HELP => Dropped the pedal, parts needed.
Started by djszilard, April 22, 2022, 03:40:16 AM
djszilard
Hello!
A few days ago I dropped my GT-100 by accident (while it was in a soft-case) on it's back (on the ports)  :'( .
Inspecting the unit, the stereo output port was a bit loose, so I opened up my unit to find out that the problem is a bit more complicated as I thought.
The output port broke from the board and it took some capacitors with it.
I can repair my unit easily (with some soldering), but there is the following problem: I can't find a schematic for the input/output circuits and parts  :'(.
I need the values for the capacitors that fell of, so I can replace them. Also a model/part number for the output stereo port would be also helpful.
Happily, the the fall only affected the output port and some capacitors on the input/output board (E74366)  ::) .
The parts that I need to identify are:
-capacitor value and type located at at C117
-capacitor value and type located at C116
-stereo output port type (located at JK105)
I need this info pretty fast, because I need to repair my unit as fast as possible (I don't have a backup yet and I was planning to sell this unit in an almost mint condition  :'( ).
Other info (not regarding to my problem): I have this unit since 2013 and I just decided that is time for an upgrade to a GX-100. I ordered the new unit already (before I dropped the old one) but I haven't received it yet, so I don't have a backup. I was planning on selling the GT-100 after I set up the new GX-100  :'( .
I need the part info as fast as possible, so I can repair it and test it if it's still good to sell (the GT-100 served me good throughout the years, so I'm planning to sell it in a good, functioning, reliable condition => there's no point in selling something that is broken  :'( ).
Thanks for the help in advance!
PS: I could upload only one image, so under the following link you can find more images about the internals and waht is affected:
https://ibb.co/ykQ55Ck
https://ibb.co/7VvbhNb
https://ibb.co/ry79jwG
https://ibb.co/Rg4JYyD
https://ibb.co/2618MHP
Mrchevy
Would the damaged capacitors have the values printed on them. If so, I have one that I can open up and look and get the value information for you with pictures
Gibson Les Paul Custom
Epi Les Paul Standard
Gibson SG 50's prototype
Squire classic vibe 60's
Epi LP Modern
Epi SG Custom
Martin acoustic
Princeton chorus 210
GT100
GR-55
Helix LT
Waza Air Headphones
Boomerang III
