2007 VG Strat - 2013 G-5A Strat - Can I swap only the Roland internal PC boards?
Started by Virtual Madness, June 28, 2018, 11:57:08 PM
Virtual Madness
I don't want to swap the GK pickups if I don't have to. There's a lot of tiny wires under those pickguards!
Here is the info on the DC Resistance of both guitars GK drivers/pickups.
2007 VG Stratocaster (is this a GK-3?)
Pin #1. String 1 - E - DC Resistance = 95.3 Ohms (Brown)
Pin #2. String 2 - B - DC Resistance = 94.1 Ohms (Red)
Pin #3. String 3 - G - DC Resistance = 92.4 Ohms (Orange)
Pin #4. String 4 - D - DC Resistance = 96.4 Ohms (Yellow)
Pin #5. String 5 - A - DC Resistance = 91.2 Ohms (Green)
Pin #6. String 6 - E - DC Resistance = 95.9 Ohms (Blue)
Pin #7. Black - Ground Reference.
Pin #8. Ground - Cable Shield.
2013 G5-A Stratocaster (GK-3)
Pin #1. String 1 - E - DC Resistance = 88.9 Ohms (Brown)
Pin #2. String 2 - B - DC Resistance = 91.6 Ohms (Red)
Pin #3. String 3 - G - DC Resistance = 89.2 Ohms (Orange)
Pin #4. String 4 - D - DC Resistance = 88.3 Ohms (Yellow)
Pin #5. String 5 - A - DC Resistance = 89.3 Ohms (Green)
Pin #6. String 6 - E - DC Resistance = 88.6 Ohms (Blue)
Pin #8. Ground- Cable Shield.
I want to do this because I like one guitars wood, but the other guitar's sounds. Is there any electronic reason not to do it? (incompatability, better firmware in the 2013 model...etc)
Thanks guys, Royce  :)
The greatest power in the universe is imagination!
Quote from: Virtual Madness on June 28, 2018, 11:57:08 PM
They are within the 90 ohms +/- 5% tolerance for that type Roland hex PU.
Either should function equivalently when feeding VG Strat  or G5 DSP Board
Virtual Madness
Thanks Steve, as always, much appreciated!  :)
One more thing, (if your still around) Is that a GK-3 in the 2007 VG Strat?
Quote from: Virtual Madness on June 29, 2018, 06:33:14 PM
the hex PU is the same white cover Fender / Roland type as used in the Roland ready Strat and GC-1 , 2007 VG Strat and 2012 G5
the Gk-3 hex PU has adjustable radius , but has more loose parts that are prone to rattles , which often is the  source of mis-tracking errors on GR-55 - solved by Wax potting
https://www.vguitarforums.com/smf/index.php?topic=43.0
Virtual Madness
