VB-99 - Noisy GR patches
Started by Antonuzzo, November 22, 2017, 01:54:32 AM
Antonuzzo
I noticed that GR33B patches seemed noisy in their rest state, and confirmed it by building a patch from scratch. Selecting the GR synth as the driver immediately resulted in a lot of crackling. There were no problems with any of the other synth drivers.
It might be a dodgy cable - I'm going to dig out a spare and test that when I remember where I stored it. But has anyone else noticed this?
Edit: It's not the cable - I've tried two, on two different basses. What I did notice that there is no noise until a cable is connected, but also touching the GK input results in noise. Very odd.
fokof
What system do you have on your bass ?
A GK pickup or a piezo ?
I don't experience this with my 2 VB99 with piezo basses.
I will try with a bass with a GK pickup.
Quote from: Antonuzzo on November 22, 2017, 01:54:32 AM
What pedal?
A genuine GR33B ? Or ?
http://www.joness.com/gr300/GR-33B.htm
Antonuzzo
Both basses have a GK-3B on them, not Piezo.
It's a VB-99 - It's the GR patches where this happens.
Kingbrit
Hi mate. Did you get anywhere with this? I have the same issue with mine...
Ben.
Kingbrit
Is this forum dead these days? =(
The VB-99 area is always slow  ( due to the limited numbers of owners )
The VB-99's SYNTH "ANALOG GR"  is notoriously noisier than the "E-Bass" COSM instruments
If you have a Bass with Piezo Saddles as part of your GK 13 preamp (Godin/RMC/Graphtech Ghost)  - you will benefit from an RMC SubHarmonic Filter for VB-99  = which will minimize noises that become apparent on the VB-99's SYNTH  - Analog GR model
( this is different than the VG-99 subharmonic filter , as the fundamental Bass Frequencies are pitched an octave lower than Guitar
fokof
I have 2 VB99 , one with a subharmonic filter , one without
just tried with the preset #208 (JazzGtSyn) , both are very clean with either Piezo or GK pickup.
I suggest to use your headphones , and unplug everything else , 1/4 , XLR , USB , SPDIF and check if it's still noizy.
I once had a ground loop with a USB interface.
