CoolAudio V1000 DSP MFX ic - (Bugera V22/V55)
Started by admin, February 08, 2023, 03:25:02 PM
V1000
Low-Cost One-Chip Multi-Effects DSP
Functionally compatible to Alesis AL3201*
https://www.digchip.com/datasheets/parts/datasheet/922/AL3201-pdf.php
With 16 built-in reverb and multi-effects, the V1000 Digital Multi-Effects DSP delivers outstanding audio performance in a rapid time-to-market solution at a very affordable price. Since the V1000 incorporates its own RAM and on-board effects, a complete reverb system can be designed with only the V1000, a low-cost ADC and DAC, and a simple 4-bit controller such as a rotary encoder etc.
https://www.coolaudio.com/features-page.php?product=V1000
http://milas.spb.ru/~kmg/dre_en.html
Digital Larry
That's been around awhile.  I compared it to the Spin FV-1 (at least a quick datasheet overview).  The chip itself doesn't have pot inputs so if you want to be able to tweak parameters you have to add another micro to poke control values into the V1000.  On the flip side it seems to have more sophisticated algorithms for LFOs and pitch shifting than the FV-1.
