SY-1000 / VG-99 / US-20 - Unexpected behavior
Started by Vaultnaemsae, February 15, 2022, 05:06:20 AM
Vaultnaemsae
Use case:
US-20 is acting as an A/B/C switch for SY-1000 and VG-99.
I can switch out the A device for US-20 power but mostly have the VG-99 in A due to my setup.
With no C (Both) active the US-20 should function as a simple A or B switch.
But:
-If A is selected I can hear the VG+SY
-If B is selected I can hear only SY.
The VG is switching correctly. The SY is not.
I tried switching A and B on the US-20 to see if is makes a difference but it responds the same way just in reverse port order.
What could be the issue with the SY-1000? It's clearly not the US-20. It's probably something simple but I can't figure it out. Any ideas?
Vaultnaemsae's SoundCloud:
Vaultnaemsae
OK, I see it's a patch volume issue. Must have both units/presets assigned the same. Duh.
