Connect the GT-1000 to the Yamaha G100-210 Solid State amplifier
Started by ReBart, August 29, 2022, 03:11:17 AM
ReBart
I just bought a GT-1000 and need some advice on how to connect it directly to my amplifier. I couldn't find much information about it and it seems to me that the manual doesn't help much. However, I have two amps, a Yamaha G100-210 and a Fender Deluxe Reverb reissue. However, neither of them has the send and the return. How should I set the output of my GT-1000 for this type of amp?
Boisdelac
I would connect my guitar to the GTs input, and the left (mono) main out to the guitar input of your amp.
First i would set the outputlevel of the GT and set the amp i am using.
How to ....
On your GT press the MENU button,
press IN/OUT setting,
press MAIN OUT out
press OUTPUT LEVEL
dial the output level to -10dB (this sets the outputlevel of your GT to -10dB)
press exit
press OUTPUT SELECT (this selects the kind of amp you use to amplify the sounds coming from your GT)
dial the AIRD OUTPUT SELECT to JC120 Input (selection for your Yamaha amp)
dial the AIRD OUTPUT SELECT to TUBE COMBO 112 Input (selection for your Fender Tube amp)
press exit 4 times.
Try also other amp output selections. They all sound slightly different. Take the best sounding.
ReBart
