Sonible ML:1
Started by admin, July 27, 2019, 01:17:07 PM
https://www.sonible.com/ml1/
https://www.sonible.com/wp-content/uploads/2016/11/sonible-ml1-user-guide.pdf
sonible Menu
ml:1
The USB DI-box for event professionals
plug & play audio interface | stereo DI-box | test tone generator
sonible
ml:1
The previously missing link in sound technology – a robust, multi-functional USB-DI-box for first-rate audio playback.
Professional and extremely robust DI-box
Crystal clear plug & play sound for any device
Unique broadband multi-tone generator
Features
Superior playback quality.
Right out of the box.
Driverless thanks to USB Audio Class 1 Standard
Brilliant USB audio playback via notebook computer and other mobile devices
Compatible with all notebooks and most smartphones and tablets, the audio-interface simplifies the playback of audio material by conforming to the USB Audio Class standard. As soon as a device is connected via USB, it is ready to play back – with no need to install additional drivers. The quality of the audio signal is significantly higher and substantially more robust than that provided by headphone jacks.
The seamless plug & play feature proves especially useful in the day-to-day work of professional live engineering, when flawless video or audio must be provided during events like seminars, lectures, or live shows. A great plus: the Neutrik USB connection can be locked to reliably withstand sudden jerky movements.
professional DI-box
Passive stereo-DI-box guarantees hum-free signals
Equipped with two 6.3mm jack plugs, the ml:1 can also be used as a passive DI-Box that offers clean, symmetrical signal routing. Low-distortion signal transformers ensure galvanic separation and a signal that is 100% free of interference. In addition, a ground lift switch remedies problematic ground loops.
Line check with multi tone
Test tone generator for "pre-soundchecks"
For savvy live technicians, the integrated test tone generator provides an additional handy feature. Thanks to a lithium battery, it operates self-sufficiently, and above all independently of phantom power or any other external power sources. This avoids many a hassle and saves time and nerves.
A multi-tone (a complex wave form) makes it possible to test whether all channels are playing correctly and whether the cabling works. It also lets you check whether there are any sources of disturbance in the system – all without the need for an external device, and absolutely perfect for the quick line check before the artist is present.
Testimonials
S. Kosmalla
tools4music.com
Thumbs up for the high-class DI-box with test tone and USB interface.
N. Mavridis
bonedo.de
On all system, the installation was straight-forward: connect USB cable, select, output, finished.
K. Chonisvhili
recording.de
You can see right away that this is a great tool for professional live- and event technicians.
   NextPrev
ml:1
Your swiss army knife in audio.
€239,- (€299,-)
The ml:series rack-mount is available for €89.
Interested, but not sure yet?
Get in touch with us for more info!
Get your demo model
when ordering at least 5 pcs.
Request a callback
by telephone or skype
Send us a message
via email
Send us a message
If you have any questions about our product, please send us a personal message and we'll get in touch with you as soon as possible.
Name
Phone
email@example.com
Text
Use Cases
Who is using ml:1?
JANUARY 31, 2017
USB-DI box ml:1 and jazz fusion group Filou on stage
Jazz-fusion group Filou recorded their first album in the course of the Headphone Sessions at the jazz club "domicil" in Dortmund. Julian David was in charge of this elaborate video live production.
READ MORE CASE STORY
NOVEMBER 2, 2017
Toni Loitsch: "Quality begins at the source."
This up-and-coming producer and mixing engineer works with some of the best bands and artists from the German punk, rock and pop music scenes.
READ MORE PRODUCERS & ARTISTS
APRIL 11, 2018
Philipp Dusse at Funkhaus Berlin: A Bastion of Good Sound
Rammstein guitarist Richard Kruspe, trance-god Paul Van Dyk and German rapper Cro have already enjoyed the one-of-a-kind room acoustics at Funkhaus Berlin.
Press
Spezifikationen
Technical Details
Download Manual
General information
Size
183 x 93 x 40 mm
Weight
~1000 g
Power Supply
≤ 40 mA USB bus powered
(only needed for USB audio)
Connectors
1x USB (lockable Neutrik receptacle)
2x Jack (analog in)
2x XLR analog out
1x XLR AES/EBU (digital out, S/PDIF compatible)
Output level
0 dBFS equals +3dBu
Ground lift
yes
Pad
0 dB/ - 18 dB
DAC
Sample rate
44.1 kHz, 48 kHz
Sample word length
16 bit
SNR
96 dB
Test Tone Generator
Waveform
harmonic multitone
Amplitude
-8 dBu
plugins
smart:comp
smart:EQ 2
smart:EQ live
proximity:EQ+
entropy:EQ+
frei:raum
ml:serie
ml:1
ml:mio
d:serie
d:16
d:24
sonible
Shop
Support
About us
Press
Contact
Stay tuned!
email@example.com
© 2019, sonible GmbH
supported by AWS impulse XL
Facebook
YouTube
Twitter
Home Page Legal Information Privacy Policy EULA AWS impulse XL
ENDE
Size
183 x 93 x 40 mm
Weight
~1000 g
Power Supply
Connectors
2x Jack (analog in)
2x XLR analog out
Output level
0 dBFS equals +3dBu
Ground lift
yes
Pad
0 dB/ - 18 dB
DAC
Sample rate
44.1 kHz, 48 kHz
Sample word length
16 bit
SNR
96 dB
Test Tone Generator
Waveform
harmonic multitone
Amplitude
-8 dBu
