How to connect gigboard to gr 55?
Started by ricmus, June 01, 2019, 10:06:46 AM
ricmus
Hi
I have just gotten a Boss gr 55 and would like to connect it to my headrush gigboard. Can anyone guide me?
Quote from: ricmus on June 01, 2019, 10:06:46 AM
Hi
Similar to GP-10
Jayme Daumen wrote>
Ok all working!!! My boss gp10 is in the Gigboard effects loop running all the 13 midi stuff and the gigboard does all the regular tones...I added a toe switch to the ehx pedal (For Toe Switch I bought a dpdt switch off eBay for 3$ drilled a hole for it in the EHX expression pedal and drilled a hole for a stereo 1/4" plug solder it up and done) ...zero noises and sounds amazing...
I run GP-10 in the Gigboard's FX loop because I then have a on/off feature...I only use the Synth sounds on the GP-10 so bass detune keyboard tones...it makes it easier with live and still have access to the Gigboard looper
https://www.facebook.com/groups/headrushboard/?multi_permalinks=595224300963840&notif_id=1559151307584371&notif_t=group_highlights
ricmus
Thanks for the reply. Best wishes from Brazil
