), the hexa-distortion (square wave), or both.
VCO Only the hexa-VCO will sound.
V+D The hexa-VCO and hexa-distortion will sound together.
DIST Only the hexa-distortion will sound.
Page 34
AMP Modeling
GAIN 0–120
Adjusts the distortion of the amp.
Page 41
POLY FX
TYPE : DISTORTION
Distortion that allows chords to resonate clearly and beautifully
COLOR: DISTORTION
DISTORTION:
Adjusts the amount of separation for chords. Higher settings produce chords less muddy.
Page 57
EFFECT Parameters >
DISTORTION (DS BLOCK)
This effect distorts the sound to create long sustain.
DISTORTION: TYPE
MID BOOST  - This is a booster with unique characteristics in the midrange.
CLEAN BOOST - This not only functions as a booster, but also produces a clean tone that has punch even when used alone.
TREBLE BOOST  - This is a booster that has bright characteristics.
CRUNCH  - A lustrous crunch sound with an added element of amp distortion.
NATURAL OD  - This is an overdrive sound that provides distortion with a natural feeling.
WARM OD - This is a warm overdrive.
FAT DS - A distortion sound with thick distortion.
LEAD DS - Produces a distortion sound with both the smoothness of an overdrive along with a deep distortion.
METAL DS - This is a distortion sound that is ideal for performances of heavy riffs.
OCT FUZZ - A fuzz sound with rich harmonic content.
A-DIST - This uses MDP technology to obtain ideal distortion in all ranges of the guitar, from low to high.
X-OD - This is an overdrive that uses MDP to obtain the distortion that's most appropriate in each pitch range.
X-DIST - This is a distortion that uses MDP to obtain the distortion that's most appropriate in each pitch range.
BLUES OD - This is a crunch sound of the BOSS BD-2. This produces distortion that faithfully reproduces the nuances of picking.
OD-1 - This models the sound of the BOSS OD-1. This produces sweet, mild distortion.
T-SCREAM - This models an Ibanez TS-808.
TURBO OD - This is the high-gain overdrive sound of the BOSS OD-2.
DIST - This gives a basic, traditional distortion sound.
CENTA OD - This models a KLON CENTAUR.
RAT - This models a Proco RAT.
GUV DS - This models a Marshall GUV'NOR.
DIST+ - This models the sound of the MXR DISTORTION+.
METAL ZONE - This models the sound of the BOSS MT-2. It produces a wide range of metal sounds, from old style to slash metal.
HM-2 - This models the sound of the BOSS HM-2. It produces distinctive cranked-up distortion sound with compression.
METAL CORE - This models the sound of the BOSS ML-2. It produces a sound that is ideal for high-speed metal riffs.
'60S FUZZ - This models a FUZZFACE. It produces a fat fuzz sound.
MUFF FUZZ - This models an Electro-Harmonix Big Muff π.
BASS OD - Overdrive tuned especially for use with basses.
BASS DS - Distortion tuned especially for use with basses.
BASS MT - Wild, radical distortion sound.
BASS FUZZ - Fuzz tuned especially for use with basses.
HI BAND DRIVE - With this effect, distortion is applied only to the high frequency sounds, and not to the sounds in the low frequency range. It is distinctive for producing a strong low-end even when intensely distorted.
X-BASS OD - This effect uses MDP to provide ideal distortion in all pitch ranges of the bass, from low to high.
BASS DRV  - This models a TECH21 SANSAMP BASS DRIVER DI.
BASS DI  - This models a MXR Bass D.I.+.
anytime the 1/4" input is occupied  - it removes the Normal Guitar input signal from the GK 13 pin input
and
Choose which active input to use when creating patches
GK 13 pin input
or
1/4" Guitar Input
Go to MASTER block at End and Toggle "Change Patch Type"
See Page 13
DYNAMIC Synth String Pan / Level
DYNAMIC Synth User Alt Tuning and User Pitch Bend Range
DYNAMIC Synth - OSC TYPES
DYNAMIC Synth with Two User Assignable Arpeggiator Sequencers
DYNAMIC Synth Layer Note Range Assignment
For 1/4" Normal Input Synth Factory Patches
Start at P48-1 thru P50-4
Quote from: rsm on December 13, 2019, 08:20:47 AM
Can the normal pickup 1/4" input be used as input into the OSC without using the hex input? Similar to how the SY-300 works?
Looking at the signal diagrams, the "Normal" input goes through a different path, then the manual states the following for the INST block "This is the sound engine section that generates sound based on the performance data from the divided pickup and the audio input from the
guitar (bass).
"  - does this mean it works like the SY-300 as input to INST if set to OSC?
Yes- below is separate 1/4" Normal Pickup Guitar Input ONLY Patch signal routing resources.
the input source is switchable from:
* the 1/4" Guitar Input
or
* the Normal Guitar signal feed on GK 13 ( Pin 7)
New features not found on other Roland / Boss units
*High Speed USB: which should yeild lower Audio & MIDI  latency for Win/ Mac platforms
*Left Main Output is a one cable 1/4" Stereo TRS
Quote from: admin on December 15, 2019, 11:43:00 AM
I wonder if at some time "Midi 2.0" protocol might be introduced.
The latest SY-1000 is the 1st Gk 13 pin Processor with full 32 bit A/D, D/A processing
https://www.nikkei.com/article/DGXMZO54064350W0A100C2L61000/
Roland Synthesizer Converts Guitar Sound
Roland will launch the "BOSS" brand synthesizer "SY-1000" in February. This is a new model of the product called "Guitar Synthesizer", which can be connected to an electric guitar and played like a synthesizer. The sound is more powerful than the conventional type. The planned price is around 110,000 yen.
The company aims to sell 5,000 units in Japan and overseas within one year from its release.
Expressive power spreads because three different sounds can be layered
Unlike a keyboard-type synthesizer that plays on the keyboard, it converts the sound of a guitar or bass guitar into a synthesizer sound. Use an optional connector and cable for connection.
The tone has been improved compared to the conventional type, and up to three different sounds can be layered. You can play the guitar and organ at the same time by playing one guitar. It also has an effector function that can add effects such as reverberation and fluctuation to the sound.
I plan to create a SY-1000 Navigation Spreadsheet, to indicate the hierarchical location of each parameter on each LCD menu  screen for rapid patch creation / tweaking at live gig.   based upon the SY-1000 Reference Manual
So far a few observations
"INST BLOCK "VIO GUITAR" mode  has a  "HARMO" setting - but this is NOT a Harmonizer - instead its for "adding overtones (harmonics) to the sound specified in the GUITAR block." (Page 40)
And the INST Block when set to  "DYNAMIC SYNTH, OSC SYNTH" has a "AMP" setting - but this is not Guitar AMP Modeling, instead its Synth ASDR controls ( page 31)
While the INST Block set to "E.GUITAR, ACOUSTIC, AC BASS, E.BASS" does have a "AMP Modeling" Guitar / Bass Amp Modeling inside the INST Block
Quote from: Imerkat, post: 29792810, member: 97678just ask on question/request: Why No USB Class Compliant
Ive been told its because the SY-1000 employs Roland latest new lower latency  8 Input / 8 Output USB Audio  / MIDI USB stack
See page 20
QuoteUSB COMPUTER port: USB B type (supports High-Speed USB, USB Audio, and USB MIDI)
Quote"Can the effects/blocks be moved anywhere in the chain?"
Yes !!
Use Boss Tone Studio Editor to fully  understand the power of this feature when designing your own patches
Quote from: tjontheroad, post: 29873221, member: 156823Well, I'm interested in how they made those patches. I gotta admit, there is a lot of cheesiness in those synth sounds. Very retro "back to future" like tones. Very basic sounding. I hope I can mangle some more modern moving textures out of the synths.
the Roland VG-99 shares some resources with SY-1000  - and at VGuitarforums we have a 12 year repository of VG-99 User created patches, many with MP3 examples.
Since the VG-99 Editor runs in an "Offline mode" and can load / import  any VG-99 User patch for review
One could employ a concept I call  "Patch Cloning" and run both editors side by side and duplicate many VG-99 patches in Boss Tone Studio for SY-1000
Patch Cloning
https://www.vguitarforums.com/smf/index.php?topic=4087.msg27632#msg27632
VG-99 User Patch Exchange
https://www.vguitarforums.com/smf/index.php?board=35.0
Quote from: slooky, post: 29944353, member: 160240Why would they not include the Tera Echo in effects. Its such a nice sounding effect. I did see a warp delay that produces a dream like sound. hmm interesting
It was explained to me during the NAMM SY-1000 Round table that each effect has a specific quality I'll call "DSP Memory Load"  - they had to balance the new SY-1000 Synth features they wanted to maintain, while demoting of few effects which require a higher, "DSP Memory Load".
They never want SY-1000 to experience the  dreaded "DSP Out of Memory" error while building a patch , often seen on older Line-6 gear
the Normal Signal path features GT-1000 class Amp  / Cab modeling and 32 bit effects   - but a simple review of the Parameter Guides and Reference Manuals for each device reveals SY-1000 does NOT include every GT-1000 FX or feature.
Each of us has specific ears and minimum requirements for our needs, for many the SY-1000 may be the All in one, to cover all your needs.
While for others , SY-1000 is simply handling the Synth and Alt Tuned Guitar duties, while their Kemper / Axe-FX handles their main guitar tones.
JiveTurkey wrote>
Hypocritical question,
did that meeting with Yoshi and the team reveal any plans to offer IR loading in the SY? Not a dealbreaker; just curious.
Our SY-1000 Round table team at NAMM hammered them on adding this  and reminded them that on $1K Guitar MFX box CAB IR Loading is an expected feature.
They have only 15% available space in the DSP which is already very busy with other tasks  - I would not hold my breath for  CAB IR loading to  occur as FW update on SY-1000
The good news  - the SY-1000 employs same AIRD Cab sims as GT-1000 and are already very good - and the flexible rerouting of the SY-1000 signal chain is the most intense ever offered from Roland/Boss  -
For basic guitar tones at a live gig , I prefer SY-1000 over my GT-1000 = its much easier to navigate and program and tweak, and you can route the normal electric guitar signal path to the 1/4" Sub Outs only - then feed a separate third party Cab IR Box if desired.
SY-1000 paired with a GR-33 with a US-20 A/B/Y GK 13 pin Switcher is an excellent combo  - I much prefer the GR-33 PCM Sound set vs the GR-55 PCM sounds, and there are better real time Synth controls on GR-33, and less likely to accidentally hit the GR-55 Looper or wave player footswitch combos
If you have only experienced GR-55 PCM and desire something new , try the GR-33 which IMHO has MUCH better Pianos and Saxophones
and there is a MIDI Quest GR-33 Editor
https://squest.com/Products/MidiQuest12/Instruments/RolandGR-33/
http://www.macminer.opoka.com.pl/gr33/
