Katana Line Out Level for Recording
Started by Petros_k, January 08, 2019, 01:17:46 PM
MoteTotoro
Quote from: admin on April 12, 2022, 11:04:51 AM
Katana is not capable of stereo audio from Rec /Phones output
Connect TRS headphones results in dual Mono feed to headphones
So, TS cable for both Line Out and Rec/Phones Out? I wanted to be able to connect my Katana 100w MKII via usb to my PC to record in stereo and monitor through my headphones connected to my interface, but it seems there's no way (at least on windows) to select different input and output devices in my DAW (studio one 4), unless someone knows a way to do this and wants to share it. Otherwise, gonna have to connect my Katana via line out or Rec/Phones to my interface and record in mono to be able to monitor through my headphones connected to said interface.
Windows is generally a one audio device at a time deal, but you can cheat it with installing "ASIO4ALL" which introduces a very small latency delay at the gain of using as many audio devices as you have.
You could also monitor through the Katana too, although not ideal.
