Boss Gt-8 help
Started by buboY, March 06, 2018, 08:53:11 AM
buboY
      Hi guys can any one help me with my boss Gt-8 on how do get good patch with the gt-8 pre amp off. So i'm just normally using the analog and my connection is pretty straightforward a 2 cable method..And most of the time i'm having a hardtime adjusting my volume level with the pedal, Whenever i switch to clean sound i need to hit my volume pedal up and when i'm using my overdrive or solo patch i need to lower my volume pedal. Is that normal or is there a way to make my clean patch and dist/overdrive patch with the same volume level? thank you.
With in each "User" Patch, you need to adjust it's level with the "Patch Level" control parameter, and then write/save the patch to the required level.
