PA for Multiple Instruments
Started by ravmitterhoff, June 12, 2022, 04:08:30 AM
ravmitterhoff
I am working on created a dawless rig for small venues. I have an electric guitar, synth, drum machine and mic and want to know the best way to amplify everything. From what I have researched the electric guitar needs to go to a guitar amp and I am using a boss katana. Does anyone have an opinion as to what would be the best solution for the rest instruments.  I was thinking of staring with Bose S1 Pro and then adding a Bose Sub1 if I need more bottom. Besides that I have not found one amp fits all solution. Any suggestions appreciated.
Any good mixing desk + PA system rated for small venues will do,
 I would consider whether you still wish to use a "traditional" guitar amp,
 or use a guitar Amp/effect modelling pedal,
 like the Boss GX-100 / GT-1000 / Line6 Helix,
 and use a stage monitor (or In-Ear Monitoring) for your guitar and other instruments.
The Bose S1 Pro paired with the Bose Sub1 would do nicely,
 if doing a "full band" type sound, you will need the bottom-end re-enforcement of a sub speaker.
