VHT amps with iOS ToneLink
Started by pacemaker1000, April 04, 2018, 01:25:47 PM
pacemaker1000
Anybody tried these valve amps that you plug your iOS straight in to?
Uses audio cable and compatible with all iOS apps like biasfx, Tonebridge etc
http://www.vhtamp.com/products/the-i-series
Quote from: pacemaker1000 on April 04, 2018, 01:25:47 PM
It uses the 3.5mm TRRS headset jack connection - so its doomed to exhibit lots of hisss and possible feedback on high gain
Why?
because it runs all audio from the amp thru the noisy built in Apple Mic preamp circuit inside iPhone  / iPad
A 24bit USB Class Compliant Audio interface will be superior  - just make sure it works with IOS 11 ( which "broke" many IOS USB audio interfaces.
For working IOS Audio interfaces - read this area:
https://www.vguitarforums.com/smf/index.php?board=212.0
pacemaker1000
Just testing the water.
Already use a sonic port vx and considering using this in the effects loop of a tube amp. This was a possible alternative
