FTP - Equalizer VST for TriplePlay
Started by PeterPan8, November 13, 2017, 09:21:03 AM
PeterPan8
I was wondering if there is a VST that could be hooked to the TP software, and that would enabling me to adjust the output audio, like an external equalizer (EQ) would do?
I don't want to get a separate box, but something that could fit in TP. And I'm not talking about the 1st channel where the guitar audio (like Gutiar RIG 5) can be adjusted through a virtual EQ cabinet. I'm looking for something that could be available on the other channels, through a separate VST EQ.
For instance, I can play an instrument (piano, violin, etc.) on Channel 2, and Channel 3 could hold a EQ VST, so I can "adjust" the output audio of the Channel 2 (more treble, less bass, etc.)
Hope I'm clear enough!  Is this feasible? Anyone done that before with TP?
QuoteI was wondering if there is a VST that could be hooked to the TP software, and that would enabling me to adjust the output audio, like an external equalizer (EQ) would do?
learn  how the Tripleplay works - here
https://www.fishman.com/support/tripleplay-support-materials/
The Fishman Tripleplay is only a Guitar to "MIDI over USB" device.
It will always require a third party Audio interface.
If you are running on Windows or Mac  - many use an Audio interface with its own DSP - for example a Mark of the Unicorn 828MKIII has separate low latency DSP controlled EQ for each output channel
Same as a Steinberg UR-44
A few folks run the Tripleplay USB Receiver connected directly to alternate hardware
Fishman Tripleplay F.A.Q.
https://www.vguitarforums.com/smf/index.php?topic=8427.0
https://www.vguitarforums.com/smf/index.php?topic=17369.0
