GT-001 - Gumtown's GT-001 FxFloorBoard editor
Started by gumtown, May 12, 2014, 02:37:46 AM
Another windows version update (20140822) with the EZ-Tone fixed, and hopefully the system/Midi pages, and the 'connect'.
Keep me informed on where the GT-001 is at with the editor, been working on may other editors too, so I have lost focus.
list things to test and confirm (preferably with debug mode off).
1. GT-001 'connects' with connect button (stays lit and no error message
2. Left panel 'patch tree' items can expand and patch names occupy the list
3. A 'double click' on a patch name from the patch tree will load the selected patch into the editor GUI.
4. the 'write' button will write the patch to the GT-001 (write location is selected by 'single click' of the patch tree or existing patch number in top left display)
5. opening the System or Midi page will load the current GT-001 settings without error.
6. EZ-Edit tone page works without crashing.
Bill Ruppert
MickTheHat
Have just downloaded 0822, Mr G. Commencing 3 weeks hols in exactly 1 hour, so let the extensive testing begin!
Bill Ruppert
odon60
hi need help everytime I try to start floorboard up for gt001 it comes up with that it has stopped working I have debugged ticked , set to channel 1 any ideas  I am using win 7 64 bit cheers
The editor program has never been  quite finished, just that small bug which crashes it.
I will need to buy a GT-001 to fix that, waiting to find one used at a good price.
The price of buying a new GT-001 doesn't justify using it for a week or two to finish the editor, than have to turn around and sell it at a loss.
odon60
 hi thanks for replying, but yes I can understand that and fully appreciate your hard work in developing these things ,and will wait and hope you pick one up nice and cheap soon , thanks again for replying and your work that you do for us cheers paul
GT-001 incoming !!!
Just picked one up on a local eAuction super cheap. (US $100 equivalent), and awaiting it's arrival (still with factory box and packaging).
I will be able to finally complete the editor..  ;D
updated the GT-001FxFloorBoard editor, so it now works.
A few bits to fix up, such as the bulk loading of backups, and a few system features to tidy up.
All going good .. ... .. ...
loaded up versions for Windows, mac, and linux
GT-001FxfloorBoard
editor updated to
version 20170430  (30th Apr 2017)
Fixed the problem with muted patch levels when loading *.tsl (Tone Studio) patch files,
and updated a few minor tweaks.
for
Windows
Mac
Linux
download here
https://sourceforge.net/projects/fxfloorboard/files/GT-001FxFloorBoard/
riccosuabe
hi there
ive just downloaded the program and once it loads up i select my gt001 as the usb device then when i press connect it loads up the patches on the side menu then the program crashes saying its stopped working.am i doing something wrong? thanks
here is a fix up update,
some system parameters were a bit off..
current Version 20170518  (18th May 2017)
stevesilk51
Hi Colin,
Getting the GT001 Floorboard to populate the patch tree correctly but when it finishes it immediately crashes.
I have the following set up:
Win 10 64 bit.
The latest version of Floorboard (20170518)
Midi in : GT-001 , Midi Out: GT-001  (any other settings I get no reply error in the patch tree locations)
Debug On, Auto Select GT-001 USB on
Probably something simple I'm doing wrong?
I will check this out next week,
probably some patch or system parameter's range that the editor may have not encountered until now.
Carlos Velho
#40
Good day to all.
A question about the software FxFloorBoard: I can run almost every patch (.sys, .mid, etc..) on my GT-001 (some of they make no sound and I understand it must be a patch for other FX unit model) but I cannot save, the ones that runs OK, in a good way as .tsl to open with the Boss Tone Studio because there is no sound on GT001 when I import the patch just saved. Is it right? FxFloorBoard is able to open and play but not to save? By the way it is a amazing software and thanks to GUMTOWN.
Many shared patches come from the GT-10 and GT-100, where they may have been saved with the Expression pedal set to minimum volume.
In the GT-001 settings, if you manually dial up the F.V. (foot volume) level, you will hear the sounds.
GT-001FxFloorBoard saves patches from my recollection.
Carlos Velho
Thanks for the reply gumtown.
Yes, the patches without sound, the problem was at FV levels. But one thing I realize is that when I save the patch I am playing in FxFloorBoard - it is not muted - as * .tsl file and I load it in Boss Tone Studio, max volume is at minimum value. That was the reason there was no sound. Well, now I can play and save, knowing what happens, thanks to you.
Thank you again.
AwesomeLizard
Hi, been using floorboard on netrunner linux 21.01 build 20210215.0546 without issues for a few weeks and now it crashes on bulk sending after starting up.
Welcome to the group AwesomeLizard!  :)
AwesomeLizard
I reset to factory settings and things seem to be working for now.
