HELP Request: All patches level are at zero. They return to zero after saving
Started by Piing, September 18, 2022, 02:37:13 AM
Piing
I haven't been using the SY-1000 for about one year. Now I am playing with it again, but the main level of all patches is at zero  :-\
I can set it to 100 but, after saving the patch, the level is back to zero again
That happens both saving the patch with the buttons or with Boss Tone Studio
Any suggestion? This is very frustrating
And no assigns to patch level?
I think GK volume is assigned by default to patch level
And the hold assigns
Piing
Issue solved. My GK-3 switch was on "GUITAR" position, so even though the GK volume was set to 100, the presets levels were always reset to zero after recall
What a failure! After having been using GKs since 1995, with the VG8, I think I am officially getting old 😅😅😅😅😅😅😅😅
Well you're not alone.....
I just made a similar mistake.
Trying out the space guitar synth on my iPad
Direct monitoring, fine , test signal from space guitar fine
Checking all the possible parameters that could be set wrong in SG.
but no signal in or out from SG.
Well I forgot to give Space Guitar access to the microphone........... 🥸
stub
I'm at that level where I keep copious notes, but forget about them. Need to find a cheap tattoo gun.
