MIDI Pipe - OSX MIDI tool software
Started by primarilyade, October 07, 2008, 03:19:22 PM
primarilyade
For those interested in having their MIDI output be a lot more flexible, check out
http://www.subtlesoft.square7.net/MidiPipe.html
Also has a MIDI guitar preset
I've found it very helpful and easy to use for routing MIDI around my computer from the VG-99 (i.e merging channels 1-3 into Channel 1, and 4-6 into Channel 2 to achieve a keyboard esque split of the neck)
Hope it's useful!
MidiPipe V1.4.6
About
MidiPipe is freeware and comes with no warranties. MidiPipe can be useful in a music studio or live on stage to route, map, filter, convert, display, input and output MIDI messages in real-time. Mac OS X 10.3.9 (Panther) or higher is required.
Use
Click on a tool in the "Tools" list (left side) to see it's parameters. "Drag&Drop" or "Double Click" a tool in the "Tools" list in order to put it in the pipe (right side). Tools in the pipe can be reordered via "Drag&Drop". MIDI messages "flow" from top to bottom through the pipe. A pipe can have several inputs and outputs. A message arriving at an output will be copied to the output and then continues "flowing" through the pipe (if there are additional tools after the output). In order to edit parameters of several tools at once, it is possible to open a panel for each tool by double clicking it in the pipe list.
Tools
•  MIDI In - connects a MIDI input to the pipe
•  MIDI Out - connects a MIDI output to the pipe
•  AList - outputs messages to the screen
•  Message Converter - converts messages from one type to an other
•  Delay - delays the time for when the message is scheduled
•  Transpose - transposes note to multiple keys, set velocity, delay and channel for each
•  Message Filter - filters by messages
•  Channel Filter -  filters by channel
•  Channel Router - routes channels
•  Keyboard Split - moves note on/off messages above/below a split point to a different channel
•  Randomizer - randomly changes any parameter value(s) of any channel message(s)
•  Keyboard - play a on screen keyboard with your mouse or keys; will display arriving messages too
•  MicroTuner - apply different scales
•  Set - set any parameter value(s) of any channel message(s) to any value
•  Duration - add a delay between Note On and Note Off messages
•  Control Split - inverse, limit, scale, fade in/out, route and map MIDI controllers
•  Control Slider - simple slider for control message input
•  AppleScript Trigger - use the power of AppleScript to implement everything you want
•  (N)RPN Mapper - map (N)RPNs
•  Velocity Modifier - scale, shift, clip and filter the velocity of Note On and Note Off messages
•  SMF Player - plays up to 128 MIDI Files; handles Song Select, Start/Stop/Continue messages
•  Key Mapper - map keys
•  DLS Synth - user interface for Apple's DLS Synth
•  Message Factory - trigger your own messages with static and variable data bytes
•  Double Filter - filters identical messages
•  Monophonic - make monophonic
2pods
That looks so cool, but it's Mac only  :'(
Fender G5 Strat, PRS SE Santana/w TriplePlay
jvguitar
Quote from: 2pods on October 15, 2008, 05:28:06 AM
There is an application in the PC world called MIDI-OX. If used in conjunction with MIDI Yoke you can get similar features. I use them to filter and route the USB MIDI output of the 99.
http://www.midiox.com
I hope this helps.
JV
2pods
Thanks JV.
I knew about Midi-OX as I used it with TDMate to edit my Vdrums.
I'd heard about Midi Yoke too, it's just Midi Pipe looked very neat - all in one type of thing  ;D
